First morning light hitting mountains
kristian1 Senior Member • Posts: 2,812
22
Hello to all , here i would like to share with you two images taken in Slovenia , early morning light.
All the best
Kristian
 kristian1's gear list:kristian1's gear list
Canon EOS R Fujifilm GFX 100 Canon EF 500mm f/4.0L IS II USM Fujifilm GF 32-64mm F4 Fujifilm GF 23mm F4 +4 more
1Dx4me Forum Pro • Posts: 10,519
Re: First morning light hitting mountains
beautiful shots, image #1 is my pick!
Absence of evidence is not evidence of absence!
OP kristian1 Senior Member • Posts: 2,812
Thanks, I am glad you liked them.
All the best
Kristian
jm10 Veteran Member • Posts: 3,283
Nice pictures Kristian! Great light in #1.
jacob
 jm10's gear list:jm10's gear list
Ricoh GR II Fujifilm X-T2 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS +1 more
John Photo Contributing Member • Posts: 983
The second is a nice composition. I wonder how the first would look with the foreground slightly brightened (slightly, but not to the point of distracting from the main object).
David1961
David1961 Senior Member • Posts: 3,877
Amazing light, colours and images!!
#1 is my favourite but not by much.
Maybe crop a bit off the bottom of #1 to emphasise the light on the peak a bit more?
Thank you for sharing.
 David1961's gear list:David1961's gear list
Canon EOS 90D
gavin
gavin Veteran Member • Posts: 7,901
Nice. I like the second one
 gavin's gear list:gavin's gear list
Sony RX100 III Canon EOS 5D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-85mm f/4-5.6 IS USM +5 more
jacob
Thank you Jacob.
Kristian
Glad you noticed it, actually I tried to brighten and at the end left a bit darker , but probably it should be a bit brighter you are right.
Kristian
Thanks David, on first image I wanted to show the other parts of mountain (probably should be a bit brighter) and to show smaller part of frame where the sun was brightening.
Kristian
Thanks Gavin.
Kristian
JarusNZ Junior Member • Posts: 32
Stunning, love both of these. Kinda makes me want to pick up a 2nd hand medium format set up.
 JarusNZ's gear list:JarusNZ's gear list
Ricoh GR Nikon 1 J5 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor VR 70-300mm f/4.5-5.6
Thanks Jarus, I am sure you can get similar results with FF even apsc, lower resolution but similar look.
Kristian
