MOOnRAKER IS BACK : MOON TONIGHT
Started 5 months ago | Photos
baobob
baobob Forum Pro • Posts: 15,779
10
Sony RX100 Olympus Tough TG-4 Panasonic ZS200 Fujifilm X-H1 Fujifilm X-T3 +10 more
BurmaRoad Junior Member • Posts: 47
Re: MOOnRAKER IS BACK : MOON TONIGHT
So what's the full process here? Surely it can't be as easy as mounting the 100-400mm with a 1.4x and firing off a shot.... can it?
baobob
OP baobob Forum Pro • Posts: 15,779
Nearly as easy. In PS first adjusting shrpening then using the ACR filter adjusting white and highlights then using Viveza Nik collection plug in adding contrast and structure all that in less than 5 mn
The key of success relies essentially on the atmosphere that should be absolutely clear
jhorse Veteran Member • Posts: 4,655
Hi, always love seeing your moon shots.  By atmosphere I assume you mean not only a haze free and cloudless sky, but also as little light light pollution (from towns or cities) as possible.
 jhorse's gear list:jhorse's gear list
Fujifilm X-E3 Fujifilm X-T4 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +6 more
baobob
Exxactly what english word you would use instead of atmosphere ? thx
