xf 56mm f 1.2 on a T-X4 - focus issues?
Started Oct 29, 2020 | Discussions
AnderssonX New Member • Posts: 1
Hi guys,
I'm currently looking at a new camera and a couple of lenses. Right now I'm kinda leaning towards a X-T4 with the Fujinon XF 56 f/ 1,2 (Non APD version).
I really love the look of photos I've seen taken with this lens. However, last night I stumbled upon a video (https://www.youtube.com/watch?v=8yDSlkJwMOc&ab_channel=JoshuaJoelMunoz) where the author isn't really satisfied with a number of things.
One big issue seemed to be that it tends to miss the face focus quite often when using eye focus.
After watching the video I googled this issue and found quite the number of posts from other people about this. (Google search link )
What's your experience with this lens on your Fuji X-T4 (or T3) ? Do you recognize yourself with the missed focus problems?
It's really not the cheapest lens out there so I prefer not being dissapointed after getting it.
I'd love to hear your thoughts.
Fujifilm XF 56mm F1.2 R Fujifilm XF 56mm F1.2 R APD Fujifilm X-T4
GKramer1 Forum Member • Posts: 60
Re: xf 56mm f 1.2 on a T-X4 - focus issues?
I saw no one had replied to your question, so I thought I would jump in.  I have both an X-T4 and the 56 1.2 (non APD) lens.  I've never been disappointed in their performance.
But, I looked over some of the links you provided, and then ran some super-simple tests with my lens.  ... and there is something odd going on... but not sure its missed focus.
Sorry I don't have photos attached, but I used my sleeping dog as a subject and shot at f/1.2.  This was not eye tracking, obviously.
When I selected a center(ish) focus point and looked at the photos (on the camera, zoomed in) things looked sharp at the focus point.
When I selected a focus point out toward the 1/3 area, and did the same... things were slightly less sharp.  And when I moved the focus point closer to the frame edge, even more so.
But I'm not sure it was missing focus vs lens sharpness as you move toward edges of the frame?  I'm not the kind that does "brick wall" tests, so don't have other data to compare this to.
Outside of that example, I know I've had times where I focused on a person (again, not Eye AF) and then, for example, their coat was in focus but their ears blurry... that was my fault, for using the thin f/1.2 DOF and not accounting for the difference in distance between coat and face.
But all of _that_ said, I love the lens and the only real-world problems I've had with it have been of my own making.
 GKramer1's gear list:GKramer1's gear list
Fujifilm X-A3 Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +7 more
Erik Baumgartner Senior Member • Posts: 6,894
AnderssonX wrote:
Hi guys,
I don’t have an X-T4, but don’t have any real AF issues with the 56 on my X-T2. F/1.2 can, however, be very challenging to focus in just the right spot - and if you miss at f/1.2, even a little, it looks like you missed by a mile. I don’t recommend shooting portraits at f/1.2 anyway, unless you’re at a good distance, but if you must, I find that manual focus is usually the way to go unless your subject is square with your camera position.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Phil1 Senior Member • Posts: 2,307
I can't comment on the focusing as my cameras are X-H1s but looking at around 80 portraits I have to agree with Erik on the critically small DoF wide open & close up.
The comment I would have about the 56mm (mine is now sold) is that my copy was not at its best wide open, especially at the edges, and Lenstip found similar results.
In the end I traded it for the 90mm which is very sharp at full bore & be careful if you stop down to f2.8 or you may cut yourself on the sharpness! Most women taken with this lens seem to require a good dose of negative clarity, but it's fantastic for showing the 'character' of males.
Of course, you question was not about the 90mm lens - and it does require more room than the 56mm - but I just wondered if you might appreciate a slightly different take? I hope you’ll forgive the liberty!
As always, if you can, try before you buy if at all possible and make sure you test the lens you get within the 'return period' just in case.
I’m sure we’d all be interested to know how you get on with your choice in due course?
Phil
Craig268
Craig268 Senior Member • Posts: 2,005
The 56mm f/1.2 is quite simply a magnificent  lens however it's not necessarily a beginner lens as it can be a little tricky to use.   Unless you plan to use it extensively at f/1.2, I'd suggest a Fuji's equally wonderful 50mm f/2  or the terrific 50-140 f/2.8.
 Craig268's gear list:Craig268's gear list
Fujifilm X-T1 Fujifilm X-T10 Fujifilm X-T4 Samyang 85mm F1.4 Aspherical IF Fujifilm XC 16-50mm F3.5-5.6 OIS +11 more
Really? The 56 can be a bit tricky to work with, but, unlike the 35 f/1.4 at wide apertures, I find my 56 to be quite sharp across the frame, even wide open:
56mm wide open at  f/1.2
I'm not a portrait guy, but if I was, I would want the 90mm too. I've played with one and it really is fantastic - a focal length best used outdoors, though.
