Will the X-E4 have IBIS?
Started Nov 21, 2020 | Polls
Keithpictures
Keithpictures Contributing Member • Posts: 832
A simple yes or no. Obviously a guess or a bet, since none of us actually know at this point.
 Keithpictures's gear list:Keithpictures's gear list
Leica C-Lux Fujifilm X100V Apple iPhone 13 Pro
POLL
Yes. (The technology has shrunk substantially - it can shrink again, or fit in as is with minimal effect on body size / It's Fuji's new thing and they'll put in anything they can / It's the main reason they're updating the line / etc)
53.1% 76  votes
No. (It can't fit, even if the X-S10's core body is barely any bigger / It's not worth the price to add it to this lower end camera / It's a gimmicky feature that goes against the ethos of this line / etc)
46.9% 67  votes
  Show results
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,432
I never respond to polls that don't offer. . .
9
  • Definitely Maybe
Sorry, it's just a policy of mine.
"Well, sometimes the magic works. . . Sometimes, it doesn't."
------ Chief Dan George, Little Big Man
@ bobtullis.com & flickr.com/photos/bobtullis
My opinions are my own and not those of DPR or its administration.
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
Eulan13 Regular Member • Posts: 150
Re: Will the X-E4 have IBIS?
I would say yes, but assuming that the body would be slighty bigger than the X-E3, and this might turn out to be an advantage.
 Eulan13's gear list:Eulan13's gear list
Sony a7 III Sony FE 85mm F1.8 Sony FE 24-105mm F4 Tamron 70-300 F4.5-6.3 Di RXD III Sony FE 40mm F2.5 G
io_bg
io_bg Senior Member • Posts: 1,548
I don't think it'll have IBIS. From a technical point of view it's probably possible although I doubt Fuji will put IBIS in the X-E4, it'll go against the 'minimalist' philosophy the X-E3 offered.
 io_bg's gear list:io_bg's gear list
Fujifilm X-T30 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS +4 more
holashobby Senior Member • Posts: 1,663
7
In current  mirrorless market, there is no room for a non-IBIS camera.
 holashobby's gear list:holashobby's gear list
Fujifilm X-T4 Panasonic Lumix DC-S5 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm 15-45mm F3.5-5.6 OIS PZ +4 more
roberthd12 Contributing Member • Posts: 872
Agreed. Not having IBIS will lessen the # of sales. Even my iPhone has stabilization.
 roberthd12's gear list:roberthd12's gear list
Fujifilm X100F Fujifilm X100V Olympus PEN E-PL1 Fujifilm X-Pro1 Fujifilm X-T1 +12 more
ragbasti Regular Member • Posts: 321
My gut says no, simply because of how the X-S1 is set up.
They added a big grip that could hold the battery, likely to make space for the IBIS and cooling necessary.
Now my hope is that they'll keep any video features to an absolute minimum on the X-E4 and make it happen that way, though it's not likely.
If you want to experience the Dunning-Kruger effect first hand, then just join a forum debate about photography.
 ragbasti's gear list:ragbasti's gear list
Fujifilm X-T2 Fujifilm X-T5 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS +2 more
zakaria
zakaria Veteran Member • Posts: 6,556
5
should be STANDARD for X mount today .
pentaxian .
 zakaria's gear list:zakaria's gear list
Fujifilm X-H1 Pentax K-1 II Fujifilm X-T3 Nikon D780 Pentax smc FA 31mm F1.8 AL Limited +8 more
SpeedyNeo
SpeedyNeo Senior Member • Posts: 1,055
No.
Not before the X-Pro4 and X100VI at least.
Fujifilm X-T3 | XF16mmF1.4 | XF35mmF1.4 | XF90mmF2 | Fujifilm X100V | Fujifilm FinePix XP140
 SpeedyNeo's gear list:SpeedyNeo's gear list
Fujifilm XP130 Fujifilm X100V Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 16mm F1.4 R WR +1 more
Truman Prevatt
Truman Prevatt Forum Pro • Posts: 14,596
If you notice the S10 - the battery is in the large grip.  I suspect that the need for the grip is so they could free up the space for the IBIS unit.  I sure don't see the X-E series being the X-E series with such a grip.
So I would say no.
_____
"The winds of heaven is that which blows between a horse's ears," Arabic Proverb
__
Truman
www.pbase.com/tprevatt
 Truman Prevatt's gear list:Truman Prevatt's gear list
Leica Q2 Monochrom Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 +12 more
sergiotous
sergiotous Regular Member • Posts: 136
IS and an articulated screen like the one x100v has would make xe4 a great selling product as long as size and weight does not increase more than 50g and price is kept under USD/EUR 1000.
 sergiotous's gear list:sergiotous's gear list
Canon EOS 6D Fujifilm X-E3 Canon EF 24-70mm F4L IS USM Sigma 50mm F1.4 DG HSM | A Samyang 12mm F2.0 NCS CS +3 more
enigmatico Contributing Member • Posts: 548
So I would say no.
