Color calibrating pixel shift images from A7RIV
Started 4 months ago | Questions
Jojakim Contributing Member • Posts: 538
I've made color profiles with the free ColorChecker Camera Calibration application a few times now with good results. But somehow the application fails to work with pixel shift files from my A7R IV, saying 'Unable to open file. File is not a valid DNG file.'
It did work with a single shot photo, but as pixel shifting does increase the photo's color accuracy I figured it would be best to base the profile on a pixel shift photo as well.
Has anybody tried this as well? Perhaps the 240MP files are too much to chew on for the app?
 Jojakim's gear list:Jojakim's gear list
Sony a7R IV
Sony a7R
VLreviews
VLreviews Regular Member • Posts: 237
Re: Color calibrating pixel shift images from A7RIV
Have you tried to convert the files to DNG using pixelshift2dng?
https://www.fastrawviewer.com/PixelShift2DNG
It might produce different output than the Sony converter. Maybe those DNGs then work with your tool.
http://vintagelensreviews.com/
Reviews of vintage Minolta SR mount lenses and more
OP Jojakim Contributing Member • Posts: 538
Thanks for the suggestion. But unfortunately I get the same error message with this DNG.
Sony a7R IV
Entropy512 Veteran Member • Posts: 4,875
I gave up on the ColorChecker app in favor of https://rawpedia.rawtherapee.com/How_to_create_DCP_color_profiles - the latter produces a better profile (more advanced than just two ColorMatrix entries, but additional LookTable color corrections) and also allows you to distortion correct the image (not super necessary for an A7-family camera, but was critical for a 360 camera with dual fisheye lenses)
Note that there are eventually going to be some enhancements to that workflow when I get more time to work on https://github.com/Beep6581/RawTherapee/issues/5575
Also, the A7R4's dynamic range is sufficient that you'll get little to no benefit from trying to make a color profile from a pixel shift image
Context is key. If I have quoted someone else's post when replying, please do not reply to something I say without reading text that I have quoted, and understanding the reason the quote function exists.
 Entropy512's gear list:Entropy512's gear list
Sony a6000 Pentax K-5 Pentax K-01 Sony a6300 Canon EF 85mm F1.8 USM +5 more
Thanks so much for the hands on info.
I'm going to check out the RawTherapee profiling for sure.
Sony a7R IV
Iliah Borg Forum Pro • Posts: 28,006
ColorChecker doesn't have enough dynamic range for pixel shift to make a difference (given the target is exposed per X-Rite recommendations).
