Dann-Oh wrote:
LarsPolarBear wrote:
Hi Dann,
First congratulation on your new E-PL10!
However (there is always a "however" ), I would like to make a suggestion to you. If you are still able to return the E-PL10, I would suggest to see if you can get an E-PL7 with the original Olympus Housing (PT-EP12), instead. AOI is the OEM manufacturer for Olympus, therefore it would be exactly from the manufacturer, meaning you can also use the cheaper ports from AOI, and don't have to use the overpriced Olympus ports.
I have ordered the housing from AOI so I can use the less expensive AOI housing and ports. Im planning to focus on Macro and then move into CFWA. I am leaning towards a Backscatter MF1 strobe or two depending on Black Friday sales.
Actually, I meant that you would not need the expensive Oly ports for the Olympus housing, obviously the AOI ports fit to the AOI housing.
Please let us know how you get on with the Backscatter MF1, once you have used it, since I am also contemplating it and I think a lot here in the community would be interested as well. Thanks!
So, you ask "why"?
The E-PL7 and E-PL10 are almost the same, except for:
- the video capabilities (E-PL10 has 4k);
I kind of dabble in video so it will be a nice feature to have for future needs.
Ok, than the E-PL7 is out, since the video is REALLY bad!!!
- the E-PL7 has no build-in flash, but comes with an attachable flash and the ability to attach an EVF;
I don't use the EVF on my Full Frame camera (A skiiing crash broke it a few years ago so I havent used it). The E-PL10 is supposed to come with a mini flash in the package AND the AOI housing has a hotshoe to LED adapter for strobe fireing.
The E-PL10 has a built-in flash, but it cannot be used with the AOI housing (they use the hot shoe to trigger the LEDs), therfore you have to use an external light source, which makes it bigger and more difficult to use.
When I shot the Pygmy Seahorse (see my pictures), I only used the fash that come with the E-PL7 and is inside the housing, all other people on the boat (Lembeh Straits) with bigger rigs did not get it, due to some current and the cumbersome setup of the strobes being difficult without destroying the Fan Coral. Yes, the 14-42mm EZ is not a great lens, but for a beginner it is a very manageable package and leads to encouraging results, instead of putting you off .
- the menu on the E-PL10 is dumbed down;
I also use Sony cameras so the menus are going to be an improvement
It's not about the menus being complicated, Oly started to take functions out and dumbing down the cameras for product segmentation purposes.
- E-PL7 is partial metal built;
The key here is the attachable flash, which is powered by the the extra contacts, which are missing on the E-PL10's flash socket. The E-PL7 housing is build to be used with the flash attached, so that you can use it - especially for macro - without an external flash. The Oly E-PL7 housing is slightly larger than the AOI E-PL10 housing, but since you safe the external strobes, it becomes significantly easier to handle. The operations become more alike to point-and-shoot camera.
Nevertheless, this is only true if you are using the 14-42 EZ lens (or any of the other lenses compatible with the port that comes with the housing: 12mm f2.0; 17mm f1.8; 25mm and 45mm f1.8) once you are attaching another, longer port, you will still need some external lighting.
Im using the 60mm lens and port so Ill need to use my external lighting. Im currently using a Kraken Hydra 5000 S+ it has the ability to strobe up to 7000 lumens when needed.
Yep, for the Oly 60mm you will need an longer port and an external light source.
So, that are my 2 cents...
Good luck!!!
Lars
your photos are awesome. I cant wait to get my EPL10 and practice photos with it. I will be sure to share them when I have some.
Thanks, but the 14-42mm has its limitations and I am sure you will get better results with the 60mm, at least for macro.
Good luck, and let us know of your progress!
Lars
