What would you use or what do you use
Started Nov 14, 2020 | Discussions
Tom Schum
Tom Schum Forum Pro • Posts: 13,282
Re: What would you use or what do you use
PT wrote:
I have a feeling my Sigma gear may need a new home soon.
Still, Sigma is entirely unique.  This is why I'm keeping my sd Quattro and dp0q.  This is why I'm looking forward to see if and when Sigma will produce a new Foveon.
Yes, I use my other cameras and my Sigmas basically live in a drawer, but visually the Sigmas are unique so I keep them.
Tom Schum
Copper: Mankind's favorite electrical conductor
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
OP Roger Veteran Member • Posts: 3,293
Why can't I/we let go??
Greetings and Thank you all for responding to my question.
Another question, why can't we let go of our Sigma gear? I do have two SD15 and two SD14 one new, one I use, so I have back up for the 14 and 15. I have SDQ a SDQ-H although the H is giving a lot of noise in the shadow area on and off, I believe it's from heat build up, I've used it hard, at times it shut itself off, more than once.
I love my Sigma's/Foveon, but it's gotten to the point I won't take them out in bad weather or if I think they'll get destroyed or stolen while on a job. I just sold my last Nikon out of 22 bodies, and it had 425,786 actions on the shutter and I've put my NPS into retirement status, the point is you ask? My SD14, SD15, DP1, DP2 were with me the whole time.  My SD1(it was the original) had to many focusing issues to go along, although I sent it in 4 times to be checked here in the USA. One went to Japan and it took 12 weeks to get back. From what I understand there are no parts for the DP's, SD9 thru the SD1 even in Japan. Or so I was told. At this time I've decided to shoot my two Olympus E-M1 with the 12-40 pro and 40-150 Pro BUT not to worry my Sigma SD15 and SDQ-H will be with me, if they break from rain, snow or desert sand so be it. The biggest problem here in the USA are the people that are anti media, the Sigma's are big making it harder to work, to do photojournalist. The question still stands, why can't I sell of more of my Sigma's? I need to let go of 2 bodies 3 lenses and not buy any more, I have to much.  The Art lenses are way to big for what I do, and I own two. I need small and fast, but I need/want the IQ of the Foveon. Oh well, it will all work out for the best. I hope the new company for Olympus, JLP will keep the brand going.
I'm looking forward to the new Sigma FF. I hope we see it.
Thank you
Roger J.
Scottelly
Scottelly Forum Pro • Posts: 18,026
digi2ap wrote:
I would use ~ Panasonic S5 and Sigma SA to L mount adaptor.
I thought that was a 24 MP camera, which would just not be enough to please someone used to a Merrill or a Quattro, like Roger.
Scott Barton Kennelly
https://www.bigprintphotos.com/
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
Scottelly
Re: Why can't I/we let go??
What is your biggest and heaviest Art lens Roger? Mine is the 14-24mm f2.8, but I rarely use it. I miss it when I need it, and I don't have it though.
Dryce Contributing Member • Posts: 598
I think when the DPMs came out most other cameras had AA filters.
That helped give the Merrill APS-C sensor an edge right up to 30Mp equivalent back in 2012 and some time after.
The DPM lenses are also sharp. That emphasises the performance of their sensor.
I have an X-H1 (24Mp) and X-T30 (26Mp) and using them with the Fuji 16mm F1.4 and 56mm F1.2 comes close to matching the DPMs in terms of pixel peeping. The Fujis win on low contrast and shadow colour - but the DPMs still manage to look a bit better on some texture and (subject to your taste) the skies.
The DPMs win on size and weight. The Fujis win on flexibility and ISO.
DPQ something more mixed. It doesn't have the outright consistent resolution of the DPMs - but with the right subject is impressive. But the DPQ is heavier and physically larger than a DPM.
 Dryce's gear list:Dryce's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp0 Quattro Sony Alpha DSLR-A700 +3 more
Hi Scott
Hope you are well. It's the 24-35 f2 Art. I don't know why I have it, the focal length isn't long or wide enough for me, but it is crazy sharp wide open at F2. The lens weights 2.75 USA pounds. or .928 KG so it's heavy and has no tripod mount
Stay safe
Roger J.
Johan Borg Veteran Member • Posts: 3,433
This is a good observation, as the Sigma fp can deliver a lot of per-pixel detail. The side effect is of course color moiré, which turns up far more often than I expected. Looking forward to that full frame Foveon
In an ideal world, CFA based sensors should take the consequence of this and combine an AA filter with oversampling, but instead we get concepts like Quad Bayer and Nonacell that optimize for processing speed over artifacts even as the pixel count is extreme (108mp for the Samsung Nonacell).
 Johan Borg's gear list:Johan Borg's gear list
Sigma dp2 Quattro Sigma fp Sigma 45mm F2.8 DG DN
Tiffles Veteran Member • Posts: 5,044
I use a Sony RX1R .
It‘s relatively cheap and does the job. No issues or concerns
 Tiffles's gear list:Tiffles's gear list
Sigma DP1 Sigma DP1 Merrill Sony RX1R Kodak DCS Pro 14n Nikon D700 +7 more
