Water: long or short exposure?
Quarkcharmed
OP Quarkcharmed Contributing Member • Posts: 729
Re: Water: long or short exposure?
Bobthearch wrote:
Quarkcharmed wrote:
Bobthearch wrote:
The water in both of them is great. But I do prefer the first shot.
In the first photo, the shutter speed is such that it provides detail and a sense of action and motion. And I prefer the color.
In the second photo the water is great, a more peaceful and mysterious aura. But the color isn't as inspiring, and I think the shadows are lifted too much on some of the rocks.
Thanks for sharing that scene, wish I was there right now!
Thank you!
Yeah the second one is more gloomy and also less contrasty, the relative brightness between #1 and #2 isn't how it was in reality.
If it were me I'd revisit the second photo, darken it, and see what it looked like in black and white. Maybe emphasize the shapes and misty water over the color.
Interestingly, I try b&w on many of my shots, this one didn't work to me in b&w - the blueish palette isn't very colourful on its own. Also the layers of rocks aren't well separated in colour and there's even less separation in b&w.
If you like it's fine to edit and repost it in b&w, I should've mentioned it was fine to edit the images.
 Quarkcharmed's gear list:Quarkcharmed's gear list
Canon EOS 5D Mark IV Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM
Gary from Seattle Veteran Member • Posts: 5,283
Graham Meale wrote:
My preference with moving water is to use either a very slow or very fast shutter, not something in between. The latter provides an "arty" effect if that's what one desires (and by the way I seldom do), whereas the other "freezes" the motion.
I think it depends on the volume of flow - but I am thinking here more of waterfalls. Still, when I shot with big waves whose tops were being blown back seaward by a strong offshore wind at Shi Shi Beach a couple of years ago, freezing the action was very interesting. A blended shot would not have been. You definitely get more color in shots with faster shutter speeds as the OP's images demonstrated.
With waterfalls, I would shoot something like Nevada Falls in Yosemite in spring in full sun with a high shutter speed to emphasize the power of the falls. With Burney Falls near Mt. Shasta, which had less volume, lot's of moss and cool rocks, my best images were not of the falls, but of smaller subsidiary falls of water. By keeping an intermediate SS of about 1/15 to 1/5 second, there was sufficient flow to be able to trace each flow (or trickle) of water as it dropped and splashed from rock to rock. Had I shot a faster SS none of this flow would have been evident; had I shot much slower the individual sprays would have been lost, making the blended mage far less interesting. I this all depends on the volume and consistency of the pattern of flow. Some of the shots I took near Mooney Falls in the mid-90's were similar, though my best image from there is of blended flow mimicking travertine limestone and hanging on my wall - Phillip Hyde apparently took the same image.
Shooting fast moving small streams (and most often waterfalls), the key is not to have too much white water as it detracts. Then, shooting an area of good flow, but not sufficient to produce a lot of white water, and flowing through boulders, I might prefer to shoot at a longer SS, but it all depends on the rate of flow. South Creek near Bishop is a good example if you find the right place to shoot. Perhaps my best stream image was taken there in the mid-90's.
With rivers, it all depends; perhaps some blending is what I might do on average, but if I want the color of rocks to show through the river flow, or if I want a nice warm reflected tone in a detail shot, I would probably freeze the action to show the best reflections and the detail of the flow.
 Gary from Seattle's gear list:Gary from Seattle's gear list
Olympus E-M1 Olympus E-M1 II Olympus OM-D E-M1X Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +4 more
Quarkcharmed
Re: short exposure, with some WB adjustment
Thank you!
Just a note the second shot was taken after sunset and it was relatively dark already, I don't think i used any filters. I increased the f-number from f10 to f13 to get a bit longer exposure though.
akustykmagmanetpl wrote:
personally, I'm quite bored with the mindless abuse of ND1000 filters that got so common in the last 5 years.
both are good photos, but normal exposure has higher impact because it retains the natural drama of the scene (water and clouds) which ND1000 steamrolls by smoothing out those harsh edges that this scenery requires.
sidenote: I think it could be a little colder WB with (at least on my screen) some push to magenta (water but especially clouds could use a little more pinkish cast).
other than that: beautiful scene, lovely conditions and neatly composed. well done!
