EFS 18-135 IS STM vs. M 18-150
Started Oct 31, 2020 | Discussions
shuutrr Regular Member • Posts: 472
Have owned the 18 - 135 for several years and have enjoyed using it with my M6 II.  It is relatively light weight, I own it, and I find it to be a good performer.
When I purchased my M6 II during a holiday retail sale I would have preferred the 18 - 150 kit but they were sold out so I bought the 15 - 45.
For those who have used the 18 - 135 and 18 - 150 lens on the M6 II, how would you compare the two?
shuutrr
 shuutrr's gear list:shuutrr's gear list
Canon EF-S 55-250mm f/4-5.6 IS STM Samsung NX20 Canon EOS 6D Canon EOS 70D Canon 6D Mark II +11 more
Canon EOS M6
Dareshooter Veteran Member • Posts: 5,842
Re: EFS 18-135 IS STM vs. M 18-150
I have used both not on the same camera. The 18-135 I used on a DSLR the Canon 100D. The 18-150 I'm using currently on my M50 and I feel the  18-150 is a better lens but it's not a night and day difference.To be honest I wouldn't contemplate using an adapted  18-135 on an M camera as it would be too front heavy.
PerfectMark Regular Member • Posts: 281
Unless you got that 18-135 fairly recently, I am guessing it is the previous model and not the latest 18-135 nanoUSM/STM though.
I personally use the nanoUSM 18-135 on my M6ii, it is a bit heavy, but my hands get used to it. Never saw any reason to change it and would be very surprised if the 18-150 is any better (considering the 18-150 is a smaller lens and you have to make compromises to make it smaller). .
 PerfectMark's gear list:PerfectMark's gear list
Canon EOS 600D Canon EOS M6 II Canon EF 50mm F1.4 USM Canon EF-S 18-55mm f/3.5-5.6 Canon EF-M 22mm f/2 STM +5 more
JRET
JRET Contributing Member • Posts: 840
I have both lenses & have used both on the M2 and M50.  I prefer the 18-150 with either M as it's native, easier to use, and has slightly greater range.  To me there is not a significant difference in IQ between the 2 lenses - altho the 18-135 is a very good lens (works great on my 80D) the 18-150 is the better choice to use with an M body.
 JRET's gear list:JRET's gear list
Canon EOS M6 II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 18-150mm F3.5-6.3 IS STM Canon EF-M 32mm F1.4 +7 more
Andy01 Veteran Member • Posts: 5,188
I think a similar question might have been asked a few times before. A quick search might help answer your question;
https://www.dpreview.com/search/forums?query=18-135%20vs%2018-150&forum=1060&only-threads=yes
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
R2D2 Forum Pro • Posts: 26,528
shuutrr
I used the 18-135 STM on my 70D and M5.  As you know from owning it, it is a very well-behaved lens.  I liked it a lot.
The 18-150 on my M6ii is just as likable, but substantially smaller and lighter (IMHO a better pairing for the M Series).  The 18-135 will work just as well, it’ll just be heavier.
R2
The OP asked about the second version the STM and  that was the context of my reply. The only compromise between them is the 18-150 is slower on the wide but it does have the advantage that it is a native system lens that needs no adapter,is less bulky and better balanced on the camera.
OP shuutrr Regular Member • Posts: 472
Thank you everyone for your replies.
They seem to be level in IQ, or, at least the 150 matches the 135 in IQ.
That so, the native mount and size advantages of the 150 seal the deal.
For an especially enjoyable walk around kit.
The overall size advantage of the high performance M6 II and M mounts is just undeniably fun.
shuutrr
dave_bass5
dave_bass5 Veteran Member • Posts: 7,342
shuutrr
Ive got both and there in a noticeable difference between them on my M50, especially at the long end.
I got my 18-135 STM when I had my 80D, but when i swapped for the M50 i kept that lens. Its my most used lens on the M50.
I got the 18-150 for holidays, and it worked well, but I haven’t used it much other than the one holiday. We went back the next year and took the 18-135. Sharper photos of the same things. Ive tried to use it on and off since then, but its just not as satisfying, optically.
My opinion  is get it for its size and weight, but keep your 18-135 until you have tried both.
 dave_bass5's gear list:dave_bass5's gear list
Canon EF 24-70mm F2.8L II USM Canon EF 35mm F2 IS USM Canon PowerShot S110 Canon EOS 5D Mark IV Canon EOS M50 +10 more
rrc1967 Senior Member • Posts: 1,984
shuutrr
The thing with the 18-150 is that it does require DLO or DXO Studio to get the most of it.
Simply because of the size, there's a little more on the way of compromises made.
Other than that, it's one of my favorite EF-M lenses. I'll easily sacrifice a bit of absolute IQ that I'll most likely never need ( or I'll use DLO) for a much much more pleasant kit to use.
shuutrr
Interesting . I've never felt the need to run DLO but then again I'm of  the mindset that if an image is successful a little bit of extra sharpeness is not going to add anything and if an image isn't successful it ain't going to matter anyway.
shuutrr
DLO isn't "sharpness" it's about computational corrections.
shuutrr
Yes I know but it does add sharpening. What other corrections do feel the need to make that you stated that you might never need. Not trying to argue here,just curious .
shuutrr
it doesn't add sharpening, what it does it computationally remove the AA filter's involvement on the image and also as well, diffraction, giving the appearance of "adding sharpening".  Even things such as precisely removing aberrations will give the appearance of a sharper image.
it does something like 12 (or 8.. I've heard both numbers) different mathematical corrections based upon the lens profile + camera profile generated by Canon.
rrc1967 wrote:
shuutrr
Yes I should have said it appears to add sharpening .
quiquae Senior Member • Posts: 2,265
I had both the 18-135STM (used on T4i, 7D and M2) and the 18-150STM (used on M5), and agree completely with your assessment. Optically the 18-150 is slightly better, but not by that much; the real tradeoff is in 1/3 stop at the long end vs drastically reduced bulk. The 18-135 is out of place on an M2-class body; it is usable on an M5-class body, but I wouldn't willingly choose it over the 18-150.
 quiquae's gear list:quiquae's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +6 more
RLight Senior Member • Posts: 4,417
Shuutrr,
The EF-M 18-150 reaches further, is smaller, lighter, and in fact sharper, all at the same time.
It's not a hard choice. The EF-M 18-150 is a superzoom that for a superzoom, is very very good. It leaves the EF-S superzooms including the 18-135 IS STM, in the dust. The only reason to consider the EF-S version is the price used. That's it. But the price reflects the realities that the EF-M version is just so much better and smaller.
 RLight's gear list:RLight's gear list
Canon EOS R3 Canon EOS R50 Canon RF 28-70mm F2L USM Canon RF-S 18-45mm Canon RF-S 55-210mm F5.0-7.1 IS STM
shuutrr
MTF graphs in fact indicate the EF-M wins in sharpness on both the wide and telephoto ends. It doesn't match it, it bests it. Go figure.
It just doesn't go to f/5.6 on the long end... f/6.3 is a very small sacrifice for another 15mm of reach and a much smaller, sharper lens.
dave_bass5
Graphs are not always right, especially when you take it consider manufacturing tolerances.
Eyes, on the other hand, generally  tend to tell the real story, and having both these lenses i cant see how anyone can say the 18-150 can match, let alone beat the 18-135 in sharpness.
Both are nice lenses, I’m not denying that, but only those that have both can really give a true indication.
RLight wrote:
Shuutrr,
Leaves in the dust ? That's just hyperbole. I've used both and the 18-150 appeared to be a bit better but not by much.
