NGC6334 Cat's Paw Nebula
Started 5 months ago | Photos
timothya New Member • Posts: 10
Compiled from 120 two-minute exposure, Skywatcher Esprit 100mm refract
or, Skywatcher EQ8 mount, ASI071MCPro. Captured with SharpCap and processed with PixInsight and Photoshop.
Brueghel
Brueghel Senior Member • Posts: 1,029
Re: NGC6334 Cat's Paw Nebula
Nice
First time it really strikes me as a cat's paw
(BTW: Captured with Sharpcap ??? :-))
 Brueghel's gear list:Brueghel's gear list
Canon EOS 6D Nikon D7100 Nikon Z50 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Micro-Nikkor 85mm f/3.5G ED VR +4 more
OP timothya New Member • Posts: 10
Brueghel wrote:
timothya wrote:
Compiled from 120 two-minute exposure, Skywatcher Esprit 100mm refractor, Skywatcher EQ8 mount, ASI071MCPro. Captured with SharpCap and processed with PixInsight and Photoshop.
Nice
Why do you ask?
chris gunn
chris gunn Veteran Member • Posts: 9,375
Nice subtly in the nebula.
Stars all blown out?
cheers!
Gunn
-- Get a big lens and get closer™.
 chris gunn's gear list:chris gunn's gear list
Pentax K-1 II
Brueghel
timothya wrote:
Brueghel wrote:
Nice
Why do you ask?
Well, I had wrong info. I thought that sharpcap was a polar alignment tool that was used in conjunction with SGP. I knew it could not be used with a DSLR so I did not delve any deeper ... Didn't know you could use it as your main camera control/session control tool.
Just looked it up. I was wrong.
This is not true - if there is an ASCOM driver for your camera, SharpCap wil interface to it. There is just no native SharpCap DSLR support:
https://www.cloudynights.com/topic/657429-how-to-use-sharpcap-with-a-dslr/
Brueghel
You're right. Should have added "natively". I answer too fast
I did set up Ascom on my PC two years ago and got SGP & plate solving working. Too many things piled up (IMHO). I use my PC for too many things (and I want the rest to be stable) and I felt that the advantages were not clear enough in my case. So I stuck with good old BEOS: simple, light, easy, never crashed.
Anyway, thanks to you, I'll keep an eye on Sharpcap in case I decide to change my SW configuration
