Is it possble to Adjust the Red Channel on a G9?
Started Oct 27, 2020 | Questions
Newmatix New Member • Posts: 7
Hi people,
I am struggling to take a reasonable image of a Deep RED or Dark Red flower.  I have been using Panasonic Lumix & Olympus EMx cameras since they were first available.  Currently I have GX7, GX8, GX9 and G9 bodies and they all have the same problem.
Generally I am very happy with the results of my photography using Panasonic Micro 4/3 with the following exception. Certain images I photograph have a deep or dark Red bloom or cluster of petals.  When taking shots of these colours, I cannot use the Panasonic/Lumix bodies, as the red is totally blown out and loses all definition and texture.  In the past with other cameras, I have been able to adjust the Red Channel slightly to compensate, but nothing I do will give me an acceptable result with the Lumix bodies.
While I can take these shots with a Sony body, it is difficult when doing a shoot to have to change to a different camera make and type.  For red shaded images I usually carry a Sony RX100M4, and the shots are usable with minimal tweaking from either JPG or RAW.
For example, this image is taken with a Lumix GX9, Lumix G 12-35 f/7.1 iso 500 shows totally blown out reds.
The same taken with a Sony RX100M4 requires minimal adjustment
To add insult to injury, this shot, was taken with a Samsung S7 two year old smartphone.... no adjustments!
Something is wrong... I even tried a shot from my trusty GX8, it did better than the GX9 and G9.
Any suggestions would be a big help.
Phil
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 Sony RX100 IV
Samuel Dilworth
Samuel Dilworth Senior Member • Posts: 1,391
Reduce the exposure
5
Your exposures were:
  • 1/125 s at f/7.1 for the Panasonic
  • 1/320 s at f/4 for the Sony
Those are similar exposures (just 1/3-stop more for the Sony). Yet the ISO setting was 5 × higher (500 versus 100) on the Panasonic than the Sony. Therein lies your problem. Get the ISO down and/or give less exposure to prevent the red channel saturating.
dinoSnake Veteran Member • Posts: 3,570
Re: Reduce the exposure
This.  The red channel is clipping, early as compared to the others, because the exposure is too high overall to maintain detail in that channel.  Reduce the overall exposure or try setting the camera's metering to center-weighted or spot, rather than muti-zone, in order to tell the camera "I want the center emphasized, rather than a judgement of the entire frame."
Tom Axford Forum Pro • Posts: 10,095
Re: Is it possble to Adjust the Red Channel on a G9?
As others have said, reduce the exposure to avoid clipping the red flower.
The simplest way to do it is to dial in an Exposure Compensation of -1.0, say.  I find that it is often needed with very brightly coloured flowers against a less bright background.  The camera's metering does not cope so well with highly saturated colours.
Simon97
Simon97 Veteran Member • Posts: 3,443
Brightly colored flowers should be photographed in raw mode at low iso and paying attention to the histogram. Processing the image will give so much more latitude and can allow you to pull back blown highlights (if not too overexposed).
Bright flowers should be bright! I will let the bight colors clip a bit as long as it isn't too excessive and removes detail. I never understand why some people dial back the exposure so much to avoid any clipping that the image looks dull.
 Simon97's gear list:Simon97's gear list
Canon PowerShot ELPH 360 HS Panasonic Lumix DC-G100
Bassam Guy Veteran Member • Posts: 4,885
Red flowers are a b!tch, not just on G9s but on every camera.
This is pretty close to the red over-saturation edge
Shoot raw; often the over-saturation is in monitors not in the actual exposure. Raw will give you more leeway in adjusting exposure or the red channel in PP to better suit the medium. (Or, I am scared of JPEG).
Underexpose. Bracket exposure. Don't bother with bracketing on the + side.
Back lighting. I've had success be evening the lighting by backlighting the petals with off camera flash.
Focus, smaller aperture/greater depth of field. As you can see in the above tulip, the less focused areas are the blotchy.
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
Jeff Wahaus Contributing Member • Posts: 943
It looks like you have the camera saturation set too high.  I don't have the GX9 but I would suggest to turn down saturation.
 Jeff Wahaus's gear list:Jeff Wahaus's gear list
Olympus E-M1 III Olympus OM-D E-M10 IV Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +6 more
RSTP14 Veteran Member • Posts: 6,370
I always dial in -1EV for deep reds on ANY cameras.
Roger
 RSTP14's gear list:RSTP14's gear list
OM-1 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-45mm F4 Pro +4 more
Albert Valentino Veteran Member • Posts: 9,767
5
I know this problem with reds well from several different systems. The problem is that you are blowing out the red channel. Using a live histogram does not help much as it can look properly exposed but that measures luminosity, not channels. So basically use the RGB histogram to review the shot and look at the red channel. Then simply dial down exposure compensation until the red channel no longer shows a hard shoulder on the right side. That is the proper exposure for a red subject. Also, best to shoot in raw. Then,if the red is is not blown too much you can dial back exposure to recover details. Desaturating does not work well since detail is still lost. The detail can be recovered with lowering exposure. I have used this method for shooting flowers for over a decade with Nikon, Fuji and Olympus. Red is tricky, blue can also a bit tricky, green a little less so since the green histogram generally closely mimics the luminosity histogram, so if the live histogram looks okay, green is generally okay. Red often needs that extra attention, especially to save textures lost by over exposing the red channel
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
OP Newmatix New Member • Posts: 7
6
Thanks for the help everyone.  I took the advice on board, and first set the G9 as recommended.
ISO 200-400, EV -1, Saturation -1, f7.1, SS 1/500th as a baseline.  Shot a RAW and a JPG, quite good.. will do more experimenting on settings. locked that one into a Custom C3 setting for quick access.  After the initial tests, I set the G9 in Manual mode, and tested several minor adjustments, Saturation & Exposure slightly.
Certainly sorted the clipped Red channel, it was a sunny morning and this particular flower or cluster of blooms, is a rather intense Red/Orange/Crimson shade, with very little contrasting lines or features...
Thanks a lot for the tips... glad I asked for help.
Phil, Photo-Matix Imagery
The first test result... JPG Out of Camera unadjusted.
Test JPG Unadjusted - Way better result
RAW to JPG Adjusted
G9 Manual Settings JPG minor adjustmentes to brightness and red channel.
Shot RAW and processed in ACDSee 2021 Ultimate
Shot RAW, processed to JPG
Thanks again for the help....
Thanks Albert, all responders had the right idea, you summed it up for me, thanks.  I had tried the earlier suggestions, all including your response were in the same vein.... I was just trying to find something that was not there, an adjustment or offset to the value, of the R channel, Now I have done it the correct way, a big help.
Never too old to learn eh?
Thanks to you and everyone who responded.
Phil
Photo-Matix Imagery
JosephScha Veteran Member • Posts: 7,249
The direct answer is YES it is possible to adjust how JPEGs are developed, I have not done that so I encourage you to look it up in the manual, but I know that you can probably find adjustments that make you happy (or happier).
So why haven't I done that? I pretty much always shoot raw. I may be a control freak, but that is what makes ME happy.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
Phil
Photo-Matix Imagery
Another tip may could help a little is to use spot metering on the subject. Spot metering is also extremely useful for shooting the moon
