Canon M6 Mark II, third party E-TTL flash compatibility
Dimi Koan
Dimi Koan Junior Member • Posts: 26
I have Godox TT685C and it works great with EOS 200D / SL2. Now I'm planning to buy M6 Mark II. Will it work?
Canon EOS M6 Canon EOS Rebel SL2 (EOS 200D / Kiss X9)
geru Senior Member • Posts: 1,116
Re: Canon M6 Mark II, third party E-TTL flash compatibility
Yes....
 geru's gear list:geru's gear list
Canon EF 85mm F1.8 USM Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EOS M50 Canon EF 24mm f/2.8 Canon EF 40mm f/2.8 STM +4 more
Dimi Koan
OP Dimi Koan Junior Member • Posts: 26
geru wrote:
Yes....
Looks like uncertain answer.
In fact, I'm asking, because I know that in their recent APS-C DSLR  Canon got rid of central contact on hot shoe. It looks like there is the central contact on M6 Mark II, but maybe they disabled the functionality some other way.
So, is there anybody here who tried a third party flash on this camera.
FDimi Koan wrote:
geru wrote:
Yes....
There is nothing uncertain about my answer.
The MK II has the same hot shoe and same pin setting as M50, 80D, 90D etc,etc. The camera you refer to is the newly released 250D/sl2 which had the center pin removed that is not the case on the M6 MKII.
Are you interested in the Godox or another Speedlight brand? That is an entirely different question
Dimi Koan
Thanks for the answers!
Well, you answer was "Yes..." with ellipsis. To me it looked like sort of hesitation.
Perhaps Canon could break the functionality without removing the central contact
I have a Godox flash, so I'm interested in this mainly. But, if Godox doesn't work but some other does, I'd like to know this too, because I wouldn't want to buy an expensive Canon flash anyway.
rrc1967 Senior Member • Posts: 1,853
Dimi Koan wrote:
geru wrote:
Yes....
that's tin foil hat wearing at it's best. the center pin isn't necessary on an E-TTL flash.
Godox flash works with the M6 Mark II. I have the smaller tt350c and it works just fine.
Dimi Koan
Thank you!
R2D2 Forum Pro • Posts: 22,155
rrc1967 wrote:
Dimi Koan wrote:
geru wrote:
Yes....
Right.  Except that I shoot with full manual flash power, and have the hotshoe's flash communication pins taped off in order to speed up flash response.  Thus there's no pesky flash communication delay before flash firing.  Plus I can shoot flash at a full 14 FPS!  Very handy.
+1 I have the Adorama Flashpoint Zoom Mini (Godox tt350c) and it works perfectly (with communication or without).  Likewise my Nissin i40.  These two flashes balance very well on the M6ii.  All of my Canon flashes have full functionality too.
R2
Canon EOS M6 Canon EOS M6 II Canon EOS R5
R2D2 wrote:
rrc1967 wrote:
Dimi Koan wrote:
geru wrote:
Yes....
can't you just turn your flash off E-TTL and do the same?
R2
the tt350c's are so tiny too.
rrc1967 wrote:
R2D2 wrote:
rrc1967 wrote:
Dimi Koan wrote:
geru wrote:
Yes....
No. (Slow) flash communication still occurs regardless of any flash settings (on the flash or through the camera's menu).
R2
Yes indeed, that was one of the "two" that I referenced. The Flashpoint Zoom Mini is an Adorama branded Godox tt350c. It's a little lighter than the Nissin, but the Nissin has 4 AA batts (with its own advantages).
R2
R2D2 wrote:
rrc1967 wrote:
R2D2 wrote:
rrc1967 wrote:
Dimi Koan wrote:
geru wrote:
Yes....
interesting. I guess the easiest way to do this would be with a hot shoe adapter so you don't gum up the actual camera's hotshoe.
the 350's are so small and lightweight I can actually travel with them. I've been tempted to get 2 more of them.
rrc1967 wrote:
R2D2 wrote:
rrc1967 wrote:
R2D2 wrote:
rrc1967 wrote:
Dimi Koan wrote:
geru wrote:
Yes....
I've done this with the M5 and M6ii for several years now.  No problems.  I use clear 3M Packaging tape.
It's a very capable flash.  If it's on-camera I really like using Gary Fong's LightBlade with it (and the Nissin i40).
R2
amidov Forum Member • Posts: 52
Yongnuo yn-600II works as well as yn-e3-rt on m6m2.
 amidov's gear list:amidov's gear list
Canon EOS 5D Mark III Canon EOS M Panasonic GX850 Canon 6D Mark II Canon EOS M100 +15 more