Which one do you like the most (if any)?
0.6s and 30s exposures respectively. The second one is taken closer to the blue hour and it would be difficult to actually make it shorter.
This thread is more to discuss your preferable approach to capturing the water movement, but CC is welcome and will be appreciated.
Cathedral Rocks
Cathedral Rocks
Quarkcharmed
Thank you for the feedback!
I should've mentioned it's fine to reprocess these images and repost here.
Just a note these are not cropped at all, a rare case where I didn't even level the horizon as it looks ok as is. So there's nothing to uncrop, but otherwise they're heavily processed. The main issue I had was that the layers of rocks blend together and look like one big formation. This place is usually photographed from the other side and for a good reason. Converting to b&w makes them less separated again, at least I couldn't make it work.
jkjond wrote:
As displayed, the first is grabbing me more. I'm wanting to like the LE more than I do, but it isn't drawing me in. The biggest problem with the LE is timing - the sky shapes and surf of the foreground rocks being much more interesting in the first.
I think they both need a lot more processing.
Much as I like the sky shapes in the first it feels too tightly cropped at the top. There's a frustrating incompleteness to the gap in the clouds as it runs off into the frame. Processing isn't going to change that directly, though making more of the foreground will reduce the role of the sky so make it less apparent. There's so much scrummy rich detail that you've hidden in the rocks, and the patterns in the foam flowing over the outcrop is underplayed.
The LE, the sky isn't that interesting when compared to the first, which is a huge loss. But there is a lot of detail to be had in the foreground. As with the first shot, developing the foreground will play down the role of the sky and maximise the good part. It's the same with all shots, make the most of the good bits, play down the frustrations.
I don't know what your take is on reprocessing other people's work on here? I'm convinced both versions have a lot to gain, more so the long exposure, which goes some way to bridging the gap between the two. Oooh, and there's a good black and white lurking in there
Lan Senior Member • Posts: 2,474
Thank you for giving us approval to post edits
I think the main change I'd make is to tweak the colour balance away from the cyan end by increasing the yellow and magenta somewhat:
Colour balanced away from cyan.
Quarkcharmed wrote:
Cathedral Rocks
1Dx4me Forum Pro • Posts: 10,441
i never liked the long exposure foggy water...so it has to be #1 it is a nicely composed shot!
if you look at God real close and for very long, you'll find defects!!!
jkjond
jkjond Forum Pro • Posts: 10,045
Thanks for the nod to reprocess. When I refer to crops I realise there often isn't an option to 'uncrop' - I should really say 'framed'.
I'll repost your version then mine in each case to show the change in emphasis. My versions may well be backtracking over ground you dismissed on your processing, but hopefully worth a look
Cathedral Rocks
Cathedral Rocks
Plus a black and white of the long exposure. This version is looking a bit pale in the mid ground, I'd likely play some more if it were mine.
Wedding and fine art photographer https://johnleechstudio.smugmug.com
You are welcome to reprocess and repost my pics on DPR.
Reilly Diefenbach
Reilly Diefenbach Forum Pro • Posts: 14,046
Short Exposure.
I can't tolerate fluffy water.
 Reilly Diefenbach's gear list:Reilly Diefenbach's gear list
Nikon D500 Nikon D850
Bobthearch
Bobthearch Veteran Member • Posts: 9,753
Personal non-commercial websites with no ads or tracking:
Local photography: http://ratonphotos.com/
Travel and photography: http://placesandpics.com/
Special-interest photos: http://ghosttowns.placesandpics.com/
 Bobthearch's gear list:Bobthearch's gear list
Nikon D7100 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Micro-Nikkor 85mm f/3.5G ED VR Tokina AT-X Pro 11-16mm f/2.8 DX II Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR II +2 more
Bobthearch
This one I cropped to emphasize the foreground water movement, which I think is the most interesting aspect of the image.  Converted to black and white, as I found the colors distracting.  Adjusted exposure settings to leave plenty of detail in the rocks.
