Focus PULL on G80, GH5 kit 12-60mm possible?
Started Nov 18, 2020 | Discussions
HRPOWER Regular Member • Posts: 159
I have a Canon which does really DEEP focus pulls in manual mode. I love it.
My G7 Does not do that at all - would the GH5 with 12 - 60 do the same job or is this focus pull element something more to do with DSLR vs Mirrorless?
The Canon is a 700d with the 18-55 Kit lens - I can't use it for much because its not 4k but its really full and almost 3d in its quality...
Help would be much appreciated.
Canon EOS 700D (EOS Rebel T5i / EOS Kiss X7i) Panasonic G85 Panasonic GH5 Panasonic Lumix DMC-G7
john isaacs Veteran Member • Posts: 8,444
Re: Focus PULL on G80, GH5 kit 12-60mm possible?
The GH5 has an autofocus pull feature.  I don't have a GH5, so I can't speak to it's effectiveness.
In general, focus pulling works with lenses that have a repeatable manual focus mechanism, generally indicated by the existence of a focus distance scale on the lens.
Most "focus by wire" lenses include an acceleration component that changes the scale based upon the speed you rotate the focus ring; this makes them generally non-repeatable.
All of the Panasonic lenses I have (I don't have the 12-60) are "focus by wire" and not suitable for focus pulling.  If I'm going to pull focus, I use lenses with repeatable manual focus: third party manual focus lenses, adapted Nikon AF D lenses, and Olympus lenses that have the manual focus clutch (generally the PRO lenses).  The disadvantage of m43 is that some of the lenses are really too small to put on a follow focus ring (like the Loawa lenses, and the Olympus 12mm and 17mm).
Interceptor121 Veteran Member • Posts: 8,691
The focus pull feature of the GH5 requires setting up given points and the speed of the transition afterwards it works quite well however even without this feature you can pretty easily do it with focus by wire s long as the lens does not go crazy when you turn (the leica don't but lumix do) and you can even use the joystick and AF-ON if you set your AF speed to slow
If you are not happy with that buy a voigtlander it has a 270 degrees run from 0 to infinity
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
OP HRPOWER Regular Member • Posts: 159
Ok - so its all about the lens right?
In simple man terms - what do I need?
xx
(unknown member) Contributing Member • Posts: 726
xx
Anything old (or new) lens with basic mechanical focus. Electronic “focus by wire” lens focus is not reliably repeatable. Exception is GH5 that has a feature to “program” up to 3 focus points.
larsbc Forum Pro • Posts: 18,282
What is a "deep" focus pull?
I noticed you didn't mention the G80 in your question but you did in the topic title. The G80 has a Snap Movie mode which has a focus pull option.
https://www.youtube.com/watch?v=rdt6Q50Rv2o&ab_channel=PhotoJoseph
I think the GH5 has an even better, less limited focus pull option.
ooo that is good.