Phil
Pennyfan
Pennyfan Contributing Member • Posts: 729
AnderssonX wrote:
Hi guys,
I'd suggest you to get the Viltrox AF 56mm f1.4. The aperture makes almost no difference to background blur and the AF is a lot faster.
Also 1/3 of the price.
 Pennyfan's gear list:Pennyfan's gear list
Fujifilm X-T3 Fujifilm X-T5 Fujifilm 16-55mm F2.8R LM WR Venus Laowa 65mm F2.8 Macro Fujifilm XF 10-24mm F4 R OIS WR +4 more
Michael Gebauer Contributing Member • Posts: 752
AnderssonX wrote:
Hi guys,
If you want to have a camera with perfect eye autofocus, there are better choices available than Fuji.
I love to work with Fuji cameras, but mainly use single point focus setting, when taking portraits. Also looking to the video, I can‘t see any advantage in using eye autofocus in the specific situation shown in the video.
Coming back to the 56/1.2. This is a perfect portrait lens, which works great with the X-T4, particularly considering the support of IBIS.
Best regards
Michael
Chandrahadi Junarto
Chandrahadi Junarto Contributing Member • Posts: 532
I just acquired 56mm f1.2 recently and pair ot with my xt4, the eye af it's more difficult compare to my other lens, sometimes it's only show face detection, but not that often, most of time it still show the eye square, maybe around 80%.
Not testing with fast moving object, but i don't have any complain about eye af with this lens
@f1.2 eye efe detected the eyes
@f2.2 eye af can't detect my daughter eyes
All jpeg SOOC
'See with your eyes - Shoot with your heart..'
http://www.flickr.com/photos/c_junarto/
 Chandrahadi Junarto's gear list:Chandrahadi Junarto's gear list
Leica M8.2 Nikon Df Fujifilm X-T4 Nikon AF Nikkor 180mm f/2.8D ED-IF Tokina AT-X 10-17mm f/3.5-4.5 DX Fish-eye +17 more
Pan50 Contributing Member • Posts: 673
Erik Baumgartner wrote:
AnderssonX wrote:
Hi guys,
Yes, what he said. The depth of field at f1.2 is very shallow, so you might nail the tip of his nose and miss his eye. Use MF and you’ll get better results.
 Pan50's gear list:Pan50's gear list
Fujifilm X100S Fujifilm X-E1 Fujifilm X-T1 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +9 more
Truman Prevatt
Truman Prevatt Forum Pro • Posts: 14,596
Sounds like filed curvature to me.
_____
"The winds of heaven is that which blows between a horse's ears," Arabic Proverb
__
Truman
www.pbase.com/tprevatt
 Truman Prevatt's gear list:Truman Prevatt's gear list
Leica Q2 Monochrom Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 +12 more
This is some very old and very ugly wallpaper shot with the 56 wide open not far from its close focus limit. Considering the ridiculously shallow DOF at this range, I'd say this thing is sporting a rather flat focal plane. And no, this wallpaper doesn't look especially sharp in real life either.
56mm f/1.2 @ f/1.2
Prokofiev Regular Member • Posts: 156
Hi AnderssonX, did you finally buy the XT4 and the 56mm? If so, how has your experience with them been so far?
My experience has been the same as the one told by the man on the video you mentioned. Usually the eye that I focused on is slightly out of focus, and the focus is usually on the tip of the nose, and sometimes it is further away. This is useless for me, as I need a trustworthy AF.
But I just recently bought it, and I am still trying to figure out if this is the normal performance of the lens, or my particular lens is faulty.
I noticed the same thing. The camera focuses better when I select the focus frame at the center.
But I haven’t tried this with different lenses. So I don’t know if this problem is specific of the 56mm. I don’t know exactly how the AF system of the XT3 works, but I guess it just tries to make the subject under the focus frame looks sharp, but for some reason when the focus frame is more close to the borders, the camera or lens tend to fail.
I could always use the focus frame at the center, and then reframe, but if the subject is too close to the camera, when I reframe the distance will also change a bit, and so I will lose the focus, won’t I? But I could try to use the centered frame when I am more far away from the subject, for head to toe shots.
Anyway, I still don’t understand how some people are very happy with the lens and report no AF issues. And some people can’t autofocus properly and are frustrated after spending a lot of money.
Is it because some 56mm have manufacture problems and need to be repaired or replaced?
