Viewing stereo pairs on VR HMDs
Started Oct 24, 2020 | Discussions
3D Gunner Senior Member • Posts: 1,031
From Brian Flint on another thread:
"The link below is for a side by side parallel-view stereo image, scaled in size to make it suitable for viewing on VR headset. I bought a Zeiss VR One headset to view my side by side stereo images on a smartphone. I wanted to see what my 3d side by side images would look like using the headset as a stereo viewer. The first thing I found was the images for left and right were far too large. My smart phone is a Sony Xperia Z5 premium and the display is 121 x 68mm in size. The centre of the two images need to be spaced apart by a distance slighty greater than the spacing of my eyes. I found the optimum distance to be 68mm. Also for best effect the images are better if they have some barrel type distortion applied as the lenses in the headset stretch the corners outwards to give a more immersive effect. This stereo image shown here is about right for my Xperia Z5 premium smartphone in the 'Zeiss VR One' headset. Notice how small the images are compared with the area of the display ( shown by a white line). Only about 30% of the pixels in the display are used, the rest are wasted.
https://www.flickr.com/photos/26973646@N05/34370957872/in/dateposted-public/
So, I checked your image on my phone with my VR device and is not "spaced"/divergent vs a normal stereo pair. Seems to be a little opposite/convergent (59 mm spaced on the same screen size as yours, 5,5" diagonal). The problem can be related to viewer's optical system (the lack of manual IPD adjustment). I have two different VR viewers with manual IPD adjustment and don't have any problems.
I prepared for you some images to do a test.
1. A "normal" image. On 5,5" screen is ~60,5 mm center separation = half of 5.5" screen width size.
2. The pair have a little convergence (as your image), ~59 mm center separation on 5.5" screen.
3. The pair have divergence, ~67 mm center separation on 5.5" screen.
I can see all 4 images (yours and my) without any problems (same for my wife). I have ~72 mm IPD, my wife have ~63 mm IPD, so you are in between.
If you can see comfortable one of them, please tell me and I will give you the image in high resolution (8000x3000 pixels) and some trick to navigate inside with head tracking function. This is "the big thing".
There are also software viewers which allow you to set the image size and IPD, and provide correction for optical distortions. .............................................................
Images are in parallel mode, to be viewed on HMD VR!
Brian F Flint
Brian F Flint Regular Member • Posts: 184
Re: Viewing stereo pairs on VR HMDs
Thankyou 3D Gunner for providing these 3 images for testing the effect of different image spacings between left and right image on a VR headset..
I copied your 3 images and added a horizontal black bar at top and bottom in equal amounts so that the aspect ratio was 16 by 9 which is the same as the display on my Sony Xperia Z5 premium smartphone. I put these images into the smartphone's memory. I displayed the images on the smartphone and measured the distance between left and right centres.
Image 1. 60mm
Image 2. 59mm
Image 3. 66mm
My IDP is 66mm
Placing the smartphone into the Zeiss VR One headset, got the following results
Image 1. 60mm - I could only just get the 3d effect
Image 2. 59mm - The 3d effect was lost or very weak
Image 3. 66mm - The image was easily viewed and the 3d effect very good.
The images where immersive , that is the image filled up my field of view in all directions. I did notice that some of the side to side detail went off screen. I would say I could only see about 75% of the original image. I could however see just about all of the vertical detail. Note that I had added horizontal black bars top and bottom - about 33% of the vertical image was black ( vertically about 45mm of the 68mm on the display was lit up by the image )
From the above results I would say that with this set up, having the distance between centre of the left and right image when displayed on the smart phone matching the IDP of the user will give optimum 3d effect and ease of viewing. There is a point that when the distance between centre of the left and right image is reduced the 3d effect will be lost. I my case ( when using the Zeiss VR One headset ) this occurred at the distance of 60mm. My IDP is 66mm.
 Brian F Flint's gear list:Brian F Flint's gear list
Panasonic Lumix DMC-ZS60 Sony RX10 III Canon MP-E 65mm f/2.5 1-5x Macro
OP 3D Gunner Senior Member • Posts: 1,031
Something is wrong, but for now I will go on.
Image #2 is correspondent of your image with the mushroom, not image #3, as you can see:
I generated the demo image with normal 3D effect for large and very large screens, but the depth is reduced on small and normal screens. (below is the version - cropped area - for cross-eyes)
Next is another image with high 3D deep effect (cross-eyes).
This kind of images (with high 3D deep effect) are very difficult to be seen on large screens and with VR devices!
