E-M10II IBIS is darn good with 100-400mm
Started Nov 5, 2020 | Discussions
Henry Richardson Forum Pro • Posts: 21,959
15
I was out wandering around today and I walked by a big Yodobashi camera store so I went inside. Nothing particular I wanted to look at, but what the hell, fun to see the tons of camera gear all sitting out for anyone to play with and no sales people hovering around you. I played with the Sony A7C again, Sigma fp, and a few others. All I had held and played with before. Pretty much anything (bodies, lenses, etc.) are out for you to play with at these big camera stores in Japan. I walked by the Olympus section and the 100-400mm f5-6.3 was sitting out and since I had my E-M10II + ECG-3 + 14-150mm II hanging from my neck I mounted the 100-400mm on my camera. The E-M10II has the latest firmware. The last few times I was at a store that had the lens I had my Panasonic TX1 (ZS100/TZ100) so I was not able to take any photos on my own body.
I took several photos in the store at the maximum 400mm (800mm-efl). By mistake I took a few photos that had my body IBIS set to S-IS AUTO and the lens IS also turned on. My understanding is that with this body and this lens you should choose one form of IS or the other, not both. The results were fine though so I wonder if one of the 2 forms of IS was automatically turned off? Take a look at the shutter speeds. I was holding the lens and body normally (right hand under the lens) and making a reasonable effort to be steady, but I was just standing there and not making any extraordinary effort to be steady. These first 2 photos are from about 10-15 meters away.
The next photos were from about 30 meters away.
I turned off the body's IBIS and only had the lens IS turned on:
I turned on the body's IBIS and had the lens IS turned off:
I would say the IBIS in even the E-M10II is darn impressive!
I wrote the following about modular m4/3, the E-M10II specifically, in February 2016:
https://www.dpreview.com/forums/post/57203605
The Pleasures of m4/3
For me the pleasures of using m4/3 runs in 3 directions depending on what kind of photography I am doing:
1. Bodies and lenses with similar capabilities to my previous DSLR gear are smaller and lighter. When I travel the decrease is really appreciated! (The GX7 can do this too.) For example, when I travel I take the following:
  • Olympus E-M10II + ECG-3 grip
  • Olympus E-M10 + ECG-1 grip (I wish both cameras used the same grip because then I would only carry one)
  • 4 batteries and charger (both bodies use same batteries)
  • Olympus 14-150mm f4-5.6 II
  • Olympus 9-18mm f4-5.6
  • Olympus 25mm f1.8
  • Olympus 9mm f8 fisheye
2. Then at other times I really love the small, excellent, prime lenses. (The GX7 can do this too.) I take off the ECG-3 grip and mount one of my small lenses (and sometimes carry one or two more in a pocket):
  • Panasonic 14mm f2.5 pancake
  • Panasonic 20mm f1.7 pancake
  • Olympus 25mm f1.8
  • Olympus 45mm f1.8
3. Then at yet other times I take the grip off and mount the Olympus 14-42mm f3.5-5.6 EZ pancake to turn it into a better LX100 of the same size:
http://www.dpreview.com/forums/post/57047115
Some people prefer the bigger cameras such as the E-M1, GH4, GX8, and G7 which are always big and are not modular with a removable grip. Maybe they also are usually using the larger f2.8 zooms, 300mm f4, and 100-400mm f4-6.3 which make the most sense on those larger bodies.
The great thing is that there is something for almost everyone!
A point that may have been missed
https://www.dpreview.com/forums/post/57244058
I think that probably some people missed one of my points and that is because I didn't state it explicitly. When I wrote the OP I decided to instead make one of the points by way of example. The point made by example is that, at least for me, my choice of m4/3 gear using the same body fills 3 roles that otherwise would likely involve 3 different cameras.
The modularity of the E-M10II (and E-M10, E-M5II, and E-M5) which have add-on grips which one can optionally use along with the plethora of lens choices of many focal lengths, apertures, and sizes allows me to use just an E-M10II and depending on whether I use the add-on grip or not and depending on which lens I mount it can be a completely different sort of camera, but retain the same great sensor, the wonderful IBIS, the excellent EVF, same battery, and I don't have to get accustomed to a different interface, menu, etc. Before m4/3 I would more likely have 2 or 3 different cameras to fill the spots that just my E-M10II currently fills. These days when I travel I take the E-M10II and E-M10 (backup). Same batteries for both.
