Polarizing Filters
Started Nov 20, 2020 | Discussions
manual_focus Senior Member • Posts: 1,515
Polarizing Filters
I've been out shooting church steeples which generally require shooting on blue sky days to better enhance the contrast between the steeple and the sky. As part of my setup I tried shooting with and without a circular polarizing filter. When shooting with the sun behind you (therefore direct reflected light from the objects) I found the differences remarkable. Much more so than when shooting into the shadows.
To see what the differences were I shot two scenes with and without a CPL. In post, I saw that the CPL (while noted for being neutral), still gave a bit of red color cast which accounted for some of the differences. I therefore picked a bright white surface and changed the Color Temperature so it was "white" and close to each other. I needed very little change without the CPL (5115 to 5150 degrees Kelvin-oK) but a bit more with the CPL (5369 to 5000 oK). Everything else in post was the same between the two images.
One additional note is that while the camera settings were the same, the shutter speed was two full stops difference (1/1600 sec vs 1/400 sec) without and with the filter. The CPL is removing a lot of polarized light which accounts for the differences. To my eye the CPL increases contrast and clarity (and deeper/truer colors) of the steeples.
Still haven't decided which way I'll go.
Enjoy.
Best at "original size" I used the left white column as my reference point (i.e., they are the close to the same in each image) with everything else relative to that point. Therefore, the only difference is I've removed 2 stops of polarized light. The sky is the most dramatic change.
kypfer Contributing Member • Posts: 985
Re: Polarizing Filters
Just remember you don't need to use the polariser at "full" setting, often a "half-way there" can give a pleasing contrast without "over-cooking" it … well worth taking two or three shots at slightly differing degrees of filtration then assessing the results when you get home. Just make a few notes as you go, the filter settings aren't recorded in EXIF
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
Hythloday Senior Member • Posts: 2,349
I always leave my Hoya Fusion antistatic on my lenses, because contrast is enhanced.
PeterPentax
PeterPentax Senior Member • Posts: 1,131
CPL's darken the light from an image. Due to their nature, they darken polarised light more than non-polarised light.
You need to take this into account when you use CPL filters. Your shots with the filter look under-exposed to me.
SlamDesi Regular Member • Posts: 179
I'm will Peter on this one. I used to slap a polarizer on quite a bit but, I find 'em to make the sky unnaturally dark. With software, one can tweak that in a bit if necessary anyway. I find them more useful in adjusting the reflections on water. I have a couple of different CPLs and they're a lot different in the variance of effect and how subtly you can apply it. Thanks for posting it, Manual.
flektogon
flektogon Veteran Member • Posts: 6,226
I would say that such a polarizer filter makes sense to use on the sky with clouds only. And to remove reflections of course.
Peter
DougOB
DougOB Veteran Member • Posts: 3,176
This is one of those basic pieces of advice that, duh, I never thought of.  Now is my memory good enough to put it into practice...
Thanks,
Doug
 DougOB's gear list:DougOB's gear list
Ricoh GR IIIx Pentax K-3 Pentax Q-S1 Pentax K-70 Pentax KP +36 more
OP manual_focus Senior Member • Posts: 1,515
Something to work at as I can easily tell when the filter is at full polarization, but not so much as to a what point is it best.
Good advice, Thanks.
Nice clouds.
MightyMike Forum Pro • Posts: 41,691
Excellent examples, Polarizers although not necessary all the time are an excellent and useful tool in photography. I'd suggest worth having in anyone's kit.
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/user/SpeEedy/profile/photos?sortBy=photoFavoriteCount
Yes, the CPL reduces the amount of light getting to the sensor because it is not clear glass and because it blocks light of a particular polarization. With my CPL I needed to increase the amount of light to the sensor by four fold (2 stops). Your description of a CPL may need some more thought. See: https://en.wikipedia.org/wiki/Polarizer#Circular_polarizers
Interesting as to your comment that the filtered images (on the left) look under-exposed.
I disagree, the pictures on the left look decently exposed, the effect makes them appear a bit darker but check the whites, they're still exposed ideally.
Mike from Canada
Like you, I have found a lot of differences in degree of effect from different polarize filter manufacturers. It's one of the reasons I like the current CPLs I use. It has a strong and very rapid response to reflected light. It's easy to find maximum polarization effect. Although I must say, I see the potential benefit of finding some balance between full and non.
The big issue with CPLs is how they darken the sky. You can get it to go black under the right conditions. If you are looking for "naturalness", this is a problem.
Outside of the sky, to my eye, it is the increased contrast and clarity that is most intriguing. The elimination of all that reflected light makes increases contrast, sharpens the edges, colors a bit deeper, leaves more pronounced, etc. Can you dial down the blue sky effect and still get the pop for the polarization effect? I'm willing to find out.
Personally, I don't mind the dark sky. In this context I'm trying to show the power of the steeple in getting people to see the church. A dark featureless sky makes the steeple front and center.
Who am I to argue? I can say this. The highlights would blow out with a longer exposure. Take a look, I used multi-pattern metering and still had to dial it down -1.0 to -1.3 eV. so as to not blow the highlights (white columns) out. The RGB luminous values for the columns are around 240s. It is not under-exposed.
Thanks,
Doug
Exactly.
Re: Polarizing Filters (DA* 50-135mm w/ K3-2)
Thanks for all the comments. Good discussion.
As an adjunct to my original post. Here is a full size image showing what the DA*50-135mm with the K3-2 can do. Based on my experience you could get a bit more detail if I had set it up on a tripod and used Pixel Shift. Another day.
Enjoy!
Impressive.
There seems to be a difference between CPLs:
https://www.lenstip.com/139.25-article-Polarizing_filters_test_2015_Results_and_summary.html
Many years ago I bought a B&W CPL, which I hardly used. Oiche mentioned the Hoya Fusion Antistatic CIR-PL, which I bought this year. I am quite happy using it.
tex Veteran Member • Posts: 8,945
I used polarizers a lot in film days. No more
In 2005 after a trip to Turkey, where i used a polarizer quite a bit, I saw the results and decided that with digital my needs had changed.
I only use them now to control reflections, mostly in my work shooting museum collections and exhibitions---still need them for that.  For skies? Not at all.
BTW, if you do need them, check out Breakthrough filters . U.S. made, and Jim Kasson feels like they are the most neutral filters available.  They also make ND filters.  be sure to scroll down on the splash page, or just hit the products from the menu tab.
tex_andrews, Andrews Fine Arts LLC, shooting professionally for mid-Atlantic U.S. museums with Pentax and Ricoh equipment, and occasionally Canon for video. Co-founder and webmaster of The LightZone Project, an all-volunteer group providing the free and open source LightZone photo editing software. Moderator at The Pentax Forums dot com
"Photography is the product of complete alienation" Marcel Proust
"I would like to see photography make people despise painting until something else will make photography unbearable." Marcel Duchamp
 tex's gear list:tex's gear list
Pentax 645Z Pentax K-1 Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 77mm 1.8 Limited +30 more
flektogon
Re: I used polarizers a lot in film days. No more
This is exactly my finding. While I used it on my film cameras almost permanently, the digital files can be so flexibly post-processed, that I don't find any reason for the polarizer. Except to control reflections.
Peter
DougOB
Which B+W CPL is it?  CPL's are the only filters I have and I had settled on B+W Kaesemann filters, so just curious.
Personally I prefer the result using a CPL to darken the sky vs postprocessing, but maybe I am just crap at postprocessing
Doug