Quarkcharmed
Thanks - interesting interpretation, although it's definitely not how it looked and felt like - the sky actually did have cyan cast and it didn't have warm/pinkish tint. The foam in the middle of your version became too bright and a bit distracting but as I said it's an interesting and more optimistic interpretation - I tried to convey the drama. In fact if the conditions were a bit more dramatic I wouldn't have been shooting the scene at all - such places may have treacherous high waves/splashes.
Quarkcharmed wrote:
Cathedral Rocks
Quarkcharmed
Thanks! That's very interesting - your version of the #1 looks almost exactly like one of my early edits, brighter with the shadows lifted. I then made it more dramatic and more contrasty. When posting to Instagram I usually lift the shadows in many of the images because phone screens usually add contrast and may make the shadows completely dark.
Same with #2, initially it was lighter (proof: https://500px.com/photo/1009938191/flip-side-of-cathedral-rocks-by-michael-borisenko) but later on I darkened it to convey the gloomy dusk time.
The b&w isn't very exciting compared to the colour one tbh, might need a lot more dodging&burning but the biggest issue is still in the separation of the three layers in the rocks. In colour it's a bit easier to show how the distant cathedral rock/stack becomes more hazy and less saturated.
Cathedral Rocks
Cathedral Rocks
Quarkcharmed
Nice one, and it's actually very close to one of my initial attempts to frame it on the location, here's an unprocessed one, with a cormorant posing:
As a side note, recently (e.g. last year or so) I stopped being a huge fan of shadow lifting and showing all the detail, and increasing microcontrast (e.g. clarity/texture in LR) creates this grungy look that some people like and some people don't.
Quarkcharmed
Re: Short Exposure.
I hated it too before ~5 years ago I tried the long exposure myself. If you shoot at base ISO at dawn/dusk, you inevitably get long exposures without any filters. Also the smoothed out water flow is how ancient (older than ~100-150 years) landscape photography looked like. The film those days was very low ISO and required long exposures at daytime.
So I convinced myself that fluffy water is actually perfectly natural in photography.
richj20 Veteran Member • Posts: 8,309
Quarkcharmed wrote:
This scene suggests the power and fury of the water crashing against the rocks. For me, a faster shutter speed would better capture the feeling.
A couple of examples:
Of course, if your intention is to create a different mood, then your example works fine!
- Richard
 richj20's gear list:richj20's gear list
Panasonic Lumix DMC-GX8 Panasonic Leica 100-400mm F4.0-6.3 ASPH Sony a7R II
Quarkcharmed
Great examples. I agree with the short exposure on the waterfall with water spray and mist - in that case it does show the power. The second example, not so much in my opinion, the water looks frozen and not how we actually see it, I'd probably do a 0.2-1s exposure in that case.
With the seascapes and waves/splashes I prefer exposures around 0.5-1s as that timing shows the motion the best to me. In my case on that location, the surf wasn't very powerful, had it been more powerful my equipment wouldn't have survived on the rock were I was standing and I'm not sure about myself.
So yeah I rather tried to show the mood/atmosphere and not the power of the surf.
- Richard
jkjond
The irony is that most of my landscape photography is dark and moody
kaphinga
kaphinga Senior Member • Posts: 2,849
I like both versions.  They tell two different stories --- the first is about energy and anger, and the second is mysterious and moody.   The preferable one depends on the story you want to tell.
Marie
 kaphinga's gear list:kaphinga's gear list
Nikon D750 Olympus E-M5 II Olympus E-M5 III Nikon AF-S Nikkor 50mm F1.4G Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +17 more
nevada5
nevada5 Forum Pro • Posts: 14,973
Everything about #1 is better IMO. I have to say I don't care for the second image at all.
#1 has, and #2 lacks - contrast, drama, interest throughout the scene.
I'll try to be nicer if you'll try to be smarter.
Life is short - drive a convertible.
 nevada5's gear list:nevada5's gear list
Panasonic Lumix DMC-GX85 Canon PowerShot S120 Sony RX100 VI Panasonic Lumix DMC-GF2 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS +3 more
KENTGA Veteran Member • Posts: 6,991
I live # 1 hands down--- both the sky and the water.
Kent
 KENTGA's gear list:KENTGA's gear list
Canon EOS 7D Canon EOS 6D Canon EOS Rebel SL1 Canon EOS 80D Canon EOS 5D Mark IV +15 more
