Focus Bracketing is like magic on EOS RP with the RF 24-105mm f/4-7.1 IS STM lens!!!
Started Nov 8, 2020 | Discussions
JoeSchmoe007 Contributing Member • Posts: 502
8
I just tried focus bracketing on EOS RP with the RF 24-105mm f/4-7.1 IS STM lens.
I specified 40 images, all 40 were taken but I picked first 20 for composite.
Exposure: 1 sec, F11, ISO 11, lens at 99mm.
First frame (focused manually):
Last frame (automatic focusing):
Composite result:
Composite result
You really need to view the result at 100% to appreciate how sharp it is. I had do do it over because first attempt had my fingerprints on the ruler and I didn't want to post them online
It was a resource-intensive task that took 8 minutes and generated 3 GB of temp files. I have i7-4770 CPU and all cores were pegged at 100%. DPP was consuming 1.5GB of RAM and batch process for stacking was consuming another 1.5GB of RAM.
davidwien Contributing Member • Posts: 572
Re: Focus Bracketing is like magic on EOS RP with the RF 24-105mm f/4-7.1 IS STM lens!!!
Thank you, Joe, for your useful demo of how good this feature is. Ken Rockwell also did one that is worth looking at : https://www.kenrockwell.com/canon/eos-r/rp.htm#focusstacking
David
 davidwien's gear list:davidwien's gear list
Sony RX100 VA Canon EOS RP Canon EOS R6 Canon EF 17-40mm f/4.0L USM Canon EF 70-300mm f/4-5.6 IS USM +6 more
davev8
davev8 Veteran Member • Posts: 4,833
Composite result:
Composite result
i want to replace my aging 5Dmki with the R but its this focus stacking that pulls me to the RP
Attention Dislexsic i mean dyslexic person... This post will have many although spell checked, spelling and grammatical errs ..its The best its going get so no need to tell me it is bad I know it is .....................................................................................................
My 5D IS a MK1 classic
There is no argument for FF vs APS-c (or m43) with shallow DOF..as it's a law of physics and a very subjective personal thing if you want to make use of the shallow DOF only FF can offer
If you wait for a camera that will  tick all your boxes ....by then you will have more boxes to tick..... so the wait continues .....David Appleton
 davev8's gear list:davev8's gear list
Canon EOS 5D Canon EOS R6 Canon EF 50mm F1.4 USM +5 more
KEG
KEG Veteran Member • Posts: 4,909
Composite result:
Composite result
RP is definently the better of the two
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
davev8
Composite result:
Composite result
what makes you say that?
OP JoeSchmoe007 Contributing Member • Posts: 502
Composite result:
Composite result
Manual solution for focus bracketing on R: https://www.dpreview.com/forums/thread/4473497
Composite result:
Composite result
No, it isn't.
KEG
Composite result:
Composite result
No, it isn't.
It kind of is obvious I was comparing 5D and RP
KEG
KEG
Composite result:
Composite result
that the 13 years younger model is better?
Dunno, 400+ focus points vs 9? 26 vs 12 MP, 38 image RAW buffer vs 5, just to name few things
KEG
Alexander Rosenwald Regular Member • Posts: 385
Stacked images tend to be very sharp, not to say overly sharp. This has more to do with the stacking software picking only perfectly sharp parts out of every shot rather than the process of taking the pictures.
I tried focus stacking with items I wanted to sell on Ebay but gave up on it. You wouldn't sell anything because the pictures will show surface defects not visible by pure eye sight.
 Alexander Rosenwald's gear list:Alexander Rosenwald's gear list
Canon EOS-1Ds Mark II Canon EOS M5 Canon EOS R Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM +11 more
davev8
Composite result:
Composite result
sorry i misunderstand what you was saying ...i think you say the the RP is better than the R... if i remember the raw buffer  on the 5D is 15 or 20 ...but you never hit it at 3FPS
R2D2 Forum Pro • Posts: 26,530
KEG wrote:
JoeSchmoe007 wrote:
No, it isn't.
Actually it wasn't obvious to me either.  All three bodies were mentioned in the same sentence, and it was the R vs RP feature that was being compared. I was fooled too.
R2
Composite result:
Composite result
No, it isn't.
Sorry, it wasn't obvious to me. I was under impression you were comparing R and RP and considering focus stacking to be a "killer feature" in RP.
Yes!  Focus Bracketing is one of my very favorite features!
I've been using it on my M6ii for over a year now, for all kinds of stuff.
Have fun thinking up all kinds of cool uses for it!
R2
Ed P Senior Member • Posts: 1,000
R2
What is the effective difference between focus bracketing and simply using a smaller aperture? Thanks!
 Ed P's gear list:Ed P's gear list
Canon EOS 500D Canon EOS M50 Canon EF 50mm F1.8 II Canon EF-S 18-55mm f/3.5-5.6 IS II Canon EF-S 55-250mm f/4-5.6 IS II +2 more
R2
The smaller the aperture, the lower the lens resolution due to diffraction: https://www.kenrockwell.com/tech/diffraction.htm
My test was at f11 and even that was bad, I should've stayed at f8 ( my lens is f 7.1 at this zoom level).
So basically you can shoot with optimum aperture for your lens resolution-wise (say f4 for fixed f2.8 prime lens) but DOF would be very thin, hence focus stacking fixes a problem.
KEG
Composite result:
Composite result
No, it isn't.
I should have been clearer, I think we all agree on that
KEG
Sittatunga Veteran Member • Posts: 5,406
R2
Just thinking about the geometry of this, focus stacking should give both an extended zone of pretty evenly sharp focus and a much quicker onset of blur before and behind your subject.  It could look odd if your focus intervals were too big.  A very large aperture with dozens of steps could give you a normal perspective with an extreme telephoto blur pattern.  Stopping down a lot instead of focus stacking would give quite a gentle roll-off of sharpness with distance from the subject.  Focus stacking will give increased subject isolation while keeping the whole of the subject sharp.
Aldaia Forum Member • Posts: 79
How do you manually focus?
And how do you switch to automatic focusing?
When I tried to focus bracket with manual focus, the focus didn't advance. All images where the same. I had to rely on auto-focus.
The result was nice anyway. But I was interested in selectively focusing the starting point using focus peaking.
Thanks in advance.
 Aldaia's gear list:Aldaia's gear list
Canon RF 24-105mm F4.0-7.1 IS STM Canon EOS RP Canon EF 50mm F1.8 II Canon EF 28-105mm f/3.5-4.5 II USM Canon EF 75-300mm f/4.0-5.6 IS USM +1 more
Thanks in advance.
I can see how what I said is misleading but I cannot edit original post anymore.
It should have said: "First frame was focused by selecting specific focus point on display". Camera and lens were  always in auto-focus mode.
