X-T1 to X-T4 Upgrade - Best General Purpose Lens
Started Oct 30, 2020 | Questions
PaulH74 New Member • Posts: 2
I currently have an X-T1 and am thinking about upgrading to an X-T4. I currently have two lenses, the 18-55 f/2.8-4.0 LM OIS kit lens that came with the camera and the 55-200 f/3.5-4.8 LM OIS. The 55-200 takes fantastic pictures and the 18-55 is generally pretty good, but just not quite as sharp.
I was thinking about "upgrading" the 18-55 to the 16-55 f/2.8 LM WR but I'm a little worried about the lack of OIS. I generally don't carry a tripod, so the low-light advantage of OIS has been pretty handy. So my question is, would the on-camera IS in the X-T4 in combination with the 16-55 non-OIS give similar low-light performance (especially with f/2.8 across the range) to the 18-55 OIS on the X-T1, and therefore make a good general purpose lens.
I don't really want to have to carry a third lens around, so that's not a practical option for me.
Thanks for you help,
Paul
Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm X-T1 Fujifilm X-T4
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,432
Re: X-T1 to X-T4 Upgrade - Best General Purpose Lens
6
Short answer:   Yes.
I'd wager you'll find the 16-55 on the X-T4 will return better results than what you've been experiencing, to boot.
"Well, sometimes the magic works. . . Sometimes, it doesn't."
------ Chief Dan George, Little Big Man
@ bobtullis.com & flickr.com/photos/bobtullis
My opinions are my own and not those of DPR or its administration.
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
Pan50 Contributing Member • Posts: 673
It’ll be about the same at similar focal lengths and apertures, but the larger eyeballs on the XT1 give better image quality at higher ISOs than the XT4.
 Pan50's gear list:Pan50's gear list
Fujifilm X100S Fujifilm X-E1 Fujifilm X-T1 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +9 more
Il Mostro Regular Member • Posts: 344
Unless going with a small and ultra light body/lens combination, 16-55 is the go-to lens on my current primary body which is an X-H1. It's really a match made in heaven. I see no reason why an X-T4 wouldn't would not have the same stellar results with this lens. It's a very worthwhile upgrade over the 18-55.
 Il Mostro's gear list:Il Mostro's gear list
Fujifilm X-H1 Fujifilm 16-55mm F2.8R LM WR Canon EOS 5D Fujifilm X-E1 Canon EOS 6D +39 more
JohnS59 Regular Member • Posts: 463
Paul
As the X-T4 has in body image stabilization (IBIS) there is no need or at least not much benefit to have also a OIS lens as the 18-55 f/2.8-4. IBIS does the job and probably better than the OIS of that lens only as you are use to on the X-T1.
Sometimes  IBIS works together with OIS to improve slightly the net result with telephoto zoomlenses but I don't think this is the case with the 18-55 f/2.8-4.
 JohnS59's gear list:JohnS59's gear list
Fujifilm XF 14mm F2.8 R Fujifilm FinePix X100 Fujifilm X-T1 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +8 more
Samuraidog Senior Member • Posts: 1,672
I remember watching a video (don't remember where) that showed the image stabilization of the X-T4 + XF16-55mm was better than that of the X-T4 + XF18-55mm. This was for video, but I'd imagine the same applies for stills.
I agree with the others posters in this thread that recommend the XF16-55mm lens.
 Samuraidog's gear list:Samuraidog's gear list
Fujifilm X-T30 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
Flying Fijian Senior Member • Posts: 1,623
That's a nice set up
Yes the ibis on xt4 will make the 16-55mm a good option & you get excellent image quality. However I hope you realise the weight difference is more than double what you currently have. What kind of low light shooting do you do?
Maybe consider xt3 +16-80 as well + a fast prime for low light, it may still be lighter than xt4 + 16-55 & a f1.4 prime is better for low light. You don't always have to carry around all the lenses.
