About extension Tubes
Started Nov 9, 2020 | Questions
Kleon Junior Member • Posts: 49
I'm a old Pentaxian since 1970, I did mani photos in dia, Bw and Color negatives.
I stopped to proiect dias and so I began to duplicate all of them.
With my K 20 I found that , with extension tube, was more simple and better than to use scanner, the only was the necessity to use a35 mm than a 50mm, cause the APS-C format of K20.
Now I finally bought a K1 ii and so I proved to make duplication with it and a smc 50mm; astonishing difference for color and all, but I relize that K1 made photos only at all open diafgram, whe I searced to stay at around f 11 for deep of field, only center in focus .
K1 and my tubes don't work together.
Thera are a lot extension tubes to sell, but I'm afraid to buy something with the same problem of mine; I need to use my 50mm all in manual.
If someone has an answer to this I'll appreciate very much!
Greetings from Italy.
Pentax K-1 Pentax K-1 II Sony SLT-A35
ozdean
ozdean Forum Pro • Posts: 28,665
Re: About extension Tubes
You need to set your K1 to work with the aperture ring on your smc 50
In the Custom menu 5 "Use Aperture Ring" Set to 2
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +14 more
OP Kleon Junior Member • Posts: 49
Leoni Fabio
Parma
Italia
I'm very glad to have an answer from you Ozdean that I read since so many years!
I already did for the ring and use all my objectivs without any problem, only when Itried to use the tube with K1 I had this problem, with K20 it was perfect. What I thik is that K1 could have a different way to function, for instance it wants only electronical abbination, but even this is questionable since I have Focal Duplicator and it works without any contacts.
Perhaps now my question is more intelligible, let's hope!
Holger Bargen Veteran Member • Posts: 4,911
There is just this thread about prbolems with extension tubes and problems with K3 in this forum:
https://www.dpreview.com/forums/post/64528788
Maybe you find the answer there. If they worked with K20 I see no reason why they shuld not work with K1. Did you allow the use of aperture ring in the menu setting?
Best regards
Holger
 Holger Bargen's gear list:Holger Bargen's gear list
Pentax K-5 Pentax K-S1 Pentax K-1 Pentax smc DA 55-300mm F4.0-5.8 ED Sigma 70mm F2.8 EX DG Macro +7 more
Leoni Fabio
Parma
Italia
Dear Holger, it seems tha your indication towards K3ii and the answer of Paul R H, that indicates the use of aAluminium foil to exclude the black-painted mount retro of the Extension tube that insulated the contacs of K1, (it's my case) can resolve the problem.
Now i get the aluminium foil and do the test.
In the meanwhile, if someone that gets a K1 and meets this problem is welcome.
Regards to all.
Kleon
Sorry, I give it up; I tried, as someone told, with aluminium foil: and it wasn't succesful; after I changed the back of a Teleplus, that worked with K1, with the rear of the extension tube, I worked two hours for them coincide: all useless and so I realize that problem is a difference of height of the leverage that connects with K1.
This is a problem of the last Pentax cameras ; there has been a change so you have to find the right one.
The problem is that with Amazon or similiar you cannot try them and you buy at your own risk.
That's all, I thank all tried to help me.
This is mine opinion, but I'll be glad to be denied.
Regards
bilybianca Contributing Member • Posts: 699
There are three "levels" (maybe four?) of extension tubes.
The simplest (and cheapest?) are simply tubes with k-bayonette mounts at each ends. They haven't got the coupling lever and the lens then acts a a purely manual lens that stops down when you turn the aperture ring. If it doesn't, the photo will be taken with the aperture wide open even if you have stopped it down with the ring. The only lens I have that would work with this kind of extension tubes is my 28mm shift lens, a fun but complicated device that I'd never use for macro shots. I guess that old m42 screw mount lenses with a k-mount adapter would work.
Next level is marked as "automatic". This simply means that there is an aperture coupling lever, and the lens will stop down to the chosen aperture when you take your photo. But it still acts as a manual lens, you have to set the aperture with the aperture ring and use the green button or d o f control to set the correct exposure. And you have to choose the "use aperture ring" option in the menu.
