Interceptor121 wrote:
Harold66 wrote:
Both lenses are very good quality but anyone serious about portrait work would not choose between those two lenses between a small size difference but would base their choice on the BIG difference in focal length
Unless one shoots mostly head and shoulders portrait there is no doubt that the FOV of the Nocticron is MUCH BETTER suited to portrait work
Harold
Not my experience with the focal length of 43mm you need a lot space for more than a headshot at 1 meter the frame width is only 41 cm
This is ALL untrue . First of all the Nocticron is actually wider than the 42,5mm of the Lumix lens . there has been a few tests on you tube to show that and since I have all this 40mm something lenses I conducted a test myself and was able to determine that the Nocticron is closer to a 41mm.
It may not sound like much but in real life at the short distances you mentioned it does make a BIG difference
so to get a person in full and some headroom you need 4.5 meters in my house I have only one room that is that long
unless you photograph people over 7 feet tall this is exaggerated . normally you can get someone full length with a shorter distance than the one you mentioned
so what I had to do to capture a full figure was to go outside as the lens is bulky this was a pain
so this was mostly for headshots and you can get the same with the sigma in a house
Not also false . You cannot get it both ways . if you say that you can barely get a headshot at 1 or 1.5 m with the Nocticron you can not pretend that this is the same with the sigma
outdoors there is no problem and the sigma has at least a splashproof mount
yes but not really relevant unless you shoot under HEAVY rain
obviously if you have access to a studio or a house with 6 meters room this is different but in UK this is rare
No my studio has several rooms ans most of my shots with the Nocticron are made with a shorter distance than the 4.5 meters you mentioned ?
are you using a different image ratio than the native 4.3 ratio maybe ?
The most used lens for all my portraits and functions is the 25mm for this reason
This was the same when I was shooting Nikon so it has been foolish for me not to consider that however with the sigma being so light it is easier to take it around
I am glad you are happy with the Sigma . it is just the info you give is not true or something else is missing here
Harold
FOLLOW me on IG @ledaylightstudio.
thedemandingtraveler.org
www.haroldglit.com
IG :thedemandingtraveler
