EOS Utility
Para5thbtn New Member • Posts: 1
EOS Utility
When i connect my eso5d to my computer and log on to Eos utility, i get a camera not recognized message. ???? can any one help please.
running windows 10, ACPIx64
tcphoto1 Senior Member • Posts: 1,125
Re: EOS Utility
I do not believe the original 5D is compatible with EOS Utility, check the website for the list of compatible bodies.
 tcphoto1's gear list:tcphoto1's gear list
Canon EOS 5D Mark IV Canon EF 50mm f/1.2L USM Canon EF 70-200mm f/2.8L IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 16-35mm F4L IS USM +10 more
John_Hoffman
John_Hoffman Senior Member • Posts: 1,917
Re: EOS Utility
You need to go to the Canon support site for Windows Vista (x64)  and download EOS Utility 2.7.3 and see if that will work for you.
John Hoffman
Conway, NH
 John_Hoffman's gear list:John_Hoffman's gear list
Canon EOS-1D X Mark III Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 8-15mm f/4L Fisheye USM Canon EF 24mm f/2.8 IS USM +9 more
ashton lamont
ashton lamont Contributing Member • Posts: 634
Re: EOS Utility
Yes, if you're using an older 5D such as the 5D Mark II you need to install EOS Utility 2, but for later cams such as the 5D Mark IV you need EOS Utility 3.
Pete
John_Hoffman
Re: EOS Utility
And the version of EOSU2 that gets co-installed with EOSU3 will also not work with the 5D.
John Hoffman
Conway, NH
