A Modest Proposal About X100-Series Cameras
Started Nov 23, 2020 | Discussions
robnich
robnich Contributing Member • Posts: 767
5
I believe there must be many owners of Fujifilm X100-series cameras who might like to see a separate forum for these cameras. I am probably not alone in having selected my current X100V and my previous X100S specifically because I was tired of carrying around what I often referred to a one metric ton of lenses and accessories in my days as a Canon beast-of-burden. I welcomed the challenge of using a light, beautiful and capable fixed lens camera of high quality.
In the current forum, X100-series camera posts are buried in an avalanche of DSLR and lens posts and are a bit hard to locate. Search by Product simply does not work, usually coming up with only a very few posts that are not days or even weeks old, even for "hot" recent cameras such as the X100V.
Anyone else who has had these thoughts?
Robert N.
 robnich's gear list:robnich's gear list
Panasonic FZ1000 Fujifilm X100V Canon Pixma Pro-100
Fujifilm X100S
Erik Baumgartner Senior Member • Posts: 6,894
Re: A Modest Proposal About X100-Series Cameras
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 19,920
5
In the current forum, X-series camera posts are buried in an avalanche of DSLR and lens posts and are a bit hard to locate. Search by Product simply does not work, usually coming up with only a very few posts that are not days or even weeks old, even for "hot" recent cameras such as the X100V.
Robert N.
Just to be clear, Fuji’s crop line contains X-series cameras, as in X-H1, X-T4, etc., all of which are represented within this forum. The notable exception is the MF line, which is not a part of the charter for this particular discussion group within DPR and is arguably a different class of products. The X-H1, X-Tn lines, etc. are not defined as DSLRs. Bottom line, I believe DPR is not particularly interested in proliferating more specialized forums, thus generating potentially a host of new forums (since a similar request could easily apply to smaller groups of products within other brands as well).
So, I wouldn’t personally be particularly supportive of this request and I seriously doubt that DPR would be inclined to further break up this forum. Just my opinion... not speaking for DPR here.
Jerry-Astro
Fujifilm X Forum Co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 XF 150-600mm Canon Pixma Pro-100 +1 more
robnich
OP robnich Contributing Member • Posts: 767
Yes, you're right, a sloppy error on my part -- I should have written interchangeable lens cameras.
Robert N.
biza43 Forum Pro • Posts: 15,074
Truth be told, the X100 discussion should be in the Finepix forum, since the official name of the camera is "Finepix". Just saying...
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
jaberg
jaberg Senior Member • Posts: 1,037
Fujifilm USA doesn’t categorize or identify the X100V as a “Finepix” model, nor do I find any such reference on the camera or in the camera manual. The “100” is clearly associated with the X Series.
I wouldn’t mind seeing the X “premium compact’ cameras broken off into their own forum section because so much of the conversation here pertains to lenses I can’t (yet?) use. However, I can understand DPRs reluctance to micro-categorize the forums.
 jaberg's gear list:jaberg's gear list
Fujifilm X100V Fujifilm X-S10 Nikon AF Nikkor 85mm f/1.8D Fujifilm XF 16-80mm F4 Fujifilm XF 70-300 F4-5.6 R LM OIS WR +3 more
DarnGoodPhotos Forum Pro • Posts: 11,881
The first X100 was called a Finepix because there was not X-Mount system then.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
Robert N.
I would agree if the X100V were fundamentally different, but many questions about the X-Pro3, for example, are applicable to the X100V.
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,432
In the meanwhile. . .
It might not be quite as fulfilling as having it's own forum, but have you tried the Filter By Product forum feature?
"Well, sometimes the magic works. . . Sometimes, it doesn't."
------ Chief Dan George, Little Big Man
@ bobtullis.com & flickr.com/photos/bobtullis
My opinions are my own and not those of DPR or its administration.
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
robert1955 Veteran Member • Posts: 7,302
Re: In the meanwhile. . .
I may not have done it like it should be done [first time I used it], but it seems there is no way to filter all X100 models in one go?
Add the cameras you want to the filter url.
https://www.dpreview.com/forums/1020?view=list&products=fujifilm_x100,fujifilm_x100s,fujifilm_x100t,fujifilm_x100f,fujifilm_x100v
jaberg
Thanks for that. I’d forgotten (if in fact I’d ever known). To re-establish a modicum of Fuji cred I’ll state that my S2 is a Finepix.
Indeed, only the original X100 was a Finepix.
Bobo Hodls
Indeed - and then one can save that as a browser bookmark for returnable convenience.
