Canon t7i with Vello battery grip
Started Nov 23, 2020 | Questions
BasPaul New Member • Posts: 7
There is a problem when the camera has a battery grip attached and is mounted on a tripod.
The electrical contact between the camera and the battery grip loses contact because the structure of the camera body and the battery grip isn't sufficiently rigid to prevent flexing causing the camera to off and back on intermittently.
This happens with the T7i, with efs 55-250 lens mounted, Vello BG-C15 battery grip, on a Vanguard SBH-100 tripod.
The solution, obviously, is to use tripod and camera without the battery grip. I wanted to use the combo to be able to work at a distance for some more time.
Canon EOS Rebel T7 (EOS 2000D) Canon EOS Rebel T7i / EOS 800D / Kiss X9i
kreygscott
kreygscott Senior Member • Posts: 1,285
Re: Canon t7i with Vello battery grip
My suggestion would be to get the OEM battery grip for your T7i.
LANDSCAPE, TRAVEL & OUTDOOR PHOTOGRAPHY
My Website
http://kreygscott.com
My Stock Portfolio
http://shutterstock.com/g/kreygscottphotography
My Blog
https://www.kreygscott.com/blog
 kreygscott's gear list:kreygscott's gear list
Canon PowerShot S110 Canon EOS 5D Mark II Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 17-40mm f/4.0L USM +9 more
mdmarqphoto Senior Member • Posts: 1,460
Not sure if you're still checking this thread, but if it were me I'd probably wedge some paper or something (tape maybe) in the cameras battery compartment along with the piece from the grip to fill in the space that is allowing it to move off the contacts (unless it's moving down and away from the contacts).
 mdmarqphoto's gear list:mdmarqphoto's gear list
Canon PowerShot S5 IS Casio Exilim EX-ZR800 Canon EOS M Canon EOS 90D Canon EF 85mm F1.8 USM +7 more
