GR III flashing green light. Frozen
Kuromusha Regular Member • Posts: 151
has this happened to anyone here. I turned my gr off right after take a photo (prob during writing process) and this happened.
https://www.youtube.com/watch?v=BRImmLdzBkM
Ricoh GR III
telemach Contributing Member • Posts: 641
Re: GR III flashing green light. Frozen
looks like problem with writing to SD card, if card is not right formatted or slow this might happen
altis Senior Member • Posts: 1,029
...or overheating. I've had this happen soon after charging a battery in-camera. I just took the battery out in the end.
maltmoose Senior Member • Posts: 2,031
I saw it once, i think your right it might be due to being switched off whilst writing to card. Ive not been able to replicate it though. never a good idea switch off camera whilst lens is extending, retracting or card writing on any camera really.
sprocket-docket Regular Member • Posts: 236
I've had it happen a couple times when using a slower SD card. Taking the battery out and putting it back in fixed it, and it hasn't happened since I switched to a better card.
 sprocket-docket's gear list:sprocket-docket's gear list
Ricoh GR III Panasonic Lumix DMC-GF7 Pentax KP +2 more
OP Kuromusha Regular Member • Posts: 151
Well I just got a faster card. Did it make any difference?
https://youtu.be/_vNGEfzFpqQ
The GR3 only supports UHS-I so there's no point in using a UHS-II card or better.. The UHS-II interface has more connections that that the GR3 cannot use.
https://en.wikipedia.org/wiki/SD_card#Bus
To find the fastest UHS-I card look at the table some way down this page:
https://havecamerawilltravel.com/photographer/fastest-microsd-cards/
sturgeon Junior Member • Posts: 35
Not sure why you'd want a microsd card. I've had very good results in all kinds of cameras, including GR3, with this card ...
https://www.bhphotovideo.com/c/product/1431033-REG/sandisk_sdsdxxy_064g_gn4in_extremepro_sdxc_64gb_card.html
SUPER-ELMAR
SUPER-ELMAR Regular Member • Posts: 144
Need to wait a few seconds to power down after you take a shot.  Battery life isn't so bad you have to push the shutter and power button in rapid sequence
 SUPER-ELMAR's gear list:SUPER-ELMAR's gear list
Ricoh GR III Leica M10 Olympus OM-D E-M1X Hasselblad X1D II 50C Leica Noctilux-M 50mm f/0.95 ASPH +5 more
fujiandme New Member • Posts: 3
Looks like A card issue, try reformating the card.