The only other camera I take with me when I travel is a very small camera. For the last few years I have used the 1/1.7" sensor Canon S95, but I may update to a Sony RX100 or Canon G9X one of these days. All 3 cameras are almost the same size, but the RX100 and G9X have 1" sensors. [Got a Sony RX100 in 2018.]
My PEN-F is great and I use it sometimes when traveling too. Then in January 2020 I bought an excellent, used GX7II (GX85) in Tokyo. My first used m4/3 gear. Here is my user review:
https://www.dpreview.com/forums/post/63703723
Oh, I added the very nice Olympus 75-300mm f4.5-6.7 a few years ago. I rarely use it, but it is another m4/3 gem. Small and light and quite sharp even at the long end.
Henry Richardson
http://www.bakubo.com
Chris DC Contributing Member • Posts: 805
Re: E-M10II IBIS is darn good with 100-400mm
Great insights henry.  Thanks!
The pictures taken inside Yodaboshi makes me smile. I was in Japan a year ago (seems like a decade ago now) and enjoyed an hour in one in Sendai during a rain shower. It was very fun trying out all the brands at the same time without hovering salespeople.
Of course, ever since I've been hankering for the 300mm/F4 and the PL 200mm!!!
CDC
dlevitt Senior Member • Posts: 1,187
The 10.2 + 100-400 lens combo might be working the same way as some later models.
While not sync/dual IS [lens OIS + 5 axis in body], both the lens and body are active - the IBIS is providing a single axis [likely rotation] working with the lens optical stabilization.
It is my understanding that the current 10.2 firmware provides this with lenses like the 12-100
Save the Earth! Collect the entire set!
 dlevitt's gear list:dlevitt's gear list
Panasonic Lumix DMC-FZ50 Panasonic Lumix DMC-LX7 Olympus OM-D E-M10 II Olympus E-M1 II Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +7 more
Interceptor121 Veteran Member • Posts: 8,691
Roll stabilisation means nothing really for photo as having the landline straight can be achieved looking at the markers on a single shot
The lens looks good because the IS of the lens is good. I have panasonic tele lenses and sigma tele lenses that are stabilised and they do not use the body IBIS and work great
At long end body IBIS is not that effective as lens IS, in the review of sigma 100-400 5-6.3 lens which is this same lens the OIS is proved to be very effective and exceed 3 stops. probably Olympus is being cautious here
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
AndyH44
AndyH44 Veteran Member • Posts: 3,110
"I was holding the lens and body normally (right hand under the lens)"
I would love to see that method!
"True craftsmen never blame their tools, but strive to use them properly"
SrMi
SrMi Veteran Member • Posts: 4,377
AFAIK, roll stabilization (IBIS Z-axis) does not mean making the landline straight but eliminating shake caused by movement in the Z-axis.
You don't understand what I wrote
1st roll stabilisation is about rotation on the lens axis not shifts so occurs when you apply a torque on the axis for example pressing the shutter. If you take a shot and keep the horizon line straight (and this can be done relatively easy) you are almost certain you are not drifting and the roll motion is zero very quickly unless you are shooting long exposures that with a long lens you dont do
If you are shooting a motion scene and the camera is moving most likely you are already at fast shutter scene with IBIS off
If instead you are shooting video and moving the camera it is possible that your two hands are not level when you do a pan and the roll stabilisation helps that situation
So for still shots is almost irrelevant while for video has some important. As nobody gets one for video this is almost irrelevant
BG28
BG28 Contributing Member • Posts: 612
Based on what Robin Wong explained in one of his videos:
1. When using an Oly lens AND body with SYNC IS (12-100, 300), both body and lens IS work together. Oly's 100-400 does not have this.
2. When using an Oly lens (with IS) on a non-SYNC IS body (ex EM-10 series, E-PLx), the lens IS is working, and the IBIS is turned off. Even though there are menu controls for doing the opposite, only the above is true. Oly doesn't give the user a choice.
3. When using an Oly lens (w/o IS) or any Panasonic lens, IBIS is the default. The menu option to turn off body and use lens IS is there specifically to use with Pany lenses, so that when using a Pany telephoto we can use the more effective lens IS.
If I understand Robin correctly, all the images you took are using the 100-400 lens IS. No matter what menu options you chose, the lens IS is the default system because neither the 100-400 nor the EM-10 has SYNC IS, so the camera turns off IBIS.
https://www.youtube.com/watch?v=7vnZ3jhQolM
I whole-heartedly agree with you on the strengths and versatility of m43. I love this system and its cameras and lenses, even though my GAS tells me "we need more moRE MORE".
