Olympus E-M1.1 fps drops while autofocus
byzz New Member • Posts: 4
Hi everyone!
I use my E-M1.1 with MZD 45mm f1.8, and I noticed, that in low ligt situations, when I half press shoot button and AF-C starts, fps in EVF or display drops very dramatically.
This issue apperars only in AF-C and AF-C+TR mode. In Mmanual, or AF-S mode all works perfectly.
I read old threads about same problem and firmware update helped in them. I try to update FW from 4.5 to 4.6 and tat not helped for me, also as a hard reset.
Have you any tips?
Thank you.
 byzz's gear list:byzz's gear list
Olympus E-M1 Olympus M.Zuiko Digital 45mm F1.8 Olympus 30mm F3.5 Macro
Olympus E-M1
Skeeterbytes Forum Pro • Posts: 18,824
Re: Olympus E-M1.1 fps drops while autofocus
What is your live view boost setting? If on, try turning it off and see whether that changes the response.
Rick
OP byzz New Member • Posts: 4
Rick
I turn off all cases of LV boost, also set refresh rate to high and it doesn't work. Focus peaking turned off also.
cosmicnode Veteran Member • Posts: 5,622
byzz wrote:
Rick
When I set frame rate to high from normal, in dim light on the MK2 it makes the viewfinder very dim and virtually stops autofocussing
Mike.
"I say we take off and nuke the entire site from orbit, it's the only way to be sure."
 cosmicnode's gear list:cosmicnode's gear list
Nikon D1 Nikon D1X Nikon D1H Nikon D2H Nikon D2X +16 more
