Epson head cleaning?
ciaran33 Contributing Member • Posts: 638
So, I have an Epson Photo R2400 which works well but can go for ages between print runs. Is switching on/off good enough to keep the heads clean? Or do I need to nozzle check or do a colour print? Thanks for any suggestions.
 ciaran33's gear list:ciaran33's gear list
Nikon D7000 Nikon D7200
Howard Moftich Veteran Member • Posts: 9,940
Re: Epson head cleaning?
you need to do an intermittent nozzle check or some other print that exercises all the colors but doesn't waste too much ink.
Just sitting in 'storage' or not used is great way to kill the print head as the ink dries out and clogs the system.  Pigment printers are worse in this respect than dye printers.
Online civility: Before you press 'Post', ask yourself if you'd say that to someone face to face.
OP ciaran33 Contributing Member • Posts: 638
Thanks for the reply. It seems just switching on and off again performs a mini head clean, or switching on holding power and paper buttons with a sheet of paper in does a nozzle check.
