R6 vs R ISO scale
Started Oct 25, 2020 | Discussions
prospects Regular Member • Posts: 272
R6 vs R ISO scale
Is it just me or the the R6 underexposes the picture by around a stop compared to the R at the same ISO (with the same SS and aperture).
Did Canon just pull a Fuji? While the R6 has generally lesser noise in high ISO files, the noise levels at the certain setting may seem to be cleaner than the R, but actually it is due to the under exposure (which people might not notice at first glance).
Canon EOS R6
Master619
Master619 Forum Member • Posts: 92
Re: R6 vs R ISO scale
Haven't used the R, but my R6 exposes the pictures just fine (at least the JPEG files are normal). There are people reporting older LR versions would open the CR3 from R5/R6 as 1-2 stops lower the actual value, so could be related to your case. Try (1) update your LR / Camera raw then import them again, or (2) use DPP to process some images to see if they are still underexposed, and (3) inspect your JPEGs to see if the symptoms still show.
 Master619's gear list:Master619's gear list
Canon EOS R6 Canon EF 135mm F2L USM Canon EF 70-200mm F2.8L IS II USM Canon RF 50mm F1.2L USM Canon RF 35mm F1.8 IS STM Macro +1 more
DuncanIdaho Regular Member • Posts: 138
Unfortunately I own neither camera but I noticed the same thing in this R vs R5 comparison:
https://petapixel.com/2020/10/14/canon-eos-r5-vs-eos-r-image-quality-comparison/
I found it almost astonishing how close these cameras are. Considering how the R’s dynamic range was beaten in contrast to the R5, even the underexposed images where they push exposure in post looks almost indistinguishable to me.
would be really interesting to learn about some real life experiences from real users.
MikeJ9116 Veteran Member • Posts: 6,005
Recently I watched a video comparing the R6 to the R.  The R6 consistently underexposed images compared to the R using the same settings, lenses etc.