Luisdent Regular Member • Posts: 107
this might be an old post, but i just got a used 56 1.2 I'm not sure if my copy is good or bad, but here are my findings so far.
at f2 and up this thing is stupid sharp. capture one defaults to a slight sharpening for images, and with some lenses it looks natural. with this lens it looks over sharpened. the lens is so sharp on its own i turn off all sharpening and it is still super sharp (but now natural looking). f2.5 is like a razor blade.
below f2 things are harder to discern. f1.8 is mostly solid. i took it to a ren fest this weeken and can post pics soon, but shot it mostly wide open to test the feasibility of doing so in a general sense.
what i found was a frustrating set of photos with some amazing shots mixed in. a few things to note... first, i focus using single point smallest box or second smallest. back button focus. I'm incredibly steady with my hands. i can easily shoot at much lower shutter speeds than most without ibis. this isn't to boast, but to give a point of reference to what I'm about to say.
at 1.2 i focus by moving the box to a top side rule of thirds quadrant for instance. then focus on an eye. this means no recomposing, and practically zero movement on my part. with many of my shots, the subject was standing still, posing as well. so the least possible movement situation. i tried pressing focus and snapping a shot, i tried almost simultaneously doing as well (still waiting for green acquisition) to eliminate any time for movement. and many of these shots were at a decent distance (3/4 body) and not just head shots.
what i found was a few things. many of the shots were focused on something near the face instead of the eye. a coat, hair, some decoration on the head... and while it might seem i just drifted forward or backwards, i don't believe this is the case. it seems like all the areas that it caught in focus were high contrast edges. so i feel like sometimes the camera tries to find the contrast in the eye but defaults to something close with more contrast. I've seen this with other lenses too, so that strengthens my theory. i didn't use eye detection or manual focus. I'll try those next outing and see how they differ. my gut instinct says f1.2 requires manually focus tweaking most of the time.
another thing i notice was an unpleasant out of focus area near the critical focus plane. it exhibits chromatic aberration and a nervous appearance. but this is when focus isn't perfect. however, when focus is nailed, damn.
some images look tac sharp at 1.2 where it is focused. beard hairs, eyeballs, you name it. razor thin plane of focus, but if it's in it and focused it's super sharp. and the rest is butter. just make sure exposure is correct. this lens is very easily over saturated with exposure. what i mean is that if you expose properly,  everything looks good. if you over expose even a little, there appears to be a lot of diffraction type appearance, with things looking even less focused, soft, and sort of  aberrant. this is moreso than other lenses, possibly due to the longitudinal aberrations  otherwise, this lens is very reminiscent of the 35 1.4 and 90 f2 but possibly smoother. I'd say closer to look the 35 1.4 than the 90 f2 in how smooth the bokeh is.
anyhow, i found f2 was safe. i probably got almost all keepers at f2. most at f1.8. f1.6 was reasonable at a distance. 1.2 and 1.4 were fairly poor keep rates.
my take based on the reasonably limited testing is the following...
if you are a pro portraits photographer, this lens is superb. you can use it all around at f2 and when you do serious portraits and want wider, just use a tripod or continuos low mode and capture a few shots to ensure focus. other focus modes may even work better. I'll need to test more.
if you are a casual shooter, even doing portraits, f2 still looks amazing at 56mm, but I'd opt for the 50 f2 lens. cheaper, smaller lighter, faster focusing. why use the 56 if you're using f2 all the time anyway? rendering is not different enough to matter. there is a blind comparison by reggie something or other on youtube and unless you use 1.2 the 56 doesn't make much sense in my opinion.
however, 1.2 does look amazing when focus is achieved. and it gives you better low light leeway. I'm tempted myself at the idea of the 50 f2 but I'm going to give it more time as i really do love the look at 1.2 and the low light benefit. so we'll see.
This has been detailed elsewhere, but I highly recommend ditching BBF except in M mode (which doesn't require disabling AF on the shutter button) . The older lenses can be quirky and given the chance to lose focus lock, they often will (especially the 56 and original 23). With FOCUS PRIORITY on, try AF-S with a single point focus box positioned where you want it and a full-press of the shutter button (no half-press first), I had the same issues when I got my 56 and this works every time, even wide open in low light (though you should bump up the focus box size as the light drops). The 56 looks great at wide apertures if you nail the focus, but can look pretty awful if you miss (even just a little).
after much trial and error, the lens is fine. I've got more than enough shots at 1.2 that are remarkable. after using it a while I've decided it just isn't my lens. focusing is just not easy or good enough for my tastes. when you nail focus is a beautiful thing. but i don't want to focus on eyelashes. lol. f2 seems to be the sweet spot where it is a lot more consistent to not miss focus due to movement.
anyhow, as such, I've posted the 56 1.2 on the for sale forum fyi. I'll probably get the f2 or wait for something else... save money and size.  lol
