FYI pen f/12-45mm/photolab 4/nope
Started Nov 10, 2020 | Discussions
alan brown Contributing Member • Posts: 805
For some reason dxo does not have a profile for the pen f with the 12-45mm pro lens.  There are profiles for this lens with the ep5, em5ii, gx9, gx8, g85. and others.  I've requested that this combo be profiled.  Not sure that I have much hope, but maybe...
alan brown
Olympus PEN E-P5 Olympus PEN-F Panasonic G85 Panasonic Lumix DC-GX9 Panasonic Lumix DMC-GX8
Henry Richardson Forum Pro • Posts: 21,959
Re: FYI pen f/12-45mm/photolab 4/nope
From reading comments on this forum I have the impression it is the best m4/3 lens.  Could a profile really improve it?
Henry Richardson
http://www.bakubo.com
OP alan brown Contributing Member • Posts: 805
I can use camera raw, but the files from photolab 4 are a bit sharper.  I guess I'm a little puzzled why dxo has ignored this particular combo.
alan brown
I know it is annoying.  You can't use PL4 if there is no lens profile?  That is very surprising.
Henry Richardson
AlmostDoctor Senior Member • Posts: 1,257
On no that's devastating. I just ordered Pen-F to pair with 12-45
Edit: I have made that suggestion. I hope they add that profile.
 AlmostDoctor's gear list:AlmostDoctor's gear list
Panasonic Lumix DMC-GM1 Olympus PEN-F OM-1 Panasonic 20mm F1.7 II Panasonic Leica DG Summilux 15mm F1.7 ASPH +9 more
ecovilks Regular Member • Posts: 141
Does this mean even the simple lens corrections like lens distortion cannot be automatically corrected when using Pen-F and 12-45 with DxO? Or is this only going to affect "lens sharpness" module?
Felice62 Veteran Member • Posts: 5,079
Isn't the only 14-150 the best lens of the kit-bunch?
F
If only closed minds came with closed mouths..
 Felice62's gear list:Felice62's gear list
Olympus Stylus 1 Olympus Stylus Tough TG-850 iHS Olympus Tough TG-3 Panasonic ZS100 Olympus OM-D E-M5 +36 more
ivan bayu Regular Member • Posts: 380
Really?
F
The olumpus(es) or the tamron? Well, many said that the tamron is the best nicest for that range, and the olympus(es) are the last...
I'm afraid I don't know.  As soon as I discovered that the lens sharpness module was greyed out I didn't pursue any other corrections.  I immediately tried to find the profile and obviously I came up short.  Perhaps someone else could chime in here.  I think I'll put the lens on my em5ii because that camera and the 12-45mm pro play nicely together.
alan brown
Harold66
Harold66 Forum Pro • Posts: 12,002
Really?
I know it did not make sense to me either... but i think maybe he meant the best trans standard zoom for m4/3
i still don’t know if it is so , but at least it can be argued
H
FOLLOW me on IG @ledaylightstudio.
thedemandingtraveler.org
www.haroldglit.com
IG :thedemandingtraveler
 Harold66's gear list:Harold66's gear list
Sigma DP2 Merrill Ricoh GR II Panasonic Lumix DC-G9 Fujifilm GFX 50S II Panasonic 20mm F1.7 II +5 more
Tom899 Senior Member • Posts: 1,241
I have the same combo and have been bugging dxo to support it for months.
The Pen F and 12-45 is the perfect combo!
Hopefully we get enough requests in so they will.
-Tom
 Tom899's gear list:Tom899's gear list
OM-1 Sony RX100 VII Panasonic Lumix G Fisheye 8mm F3.5 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +18 more
