NX300 Charging while streaming
Started Nov 4, 2020 | Questions
Joe Roe New Member • Posts: 1
I would kindly ask for your wisdom regarding Samsung NX300.
I have the opportunity to grab this piece from my brother. I want to use its capabilities for streaming. I was shocked when I learned that there seems to be no way to charge while recording. This is a dealbreaker as the battery is already so deprecated, that it wont hold for more than 30 minutes.
Is there a way to power this camera directly from the adapter? Any method of charging while recording for live stream?
Thank you.
Samsung NX300M
White Widow Forum Member • Posts: 66
Re: NX300 Charging while streaming
You may want to get a dummy battery similar to this:
https://www.dhxgate.com/product/bp1030-bp-1030-camera-dc-coupler-for-samsung/214437315.html
you have to take out the x in dhxgate to get the proper url.
There is more info here:
https://www.dpreview.com/forums/thread/4242687
I haven't tried it myself but it seems that if your battery is fully charged you can run the camera for ours when the usb charging cable is connected.
 White Widow's gear list:White Widow's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 12-24mm F4-5.6 ED +4 more
yazzy New Member • Posts: 2
Have you managed to find a solution to your problem? Were you able to use the NX300 to live stream using OBS? with the use of a Camlink/capture card?