 BG28's gear list:BG28's gear list
Olympus PEN E-P5 Olympus E-M5 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-40mm F2.8 Pro Panasonic Leica DG Summilux 15mm F1.7 ASPH +2 more
OP Henry Richardson Forum Pro • Posts: 21,959
Left hand under lens :-)
Maybe I was looking in the mirror when I wrote that.
Henry Richardson
Lens IS turned OFF
In the last photo I had the body IS turned ON and the lens IS turned OFF. I assume that the lens IS when switched to OFF turns it OFF so I think that last photo is with only IBIS.
I really like the modularity of the E-M10II.  Too bad the E-M10III got so many things removed from the firmware.  The E-M10IV restored some things, but some of the things I use with the E-M10II every time I take it out are still gone.  Same for the E-M5III.
Henry Richardson
SrMi
Excerpt from:
https://robinwong.blogspot.com/2020/08/olympus-mzuiko-100-400mm-f5-63-is-review.html
"when paired with selected Olympus camera models (...), you get additional rolling axis stabilization from the body."
Last photo: IBIS turned ON, ILIS turned OFF
This photo has IBIS turned ON, ILIS turned OFF. The IBIS works well. With care I get shots using my E-M10II + 75-300mm at 300mm without much problem and this photo is at a much longer FL and 1/30 second.
Henry Richardson
Ever since the 1980s I have been going in the big camera stores in Japan.  I don't even bother in the States.  I am totally spoiled.
CDC
Henry Richardson
I hadn't heard that, but maybe so.  Note that the last photo was taken with only IBIS.  I turned ILIS off:
https://www.dpreview.com/forums/post/64528621
Henry Richardson
1/30 second, standing, without extreme care
Lots of people say that IBIS is not all that effective at longer focal lengths. Well, even without extreme care I easily managed 1/30 second at about 800mm-efl using only IBIS using an E-M10II. The E-M10II IBIS is rated lower than the E-M5II, E-M5III, E-M1II, E-M1III, E-M1X, E-M10III, E-M10IV, PEN-F, etc.
Henry Richardson
SrMi
Re: 1/30 second, standing, without extreme care
It is my impression that manufacturers also think that IBIS is less effective with longer lenses. Why would they otherwise add OIS to long lenses?
strawman fallacy
I saw what you did there. You constructed a strawman fallacy. Probably unintentionally. Yourewordedwhat I wrote and changed the meaning and then commented on what you wrote rather than what I wrote.
Henry Richardson
SrMi
Re: strawman fallacy
I understand now that one can read it that way, but it was not my intention to construct a strawman fallacy :). I try to rephrase my post.
You write that many people (erroneously?) think that IBIS is less effective with longer lenses. My point is that most (all?) manufacturers also believe that IBIS is less effective with longer lenses (OIS included in long lenses only).
Note that Petr Bambousek turns OIS off on 100-400 and uses IBIS only. He suggests that everyone try to find their best stabilization setting (OIS/IBIS).
after 2 cups of coffee
5
One more thing I will note is that these photos were taken at 12:00 noon and earlier I had 2 cups of coffee.   That E-M10II IBIS is pretty awesome, isn't it?
Henry Richardson
I hate to be a pedant, but you still seem to be misunderstanding and rewording what I wrote to change the meaning.
No, that isn't what I wrote. Maybe it would be easier if you just use the words I wrote (you can copy and paste them if you don't want to retype them) so that you don't change my meaning. I wrote "not all that effective" which is not at all the same as your rewording where you wrote "less effective."
I said absolutely nothing about whether IBIS is more or less effective than ILIS for long focal lengths. I think ILIS is generally probably more effective for long focal lengths. And that is a totally separate issue than my point that even IBIS works pretty well.
The common definition for a strawman fallacy:
The straw-man fallacy is when a person misrepresents his opponent’s position and then proceeds to refute that misrepresentation rather than what his opponent actually claims.
To be clear, I know you didn't do it intentionally. I am just trying to be precise in what I write and make sure that rewording doesn't significantly alter my meaning.
I certainly don't want this to turn into one of those nasty internet quarrels. I am just trying to be clear and I think my words were clear so no need to reword them. So, I think, we can drop this now.
Henry Richardson
