Panasonic and macro photography
Started Nov 4, 2020 | Questions
Shazmon New Member • Posts: 2
Hi, I have the Panasonic G7 and Leica Macro 1:2 lens. I like to shoot a lot of macro photos of beetles and although this set up is usually ok for largish beetles I cannot get shots of very small ones. Is there a solution to this? I've tried all kinds of different things.  I also have the Sony A6000 with 3.5/30 Macro lens but have the same problem with that and I prefer my Panasonic anyway.
Panasonic Lumix DMC-G7 Sony a6000
Rmark
Rmark Senior Member • Posts: 1,188
Re: Panasonic and macro photography
Longer FL macro lens with 1:1
diopters on front of lens
extension tubes between camera and lens
 Rmark's gear list:Rmark's gear list
Panasonic LX100 Olympus E-M1 Olympus E-M1 II Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus Zuiko Digital 1.4x Teleconverter EC-14 +5 more
JosephScha Veteran Member • Posts: 7,249
Hi, I used to have a G7 now have a G9.  For both, I have macro rings (which do pass electrical contacts through, make sure).  They are relatively inexpensive.  Put a 16mm macro ring behind the 42.5mm lens and you can get near 1:1.  Put a 10mm macro ring behind the 15mm lens and 1) you will focus VERY close  and 2) you will likely get beyond 1:1.    I recommend macro rings because they are really inexpensive, compared to anything else you might buy for your hobby.  I have Meike "Automatic Extension Tube Set" MK-P-AF3B, "For Panasonic micro DSLR".   We'll forgive them for calling our cameras DSLRs!
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
JeanPierre Martel Veteran Member • Posts: 3,304
If you want to try extension tubes…
If ever you want to try some extension tubes, here is an article that might be interesting for you:
https://jpmartel.quebec/2020/08/10/les-bagues-allonges/
The article is in French but use the Google translation applet located at the top right corner of the screen to get a rough on-the-fly translation.
Moreover, click on any photo to zoom.
Hoping that it will be useful to you.
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +17 more
OP Shazmon New Member • Posts: 2
Thanks for the replies! I will try the suggestions and hope they improve my photos of beetles
C Sean Veteran Member • Posts: 3,423
There should be a 100mm Macro lens coming out in the near future. It's on the Olympus road map and hopefully it's compatible with their macro flash.