I agree that the X-E4 would look odd with a large grip and it’s unlikely to get IBIS anyway. At the same time, Fuji has invested a lot of R&D time to figure out how to miniaturise IBIS and make it so effective. So they will be wanting to maximise their returns on it.
I can live without a flip screen, but an X-E4 with IBIS and a slightly better EVF + eyecup, would be an instant hit with me, even if it meant a slight increase in size.
 enigmatico's gear list:enigmatico's gear list
Leica Q2 Fujifilm X-T1 Leica SL (Typ 601) Fujifilm GFX 50R Panasonic S1 +8 more
forest dream Senior Member • Posts: 2,796
Market Segmentation
Agree. Technical is possible but market segmentation ....
If X-E4 has IBIS, X-S10 selling will drop very fast.
Other possiblity (but Fujiflm didn't do): X100V with lens IS.
Re: Market Segmentation
I think it has becoming an expectation that all cameras have some form of image stabilization. Plus, a minimalist camera can have image stabilization. Ricoh GRIII, right?
Agree that all mid-range / high-end camera except (price like Canon M50 now) should has image stabilization, dual card slot and simple WR (not IP rating).
Above item is not any technical issue (especially dual card slot & WR is simple tech and low cost) but just camera maker marketing segmentation.
IMO dual card slot more important than HDMI slot in camera.
For WR (not IP rating and without any guarantee) in camera body, it just few simple rubber sealing. I still remember OnePlus 6 (phone) provide water-resistant in low price (because not IP67).
John Gellings
John Gellings Veteran Member • Posts: 9,741
SpeedyNeo wrote:
No.
Exactly....
https://www.johngellings.com
Instagram = @johngellings0 and @nycrandomjg
 John Gellings's gear list:John Gellings's gear list
Ricoh GR IIIx Fujifilm X-E1 Leica M Typ 240 Fujifilm GFX 50R Fujifilm X-Pro3 +6 more
John Gellings wrote:
SpeedyNeo wrote:
No.
Exactly....
But the X-S10 was released before the X-Pro4 and X100VI ????   And that IBIS is quite a game changer. I have an X100V and now a brand new X-S10. I do a lot of night street photography and its going to be very tempting to take the X-S10 with me over the X100V, given that I can shoot at 1/15th sec. with complete confidence.
It effectively means that as long as I don't have a moving subject, I can set my X-S10 to ISO 1600 instead of ISO6400 (X-100V) and take advantage of the significant difference in IQ.
You guys are probably right and the X-E4 is unlikely to have IBIS before some of the more upmarket models get fitted with it, but you never know. The Fuji roadmap isn't always logical in that way.
9VIII Senior Member • Posts: 1,331
IBIS is the only significant feature missing from the X-E3.
 9VIII's gear list:9VIII's gear list
Canon EOS 1100D Fujifilm X-E2S Fujifilm X-E3 Canon EF 400mm f/5.6L USM Sigma 150mm F2.8 EX DG Macro HSM +7 more
5
Plus a larger EVF with a more comfortable eyecup. 😉
007peter
007peter Forum Pro • Posts: 12,933
IBIS would be NICE (but) realistically NO in that Tiny SIZE
I want IBIS, I want an updated Fuji X-E3 (but)
  • given the SIZE restrain of the E3 body
  • given that Tiny Size = the appeal of the E3 range finder
  • I don't realistically, think we'll get an IBIS.
  • I hope I'm wrong, but its already looking like a very TIGHT squeeze
Even @the reduce IBIS unit size of X-S10 is quite THICK. cramping that into a tiny E3 body maybe asking for trouble. An undesirable compromised must be make:
  • Either by Making the X-E4 SIZE BIGGER & THICKER
  • thus reduce the appeal of E series (why buy one if its THICK?)
  • or take out the IBIS and remain small.
  • Choose your Poison
Another problem is HEAT!  Cramping a constantly moving IBIS unit into a tight cramp space will generate a lot of heat.  It'll even limit the 1080p video ability, 4K maybe in the range of 10~15min as well.  Just a thought to consider.
Lastly, @what price are you willing to pay for E4?
  • are you willing to pay the same $999?
  • because cramping an IBIS will add cost, & price it similar to X-S10!
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic 20mm F1.7 II