Third level are tubes with both the lever and the electric contacts for aperture control from the camera body. With these tubes, lenses with an "A" setting on the aperture ring work just like they do without the tubes. Just set the ring to "A" and handle the rest from the camera body. After much search I actually found this type of extension tubes, used on ebay. They are only marked "made in Japan", no brand name or anything like that. But they do work well.
The possible fourth level would be tubes that also have the autofocus screw. I have never heard of or seen such tubes.
Kjell
 bilybianca's gear list:bilybianca's gear list
Pentax *ist DS Pentax K-5 Pentax K-1 Pentax smc FA 50mm F1.4 Pentax smc DA 16-45mm F4 ED AL +24 more
Kleon
I completly agree with you, but it seems tha last Pentax cameras has made a little change in the connession of the camera: a little difference in height that makes out my Extension Tube that worked perfect with MX, LX and K20.
I can't say no more, sorry.
Regards
Kleon
To whom it concern: after my various attemps to find a solution for duplicate dias with a slide duplicator and K1 ii, I think to have found a system.
This is because mi tubes don't communicate with K1; with all mine others Pentax there was no problem.
With a little piece of wood ( or plastic ) I block the lever tha that communicates with K1, this after put the ring at 13 for instance.
In this way tge diafghram of the lens remain at f 13 when you attack it to the camera and works in stop down.
If you, before to block the lever, use it at full aperture, you can find the best focus, that pratically remain always the same, then block and go in stop down.
Just a little complicated, but it works!
Best regards.
Paul_R_H Senior Member • Posts: 1,166
Hi Kleon
It was me who used the aluminium foil solution with a K3 ii.
But before that, I had another answer which might help. When the lens is mounted to the tube and the tube is mounted to the camera, just unlock the lens and twist it slightly anticlockwise – but not too much or it could fall off! This will close the aperture.
Paul
mxx
mxx Senior Member • Posts: 1,250
I've got it to work on my K1
I've just tested the use of extension tubes on both my K1 and K5, and they work exactly the same way on both cameras. The tubes are manual Vivitar ones with only an aperture lever linkage.
Using them "as is" produces the same results as that of the OP: The aperture of the lens does not close down. The problem in my case is the anodized black finish of the tubes: It prevents the tubes from shorting the electronic contacts on the body, as a normal lens would do. Using an aluminium strip between the tubes and the lens mount to short the contacts results in the aperture closing as it should.
Also: The use of the aperture ring should be selected in the menu, as pointed out by other posters, the camera should be in manual exposure mode ("M"), and the focusing mode should also be Manual (not absolutely sure about the last one, though).
In my case a permanent solution could be to sand off the anodized finish on the part of the tube which makes contact with the electronic contacts on the body; or fix a piece of aluminium foil to that part. Of course, all your tubes (they usually come in sets of three) should be treated that way in order to work with the camera.
 mxx's gear list:mxx's gear list
Sony Cyber-shot DSC-V1 Canon PowerShot SX50 HS Sigma DP3 Merrill Pentax K100D Pentax K-m +11 more
Re: I've got it to work on my K1
Yes, mine are anodised Vivitar ones, and behave in the same way. Actually there are two levers on mine, the aperture coupling lever, which is almost hidden, and the stop-down lever itself.
Paul
To Paul and MXX
Probably my knowledge of English language can do some wrong interpretation of your missives.
My tubes are completly manual and there is no problems with electrics contacts so.
The fact is that with K1 and, for what I've seen, last Pentax, the lever of mine doesn't joins with the lever of K1.
The solution that I found, attention I can speak only for mine, is to block the lever, not of the tube, but of the lens, to make it remains at f11,13,16 ( at your choice ) and work in stop down.
This method works for duplication or static macro, not for general uses.
I hope not to have caused misunderstuding with your previous missives.
I'm sure that if someone meets a problem of this can resolve it easily.
Regards
mxx
I understand that you have a mechanical problem, but in addition to that the camera body contacts also have to be shorted to allow the closing of the aperture.