Ed B
Ed B Forum Pro • Posts: 12,575
There was a big push recently for DPR to start a forum for fixed prime lens camera that would have, naturally, included the X100 series along with other cameras like the Sony RX1 series, Leica Q, Ricoh GR series, and others that would even include older cameras like the Nikon Coolpix A.
I think the original thread was posted in the Sony forum and there was also a thread posted in the Site Feedback and Help forum.
Long story short is that after more than 140 comments every one supported the idea with the exception of one or two Mods.
DPR never responded and for the most part, the idea/suggestion was ignored.
Two things were obvious from these threads.
First, some mods didn't like the possibility that their precious forums might lose traffic because these cameras were being talked about in another forum.
Second, it proved, without a doubt, that DPR doesn't care one bit about what their forum members want.
Such is life.
surfoxy
surfoxy Contributing Member • Posts: 936
Robert N.
I think it's a great idea. I don't buy the "forum proliferation" argument, as forums only proliferate as camera types do. While this is obviously an X series camera with it's sensor and construction, the fixed-lens premium camera also obviously a very cool, very popular and very discussable niche.
If it's not up to the mods, I wonder how such a change would be proposed to the forum runners. Whoever they might be...
This can't be a static thing, new cameras and new lines come out all the time. Someone's paying attention.
Chris
 surfoxy's gear list:surfoxy's gear list
Fujifilm X100V Sony a9 II Sony FE 100-400mm F4.5-5.6 Sony FE 16-35mm F2.8 Sigma 85mm F1.4 DG GN +2 more
jaberg
I’m going to toss in my rather jaded view that a forum dedicated to the X100 (or even to premium compact cameras as a whole) is just another place for people to swing by and tell the fans and users of those cameras why they’re doing it wrong.
This is just off the top of my head from this mornings readings (here and elsewhere)
Leica Q2 Monochrom — Why would anybody want one when they could use [camera] and [software] to make better monochrome images. Leicas are just status symbols anyway.
iPhone 12 Max — my [phone, or camera, often full frame] takes better images. I’ll bet you won’t find professionals shooting the olympics using their phones. (Yes, that last one is real.)
Apple ProRAW — It’s not real raw. And… and… Android did it first. Plus my [real camera] does it better.
Apple M1 Chip — I bet it won’t run [obscure specialized software] plus this [workstation chip] is faster. Why did Apple bother. (Seriously, I wonder if the engineers there sometimes ask themselves this very question.)
To be clear I don’t object to, and even enjoy, honest debate. It’s the whataboutism and I have to impose my thoughts on everythingism that gets to me.
The Internet. Raining on parades since—USENET. I’ve started to become what I detest: An old (56) man shouting at The Cloud.
/rant off.
Back to x100 cameras. Which I’m happy to discuss, even debate, here there or anywhere.
Jerry-astro
Such is life.
I won’t try to speak for other Mods here... this is just my own view of your comments.  First of all, just because DPR disagrees with a suggestion in no way suggests that they don’t care about what forum members want.  Proliferating specialized forums is something that needs to be carefully considered, and simply because a group (even 140) of DPR members wants to see something like this does not necessarily mean that it’s a no brainer to make it happen or that it even makes sense when considering the broader range of forums that DPR already has.  What’s more, you seem to assume that individual Mods have a strong say in this.  Decisions like this one are made by DPR staff, not Mods.  Individual Mods might have opinions, but we have little more say in the process than DPR members do.  Your suggestion that a Mod might oppose this idea because of a loss of traffic in their forums is also simply ridiculous.  We don’t get measured on volumes of posts.
So, bottom line, I’m sorry that you didn’t achieve what you wanted, and I’m sure you’re looking for people to blame for this.  Consider the possibility that your idea was considered but didn’t work within the framework that DPR has in mind for their forums.  In other words, just because a group of forum members agrees on a direction does not necessarily mean that it fits well with DPR’s plans for forum organization or that it’s necessarily the right thing to do.  As you said, such is life.
Jerry-Astro
robnich
As I mentioned in my original post I have found that searching (filtering) by product is not effective, as it yields only a very few posts and misses many. For example, my post on this topic is not found by entering X100V or X100. Apparently the Filter by Product only works if a tag for the product is selected.
Robert N.
Don Davis
Don Davis Contributing Member • Posts: 902
Just my personal opinion, but I like having all the X100 series and the X-mount interchangeable lens cameras in one forum. I use a couple of different x-mount bodies in addition to the X100's, and I like to scan one place for news, info, and opinions. It would not be a disaster if they were separated, but it wouldn't be a benefit either.
 Don Davis's gear list:Don Davis's gear list
Fujifilm X100F Sony RX100 VII Fujifilm X100V Nikon D700 Fujifilm X-T2 +1 more
