X-S10 missing "film simulation recipe" (JPEG) custom settings (C1 to C7) capacity?
Started Nov 6, 2020 | Discussions
rla1022 Contributing Member • Posts: 762
Re: X-S10 missing "film simulation recipe" (JPEG) custom settings (C1 to C7) capacity - maybe not?
Erik Baumgartner wrote:
rla1022 wrote:
chromos wrote:
rla1022 wrote:
Greybeard2017 wrote:
rla1022 wrote:
Inpuressa wrote:
rla1022 wrote:
Anyone get their hands on the xs10 that can confirm or deny if you can save recipes ?
Yes, you can save recipes on C1-4.
Thanks that’s disappointing. That’s a major difference between existing models that none of the reviews mention. I have xt2 and was going to UPGRADE for the new simulation stuff.
I'm confused - why is an improvement disappointing?
Because going from 7 to 4 without the ability to name them like the EXISTING line has. I use recipes. I like recipes. I wanted the lower entry bar because I gave the f2 35mm. But gonna just get the 100v.
"...going from 7 to 4..." - yes.
"... without the ability to name them..." - no.
And there’s not a single review that mentioned them. Hence disappointing. It’s a software thing and not anything hardware related.
I'm not a jpeg shooter, this camera was a total non-starter for me because it can't be set up at all like my three existing Fuji cameras - no MCS switch on the front, no d-pad, no exposure compensation on the front dial, no marked dials, everything in wrong place etc. I just assumed it must, at least, be optimized for the jpeg/recipe crowd, but that doesn't seem the case either. Other than IBIS, does this camera look like a step forward to any current Fuji users? Video people, maybe? The more I look at how this thing is configured, the more it looks like a dumpster fire of a camera to me.
As I'm not jpeg shooter too, I'm glad I can now store much more camera settings than jpeg related ones into custom slots. And, I can have totaly different camera behaviour by rotating only one dial, which is fast and bulletproof. If someone prefers to have a dedicated mechanical element for each camera function, so be it. I rather program my whole camera settings into memory banks. So, it's step forward to me.
Great then, I’m glad it works for someone, it wouldn’t work for me at all. I get that they wanted to make something for the PASM people, but did it have to be so unFujilike? You can’t even assign EC to the front dial like all the other models. Dumb, IMO
Im sure there might be a firmware update.  The dials are just decoupling them from the film simulation.
 rla1022's gear list:rla1022's gear list
Fujifilm X-E4 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR Fujifilm XF 16-80mm F4 Fujifilm XF 27mm F2.8 R WR +1 more
garydavidplummer New Member • Posts: 7
maltmoose wrote:
Inpuressa wrote:
boogisha wrote:
Inpuressa wrote:
Found this on yt. Don't understand what they are saying, but showing all these screens to explain the custom settings brings me to hope that all of them will be saved individually... hoping
Ah, seeing "CUSTOM 1" on top of each one of these screens brings hope, indeed, and not just for "film recipes", but for really storing many (all?) settings, too
Thanks for this finding!
p.s. Could you please provide the link to YouTube video in question?
Here you go
I dont understand the language either but this looks to be a good find and great news.
You can clearly see the shutter, aperture, ev screen that the manual refers to also under the custom 1 slot, so maybe just bad wording in the manual.
Normal fuji cameras dont have that aperture, shutter, ev screen as they use physical dials so adding an extra menu option for saving to a custom dial makes sense. Looks like all options can be saved from all menus?, which is fantastic if true.
Let's wait for positive confirmation from someone that has it and its limitations.
I have a couple of Kevin Mullins' JPEG recipes set up as custom settings in my X-S10.
I.Q. Menu > Edit/Save Custom Setting
RefinedRuffian New Member • Posts: 1
So a short bit of additional information here, just bought and tortured the X-S10!
The recipes do still exist, but operate a little differently than I would have expected. And yes you can custom name the settings
I was able to recreate my custom black and white presets exactly, however I could not figure out why the aperture ring was not working.
I could not find a menu option to prioritise aperture over shutterspeed, so I made a workaround:
• Move the dial to aperture priority
• From here save the settings as a custom setting to each placeholder Custom 1, Custom 2, etc
• Customize each setting and save as required
Coming from an X-T10 I notice a few changes
- Highlights and Shadows are now a combined "curve" setting - but can be set the same way
- Noise reduction is missing and his now "High ISO NR"
- There is also now the added setting of "Clarity" that seems to enhance micro-contrast and especially skin smoothing/detail. It does feel like this is a way of simulating a lower aperture when lowered, could be interesting for kit lens optimization
Hope this helps someone.
Curtisb908 New Member • Posts: 2
Re: X-S10 missing "film simulation recipe" (JPEG) custom settings (C1 to C7) capacity?
Mark Levine wrote:
OMG! Maybe the worst UI I've seen in a while but now I understand that once you've entered the page to edit custom settings, you can scroll down and down and down to see more settings. I think the functionality may be perfect. Thanks.