Thanks. for you help,
Paul
Good luck with the upgrade
 Flying Fijian's gear list:Flying Fijian's gear list
Ricoh GR III Fujifilm X-E3 Fujifilm X-T4 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R +13 more
Powerdoc Veteran Member • Posts: 3,941
I have both set up (XT1 and 18-55 at work) and XT4 and 16-55 at home. IQ wize the 16-55 is better but I think that your main question was about stabilisation.
The answer is that the XT4 16-55 combo is better than the XT1 18-55 combo by a huge margin.
It's all about photography
 Powerdoc's gear list:Powerdoc's gear list
Fujifilm X-T1 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
KariP
KariP Veteran Member • Posts: 6,458
Best General Purpose Lens ??? In some tests...
Paul
With X-T4 IBIS you do not really need OIS lenses.
In some tests ( like "Optical Limits" that i value ) 16-55f2.8  is optically not exceptional or stellar -  or much better than 18-55.
it 16-55 is heavier and is a WR lens - but look at the price and weight first. It  is an expensive big lens - is it really worth it?
Status value is of course a factor.
Kari
I started SLR film photography in 1968, first DSLR was Canon 40D in 2007. Now Fujifilm X-E3 and X-H1 for nature, walking around ,traveling/landscapes - fantastic 5DMkIV for landscapes, macro , BIF ... .
 KariP's gear list:KariP's gear list
Canon EOS 5D Mark IV Fujifilm X-E3 Fujifilm X-H1 Canon EOS R6 Canon EF 50mm F1.4 USM +13 more
7rvar Regular Member • Posts: 377
Even if stabilization was the only criteria to compare I would choose the X-T4 with 16-55 over prior model with the 18-55. I have the X-H1 but after experiencing IBIS it is my preference over lens stabilization now.
Telephoto is really the only place where IBIS comes up a little short vs. in lens systems.
If I didn't have 3 cameras how would I take pictures of my 2 cameras?
 7rvar's gear list:7rvar's gear list
Fujifilm X30 Canon EOS 5D Sony a7S Fujifilm X-H1 Fujifilm X-E4
OP PaulH74 New Member • Posts: 2
Thanks all for the advice so far. It sounds like the upgrade is a pretty safe bet.
And yes, I'm aware that the weight increase will be significant. I'll be keeping the 18-55 for times when that really matters!
Paul
MrSee
MrSee Senior Member • Posts: 2,604
No problem at all with the 16-55 on the T4
Jim from Ontario Canada
Fuji X-H1
Fuji 18-55 2.8-4
 MrSee's gear list:MrSee's gear list
Fujifilm X-H1
NormanAllen Senior Member • Posts: 1,033
+1 vote for the 16-55.  It is such a versatile lens.
 NormanAllen's gear list:NormanAllen's gear list
Fujifilm GFX 50R Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +6 more
caesarb Contributing Member • Posts: 606
Hi.
Personally, I believe that 16-55 delivers an excellent combination of image quality and flexibility in one-lens package.
PFB a discussion on this topic.
https://www.prophotonut.com/2015/04/30/zoom-or-prime-lenses-for-portraits-with-fuji-x/
Also, just wanted to mention this... one can "test" various Fujinon lenses here:
http://fujifilmxmount.com/comparison/en/test-our-lenses/
Thank you and kindest regards.
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 19,920
Status has nothing to do with it.
Kari, it's rare that we disagree, but on this one, we certainly do.  I've owned both the 18-55 and 16-55.  Optically, IMHO, there's simply no comparison... the 16-55 pretty well wins across its range, not to mention the fact that the constant f/2.8 aperture can be a big benefit for low light photography.  I didn't acquire my 16-55 until I had purchased the X-H1, since I rely heavily on stabilization and do a fair amount of photography in challenging lighting.  I found the optics across the FL range to be noticeably better on the 16-55, and while I respect Optical Limits (I haven't read the review in question), my own experience has been very different.  If you value stabilization and own a camera with IBIS, I think the choice is pretty simply and the IQ difference significantly more dramatic that what you suggested in your post.  I don't disagree with the weight as potential issue for some, but in my case at least (with the X-H1), I find that a heftier lens like the 16-55 actually balances and handles better than the lighter 18-55.  Of course YMMV.
