Active Stereophotography Community?
Started Oct 29, 2020 | Questions
hoarybat New Member • Posts: 1
Hi everyone,
Can anyone recommend an active forum or community for stereophotography?
I've just started doing digital stereophotography with a pair of CHDK-modified Canon A4000IS cameras. They work great, but I'd love to talk with some folks about improving my stereo bar -- I can't get my two cameras close enough with my current solution to shoot close-ups, and I'd like to upgrade to a Z-bar or 3D printed solution.
Here's my rig. It works pretty well (especially given how inexpensive it was), but I'd like to optimize it a bit more.
3D Gunner Senior Member • Posts: 1,031
Re: Active Stereophotography Community?
Search for "3D Photography Forum Community"...
To shoot close-ups/macro pictures with your cameras will need a dedicated beam splitter.
Brian F Flint
Brian F Flint Regular Member • Posts: 184
Hoarybat - Putting two cameras on a bar is a good start.
To get the lens closer you could try overlapping the cameras on the bar , I guess this would reduce the lens separation from around 100mm to about 70 mm. Another thing to try with some modification to your rig , is to turn one of the cameras upside down. The would result is getting a lens separation of around 60mm. If you want to do 3d macro, you will need to get the lens even closer. I have spent many years looking at ways to do this with my cameras. It usually means building some sort of rig and using mirrors.
Here is a rig I built some years ago - with this rig you can get the lens separation to around 30mm. I have since refined this rig to make it take macro photos/clips. I have added a close-up lens at the front of the rig so that I can focus to closer distances.
https://www.flickr.com/photos/26973646@N05/15664046779/in/album-72157644982222370/
Here is a much more complex rig which uses a half-mirror ( also called a beam splitter ). On this rig I can have a lens separation which is adjustable between of 5mm to 20mm. Again I can put a close-up lens at the front of this rig ( both cameras look through this same close-up lens) and have the focus distance at around 200mm from the rig.
https://www.flickr.com/photos/26973646@N05/49511156646/in/album-72157644982222370/
 Brian F Flint's gear list:Brian F Flint's gear list
Panasonic Lumix DMC-ZS60 Sony RX10 III Canon MP-E 65mm f/2.5 1-5x Macro
Boris Starosta
Boris Starosta Forum Member • Posts: 53
Here's where most hobbyists and some professionals go (if there are any left):
https://photo-3d.groups.io/g/main
I like your anaglyph appropriate camera coloring!
Boris
 Boris Starosta's gear list:Boris Starosta's gear list
Canon PowerShot G9 Fujifilm FinePix Real 3D W3 Panasonic Lumix DMC-3D1 Sigma DP1 Merrill Sigma DP2 Merrill +5 more
wim hoppenbrouwers
wim hoppenbrouwers Regular Member • Posts: 250
3D stereo Community
Life has 3 dimensions