I have been using the X-T4 for several months now after moving over from Sony.  Once you get used to the Fuji menus, they are quite easy to use, especially compared to the Sony system (great cameras but their menus are a total disaster in my mind). After my wonderful experience with the X-T4, I recently bought the X-S10 for my wife who is a novice photographer. I was initially dismayed when I learned that I couldn't save the 7 film simulations like I could in the X-T4. However, the plus to having only 4 custom settings in the X-S10 is that you can save all of the shooting settings in addition to a  film simulation for each.  This is perfect for my wife because all she has to do is select one of the custom settings (which I pre-named for her) and then click away. Personally, I like using the dials on the X-T4 to customize my image - it reminds me of the film cameras I started with many years ago. But I can see why Fuji developed the X-S10, which appeals to a different type of photographer, and broadens their market.  I particularly found "John Peltier Photography" to be extremely valuable in learning the Fuji menus and for setting up both cameras - he has online tutorials with setup lessons for various Fujifilm cameras.  These are available for a reasonable monthly subscription price which can be canceled at any time  - I highly recommend his website as it really shortened my learning curve.  (I'm not paid for mentioning his website- just a satisfied customer).
 Curtisb908's gear list:Curtisb908's gear list
Fujifilm X-S10 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F2 R WR Fujifilm XF 16-80mm F4 +1 more
Photo Legit
Photo Legit Contributing Member • Posts: 533
This has been pretty confusing to someone that hasn't used custom settings, Q menu, and film simulations previously but intends to.
If I'm understanding correctly, the only way to create custom film simulation recipes is through the custom settings slots 1-4?
Or, is it possible to use custom settings for things like auto iso and exposure settings and then have a custom film simulation selected and active that is not coupled to C1-4?
 Photo Legit's gear list:Photo Legit's gear list
Fujifilm X-T3 Samyang 12mm F2.0 NCS CS Fujifilm XF 16-80mm F4 +2 more
Yes.  It’s very confusing and none of the reviewers have tackled this question
I'm pretty sure that the C1-4 buttons are the only place to store what you're looking to do. I have not found a way to store auto iso and exposure settings along with film simulations in any other place.
Photo Legit
Just got my X-S10 and configuring it.
Here’s what I want to achieve.
1. Create and store custom film simulations
2. Set the camera to my custom film simulation of choice
3. Shoot like I normally do using dials for M/A/S/etc, white balance set, ISO set yada yada
Why in the world would custom film simulations not live in their own world with canned film simulations?
Seems like custom settings would exist for different situation to taste. Not dependent on the film, or film simulation in this case, being used.
Heavens Light Regular Member • Posts: 380
Posted a separate thread on this also. Trying to set up custom modes in XS10 for JPEG sims/ recipes. Can save the recipe settings OK but when I try to use them the aperture is set to the one I was on when I made the custom setting and I can't change it. Also, all the info has disappeared from my VF. Any way of changing this as if not the camera will go back to the dealer
 Heavens Light's gear list:Heavens Light's gear list
Fujifilm X30 Fujifilm X-S10 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R
Photo Legit
It seems you have to reconfigure your camera in the menu almost completely for each custom setting and save.
It's a little frustrating when there are settings you don't want to change globally.
For example, I have several manual lenses. I programmed my adapter mount settings to reflect that.
If I want to have those adapter mount settings in a custom setting I need to add all those lenses back in to each custom setting and save.
Greybeard2017
Greybeard2017 Veteran Member • Posts: 3,112
Could you not have set up your adapter settings and then saved them into each of the custom settings (before you made the unique changes for each set)?
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T30 Fujifilm X-S10 Fujifilm X-H2S
Photo Legit
The thing is, I don't want to make unique changes to each set for those settings like mount adapter.
Those settings don't transfer when you move to a custom setting mode. You basically start from scratch.
Same for other settings like MF assist. For each Custom Setting, you need to manually set which MF assist you want and save. Even shooting mode (A, P, M) and focus mode.
It's a little disorienting when you switch from C1 to C2 and everything isn't set up the way you normally work because you forgot to configure and save.
Hey, I was in aperture priority and now I'm in C1 which is set to P!
It would be very useful if Fuji implemented some type of option to sync specific settings or go off a base.
Greybeard2017
Maybe I'm misunderstanding what you are trying to do - but you could set up the mount adapter settings and then just save them to each of the custom settings - i.e. save all the current settings.
You would then have to customize the individual settings (C1-C4) in the way you want so it probably only makes sense when you are starting your configuration - but you would only need to set your adapter settings once.
dhearsch New Member • Posts: 8
Just traded for an X-S10 and played around a bit - seems like there's not much info out there so I can tell you that you can save 4 custom settings on this camera (rather than 7 in previous cameras).  The custom settings include many more options that can be saved (as previously mentioned) - INCLUDING WHITE BALANCE SHIFT!  Yes - you can save a specific white balance and a specific shift with each of the 4 custom settings.  This is a really nice feature if you like to use film sim recipes - just wish there was the ability to save 7 custom settings instead of only 4.  Bad news is that since the custom settings are selected via the command dial (vs. the Q menu) I don't see how they will ever be able to increase this.
Not sure if I'm going to keep the camera yet - some nice features for sure but not sure about the controls.
boogisha
OP boogisha Senior Member • Posts: 2,858
Re: WHITE BALANCE SHIFT in custom settings (C1 to C4)
Yes, it`s a feature that (finally) got introduced way back with X-Pro3, being included with all the following models, too... and one of the things that never came to X-T3, eh.
 boogisha's gear list:boogisha's gear list
Canon PowerShot A75 Canon ELPH 300 HS Canon PowerShot S120 Canon PowerShot G7 X Fujifilm X-E1 +15 more
Quickoo Forum Member • Posts: 84
I don’t know if anybody postet, but FIRST set the Modedial to for example C1, then do all your settings you like and save it under IQ, Edit/Save custom setting, choose C1 and name it how you like.
