Oly ST-8 Macro Flash for EM5iii
Dale108
Dale108 Veteran Member • Posts: 8,693
Just received this flash this week.  Works fairly well on the EM5iii, but while manual says that is compatible with the EM5iii, the flash does not fire during Focus Stacking.  Anyone know why it does not?
Dale
 Dale108's gear list:Dale108's gear list
Panasonic Lumix DMC-FZ300 Olympus TG-5 Sony RX10 IV Pentax K-1 Panasonic Lumix DC-G9
dav
dav Regular Member • Posts: 435
Re: Oly ST-8 Macro Flash for EM5iii
Dale
Check your shutter speed....in silent shutter flash only works below 1/100 I think it is...maybe even slower
Cheers
Dave
Dale108
OP Dale108 Veteran Member • Posts: 8,693
Tried that but still won't work.
Dale
dav wrote:
Dale
mchnz Senior Member • Posts: 1,548
Dale
Manual or electronic shutter?  I don't have the ST-8, but I seem to remember reading that flash has some limitations with the electronic shutter.
Dale108
Re: Oly ST-8 Macro Flash for EM5iii: Worked it Out
It seems that the flash has to be in Manual mode for Focus Stacking to work.  Thanks All
Dale
mchnz wrote:
Dale
MacroLunchtimes
MacroLunchtimes Regular Member • Posts: 240
Dale,
Are you happy with diffusion from the connected diffusers?
Ive added another layer and my look at even more layers as I still get hotspots.
 MacroLunchtimes's gear list:MacroLunchtimes's gear list
Olympus E-M1 III Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +1 more
Joe Lynch Senior Member • Posts: 1,980
Dale--If you mount your 5iii on a tripod for macro, be very gentle with any manual focus ring movements.  The tripod mount is a weak point of the camera.  I bought an L-bracket grip and tie-wrapped it to the right side strap eyelet to eliminate any flex of the tripod socket area.  Looks terrible, works perfectly.
L bracket grip modification for 5iii
Inexpensive L bracket grip for 5iii
Joe
Morpho Hunter Contributing Member • Posts: 701
Great review: How to eliminate flash hotspots with the STF-8 Macro Flash:
MacroLunchtimes
Re: Great review: How to eliminate flash hotspots with the STF-8 Macro Flash:
Nicky Bay is a legend of macro flash photography!
Dale108
Hi Darren:
Have not used it enough yet to come to a definitive conclusion.
Dale
DarrenChef wrote:
Dale,
Dale108
Thanks for the tip Joe
Dale
Joe
