Z6 snd STC 6 stop filter question
keano12
keano12 Regular Member • Posts: 466
I know in the Sony mirrorless you can change a setting to focus avoiding the dark filter. Can the same be done on the Z6?
thanks
Nikon Z6
Ernie Misner
Ernie Misner Veteran Member • Posts: 7,229
Re: Z6 snd STC 6 stop filter question
Do you mean that on the Sony, you can change a setting in the menu that will allow for better focusing in spite of having a dark ND filter on? If so, I think the Low Light setting on a Z6 would aid in focusing with a dark filter.
I have also found that focus peaking works good on a Z6 with a dark filter on which involves manual focusing.
thanks
Ernie Misner
http://www.flickr.com/photos/erniemisner/
The first digital image was made in the late '60's for NASA, as a way to record images of Mars. Each "square" was represented by three numbers, corresponding to the red, green, and blue hue on a scale of 0 to 255. This eliminated the need to ship film back to Earth.
 Ernie Misner's gear list:Ernie Misner's gear list
Nikon Z6 Nikon AF-S 70-200mm F2.8E FL ED VR Nikon Z 24-70mm F4 Nikon D810 Nikon AF-S Nikkor 24-70mm f/2.8G ED +6 more
