Lens stabilization. Camera stabilization off or on?
Started Nov 5, 2020 | Questions
Tom Husband
Tom Husband Contributing Member • Posts: 770
I just bought the FE 90mm F2.8 Macro G OSS lens. It has built-in image stabilization so if I use that I should turn my a7 III stabilization off right? Or maybe the reverse, use the camera instead of the lens? Or both on?
Of course it's all off when it's on the tripod.
Sony a7 III
splashy
splashy Veteran Member • Posts: 3,554
Re: Lens stabilization. Camera stabilization off or on?
On a tripod all stabilization can/should be off.
Out of hands lens ANS camera stabilization do work well tigether.
 splashy's gear list:splashy's gear list
Sony a7R III Sony FE 55mm F1.8 Sony FE 20mm F1.8G Tamron 28-200mm F2.8-5.6 +1 more
SigZero
SigZero Contributing Member • Posts: 616
7
There is no way to enable/disable camera and lens stabilization separately.
They are either both enabled or disabled.
Br, Pawel
My photo-blog: http://pawel.online
 SigZero's gear list:SigZero's gear list
Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Apple iPhone 13 Pro
SQLGuy
SQLGuy Forum Pro • Posts: 11,300
And the camera is designed to use IBIS and ILIS/OSS together for native lenses like that one.
A7R2 with SEL2470Z and a number of adapted lenses (Canon FD, Minolta AF, Canon EF, Leica, Nikon...); A7R converted to IR.
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Canon PowerShot S100 (2000) Canon EOS-1D Canon EOS 5D Fujifilm FinePix S5 Pro +34 more
Tom Husband
OP Tom Husband Contributing Member • Posts: 770
Br, Pawel
Really? So turn one on and they're both on? Why even have a switch on the lens?
Tom Husband
Definitely off with the tripod but with hand held I didn't know both should be on.
Thanks.
Mark Sloe Regular Member • Posts: 440
Br, Pawel
...so you don't have to browse the menu everytime you want to switch it on or off...
why would you want to switch one off and leave the other on?
 Mark Sloe's gear list:Mark Sloe's gear list
Sony a7R III Sony FE 24-105mm F4
Dsnoir
Dsnoir Senior Member • Posts: 1,159
You do not get a choice, the lens controls all of the stabilisation functions. An easy way to see this is to turn the lens to no stabilisation, and then attempt to turn on the cameras stabilisation, a message will come up " Invalid with this lens"
GAS - Get Another Sony
 Dsnoir's gear list:Dsnoir's gear list
Sony FE 24-70mm F4 OSS Sony FE 90mm F2.8 macro Tamron 17-28mm F2.8 Di III RXD Sony FE 200-600 F5.6-6.3 +4 more
Foto4x4 Veteran Member • Posts: 3,606
Tom, there’s a heap of threads here that have explained Sony’s implementation of IS. This is a good one. https://www.dpreview.com/forums/thread/4388304.
And this image from there shows how they work together.
Cheers, John
Quote: “A good photograph is knowing where to stand.” - Ansel Adams
 Foto4x4's gear list:Foto4x4's gear list
Sony RX100 VI Sony a7R III Sony a7R IV Sony 50mm F2.8 Macro Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +9 more
SQLGuy
Mark Sloe wrote:
Br, Pawel
With native lenses, you would not want to, and cannot. With adapted lenses, I am not convinced that Metabones' implementation of coordinated stabilization is as good as native, but I'm still evaluating that; they give you the choice of none, one, the other, or both. With some adapters, like the Viltrox III, you can also enable both, and they don't cooperate at all, and the result is worse than no stabilization.
SQLGuy wrote:
Mark Sloe wrote:
Br, Pawel
point taken.
Mike Evangelist
Mike Evangelist Contributing Member • Posts: 645
Because the lens can be used on some bodies which don't have built-in stabilization.
 Mike Evangelist's gear list:Mike Evangelist's gear list
Sony a7R IV Sony a6600 Sony FE 70-200mm F2.8 GM OSS Sony FE 24mm F1.4 GM Sony FE 200-600 F5.6-6.3 +6 more
Fotozone Regular Member • Posts: 207
Thanks everyone on this thread! I learned a number of valuable things I had no idea I needed to know!  T
 Fotozone's gear list:Fotozone's gear list
Sony a7R II Sony a7 III Sony a7R IV Sony a6600 Sony FE 70-200 F4 +5 more
Tom Husband
Mark Sloe wrote:
Br, Pawel
That makes sense. Thanks!
Tom Husband
I guess it's best to stick with Sony if the lens has stabilization.
Tom Husband
Of course, I should have realized. Thanks.
Tom Husband
Glad I asked. It's the lens and not the camera that controls stabilization. Thanks.
Tom Husband
Thanks, I should have looked harder.
Tom Husband
You and me both. Thanks to all.
Brian_Smith
Brian_Smith Veteran Member • Posts: 3,449
Any lens that has a physical OSS Switch will control image stabilization from the lens - not the camera menu. With the FE 90mm Macro mounted on your camera, the SteadyShot Menu setting is grayed out.
 Brian_Smith's gear list:Brian_Smith's gear list
Sony a7R IV Sony a7S III Sony a1 Sony FE 90mm F2.8 macro Sony FE 24-70mm F2.8 GM +9 more
