edispics
Careful with the b and the B
Simon Garrett wrote:
Morris0 wrote:
Ron Zamir wrote:
Hi. Just a beginner question - My first ever build PC based on AMMD Ryzen 2400G on an Asrock B450 motherboard. I have collected most of the parts but case. I bought the Samaung Evo 860 2,5 Sata SSD. This PC is not for gaming just office and Photoshop and some basic video editing. Saw some review, very impressed with the Kingston A2000. Does it make sense to sell the Samsung SSD and get the Kingston or other NVME SSD? Will I notice any improvement, speed difference and reliability?
The big difference is when you go from hard drive to SSD. There is an additional improvement in load time and responsiveness with a fast NVNM drive yet it's not huge.
Morris
The throughput of M.2 NVMe SSDs can be much faster than SATA SSDs. SATA maxes out at 6GB/s,
Nope, 6Gb as in bits, not B as in bytes per second
SATA I (revision 1.x) interface, formally known as SATA 1.5Gb/s, is the first generation SATA interface running at 1.5 Gb/s. The bandwidth throughput, which is supported by the interface, is up to 150MB/s.
SATA II (revision 2.x) interface, formally known as SATA 3Gb/s, is a second generation SATA interface running at 3.0 Gb/s. The bandwidth throughput, which is supported by the interface, is up to 300MB/s.
SATA III (revision 3.x) interface, formally known as SATA 6Gb/s, is a third generation SATA interface running at 6.0Gb/s. The bandwidth throughput, which is supported by the interface, is up to 600MB/s. This interface is backwards compatible with SATA 3 Gb/s interface.
but M.2 NVMe can reach approaching 40GB/s (potentially double for PCIe 4.0). I can measure that sort of difference between SATA and NVMe SSDs I have.
A typical Samsung 970 Evo PCIe NVMe is rated at 3500 MB per second sequential read and 3300 MB per second sequential write.
Although 5 times the disk throughput would be pretty unlikely to make any program run 5 times as fast, on my machines, Lightroom is significantly faster with M.2 SSDs.
M.2 is just a design factor and can support PCIe or SATA or even USB. I supposed you mean with M.2 PCIe NVMe SSDs. But even then that statement is not consistent with Puget's testing, I have posted their benchmark results for Lightroom below.
