A6000 and studio strobes
Started 7 months ago | Discussions
Photo Tauger
Photo Tauger Regular Member • Posts: 112
Does anyone have a good method for triggering studio strobes (Alien Bees B400s and B800s) with an A6000?  My A77 has a PC synch port and I use a standard cable between the camera and the strobe.  Can't seem to find a similar method with the A6000. Any ideas?
 Photo Tauger's gear list:Photo Tauger's gear list
Sony a6000 Sony a77 II Sony DT 11-18mm F4.5-5.6 Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony E 35mm F1.8 OSS +5 more
Sony a6000 Sony SLT-A77
Sympa Senior Member • Posts: 2,536
Re: A6000 and studio strobes
A hot shoe to PC adapter perhaps?
Or a radio remote with a PC output. This would be more expensive obviously.
 Sympa's gear list:Sympa's gear list
Sony RX100 Sony E 30mm F3.5 Macro Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS Sony Vario-Tessar T* E 16-70mm F4 ZA OSS +4 more
Dennis Bayer Contributing Member • Posts: 692
 Dennis Bayer's gear list:Dennis Bayer's gear list
Canon PowerShot SD1200 IS Canon PowerShot G15 Sony a6000 Sony a6500 Sony a7C +13 more
Photo Tauger
OP Photo Tauger Regular Member • Posts: 112
I think you are right.  A shot shoe adapter is the key.  I will have to search for one.  Thanks!
Photo Tauger
Thanks!
I have the one I posted and it works fine.
One other thing you have go consider is the trigger voltage of your strobes.  If they are old, the voltage may be too high for  your camera.
I have a few very old Speedotron studio strobes with high voltage.  This can be controlled with something like a Wein Safe Sync.  I use an in line Wein with mine.
Hotshoe with the Pixel adapter.....pc cable from adapter to Wein SS......pc cord from Wein to strobe.
thedancer Regular Member • Posts: 196
Hi, I also have old studio flashes and wouldn’t take the risk off frying my camera. So I use my Hahnel capture transmitter/receiver set to do the job. One flash I has the receiver, the other 2 or more strobes work in slave. Since they are old they don’t have TTL and are fully manual.
only thing you need to use on the receiver is a correct PC sync plug.
This is the set:
If you need more info, let me know.
E.Dancer
Photo Tauger
Thank you, great info.  All the best, Rick.