And, finally, this has absolutely nothing to do with status, at least for me.  I see my gear as a set of tools, not something that defines status in any form.  If anything, when I'm out photographing  birds or other wildlife and run into other photographers, the reaction I get is almost universally one of curiosity... particularly from long time DSLR users who haven't yet made the move to mirrorless.
Jerry-Astro
Fujifilm X Forum Co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 XF 150-600mm Canon Pixma Pro-100 +1 more
readyoulater
readyoulater Regular Member • Posts: 206
Re: Status has nothing to do with it.
I'd second both of Jerry's points...
I find the 16-55 to be the better lens than the 18-55, Yes, it is heavier, but the 16mm (and obviously the overall better IQ) already made it for me. Sold the 18-55, never missed it.
About status... I don't know why, but somehow I have the impression that Fuji shooters don't care about status. People caring about status would rather buy... Sony? Canon? Leica? Strangely, if Fuji cameras would mean "status" that would rather chase me away from Fuji...
 readyoulater's gear list:readyoulater's gear list
Canon G5 X II Nikon 1 AW1 OM-1 Olympus Zuiko Digital 2.0x Teleconverter EC-20 Olympus M.Zuiko Digital ED 75mm F1.8 +7 more
KariP
Re: Status has nothing to do with it. Or sometimes...
I mentioned also the price - 16-55 is about 1100€ and 18-55 comes often in a bundle ... half the price perhaps.
16-55 could work  quite well with my X-H1 and i read some tests ... i seriously considered the lens. But - perhaps some day if there is an offer.
In the beginning 18-55 had some sample/quality issues and there are good samples and some not so great. My lens (18-55)  came with X-E1 some (many);-) years ago and i have been quite happy with the IQ. I have compared it with 23f2, 55-200  and 55f1,2 also.
Perhaps you are not interested in status things - i think very many want "The Best" - even if they can not even use it   Even on this serious  specialist forum. Not meaning You
If my 18-55 stops working i will replace it with 16-55 of course
and the 16mm vs 18mm angle of view difference is sometimes important.
But - as an upgrade from 18-55  i'm not sure if it really is worth it - compared to other possibilities. But why not if budget is OK
Kari
Jerry-astro
Kari—
No question that there’s a significant price difference and whether the benefits that the 16-55 bring are worth that difference is a decision that everyone has to make individually.  I’ve owned both lenses (the 18-55 was my first Fujifilm lens) and ultimately replaced the 18-55 with the 16-55 after renting a copy and running some comparisons.  I found the difference in IQ to be pretty significant — absolutely enough [for me] to justify the upgrade, particularly on the long end, IIRC.  Even setting aside the advantage of constant f/2.8 aperture, I found the IQ to be more consistent across its FL range than the 18-55 — which, BTW, is not in any way a bad lens.  I’d simply argue that the IQ differences are not insignificant and the constant aperture can be a real help, particularly if you’re shooting in low light on the long end of the FL range.  That, for me, was enough to justify the purchase, and I’ve had no regrets since.
Jerry-Astro
KariP
Re: ... WR Or sometimes...
Kari—
Jerry,
I did not really notice or think  that OP was upgrading his whole system from X-T1 to T4.   With a camera body with  IBIS  a lens like 16-55 could be an upgrade. And T4 is not actually a cheap camera - why not a more expensive WR lens.
When i bought my X-H1 about a year ago it was really a bargain and i did not "upgrade" anything else - kept my X-E3 and lenses .   With H1  the 16-55 f 2,8 could be a great combo. Perhaps i should upgrade ;-). Size and weight could be in balance - and WR
BTW I bought a 16-80 in July  because in theory it could be something  like a traditional 24-105 (on FF camera) - BUT the sample i got was really a lemon (rotten lemon) and i returned it.  I have not tried again.
Because of this discussion i checked the prices  - there is at the moment a reasonable "cash back". 16-80 is 900€  (no cash back) and 16-55f2,8 will be about 1000€.... i must reconsider ;-).  WR  has some serious meaning for my "lifestyle" - 18-55  has survived a lot of traveling and boating. So far.
Kari