From this link: https://we.tl/t-6TZ4LOi6Rb you can download 3 high resolution images, intended to be viewed with a unique VR Player (for Android) which can be installed from here: VR Media Player - 360° Viewer
After installing the player, look for one of the high-resolution images uploaded to your phone:
- open it in this VR player,
- set the type of lens used (standard),
- set 3D image type - Side-by-Side,
- click on the image, then in the upper right click on the symbol for 3D glasses (to see the pair) and the symbol for the compass to activate the "head tracking" function,
- the pair of images appears on the screen and in the center there are two symbols with which the image is centered in the preferred position for viewing (spatial orientation, left-right, up-down).
The image does not appear in full screen, it can be without black stripes to complete the 16/9 format. You can see the image as it is in the HMD viewfinder.
The unique aspect of the player is the fact that it allows both pictures and videos to be greatly enlarged (zoom-in) and you can use the "head tracking" function to orient yourself inside the image, to observe different areas of interest!
High-resolution 3D images are recommended, preferably made to cover a much wider FOV than in the classic format.
Enjoy!
Brian F Flint
3D Gunner - You are right, the stereo image of the Mushroom which I had a link to , has a spacing of 59mm and not 66mm ( as seen on my Sony Xperia Z5 premium phone ) as I had intended. However is does illustrate the small size and the separation of the left and right images to get a full image when view in a VR headset.
When I view the Mushroom image on on Sony Xperia Z5 premium phone which is placed in the  Zeiss VR ONE headset I find the mushroom does not have much a a 3d effect , but if I zoom in on the image slightly so that the spacing increases from 59mm to 66mm the 3d effect is greatly improved. If I zoom in a slight bit more so that the spacing is 68mm , I get a double image of the mushroom. It would appear that spacing of the left and right image needs to be between say 62mm and 67mm in my case. There is no mechanical adjustment on the Zeiss VR ONE headset for varying the spacing also no mechanical adjustment for focal length ( dioptre adjustment ).  I measured the distance between the centre of the two magnifier lens built in to the head set  to be 66.5mm. The distance between the magnifier lens and surface of the phone is about 40mm.
I installed the VR player ( for Android ) on my Sony Xperia Z5 phone and downloaded the 3 hi resolution images. The position tracking worked.  I was able to  zoom in on the hi resolution images , but if I zoomed too much so the spacing was 68mm or more I got a double image.
I think on Hi Res image named "normal" you can zoom more than in image named "divergent". The image named "deep" is too "deep" for VR, is for test/demo purpose only.
So, the point is:
- The spacing between centers of a stereo pair is determined by the size of smartphone screen.
- The people must see all available stereo pairs without additional intervention with more or less "spacing".
- Some manufacturers of VR devices expect to address the problem with "spacing" on different screen sizes, with some complex optical solutions, as in case of Zeiss VR One headset.
So, i would recommend you to buy a cheaper headset with manual IPD and focus controls. BOBO VR Z4 is a very good one, with some negative aspects, like peripheral chromatic aberrations and the headphones are of poor sound quality (but are useful for balancing the device on the head).
I have one and I am very satisfied. With head tracking , the peripheral areas of images can be observed without chromatic aberrations (you can turn your head to see peripheral areas, not only eyes).
I also have VeeR OASIS VR device. This device have better optics, less chromatic aberrations, but requires very strict eye positioning, with low tolerance to the position of the lens. I don't like that.
I have presented 3D materials to many people, using the BOBO VR Z4 device, and no one has complained to have visualization problems. I can zoom-in or zoom-out on any normal 3D pair, without having to change the original axial distance (manually setting the IPD provided by the VR device solves any problem).
Your photo with the mushrooms have a very good depth, including the maximum zoom-in, I think that your problems come exclusively from the Zeiss VR One device.
You have a lot of 3D images/pairs, check some of them with 360* VR Player (without any modifications/distancing), including zoom-in.
One more image for cross-eyes viewing.
High resolution for VR Player here: https://we.tl/t-DSKIMI3OVJ
ShafqatMAK New Member • Posts: 9
Hi Brian / Gunner
That's a real interesting and useful info being discussed by you.
I am a great fan of 3D Stereo since long and also own a 3D Sony TV. Pity that they are getting out of use. I am very keen to view these parallel 3D image in my Quest2.
My failed approach ---
I downloaded these parallel images, but they are twin SBS in one image
Transfer them on the Quest2 folder.
Try to open them, but doesnt work
Greatly appreciate if you please guide me on this
1) Which app is required to open them in Quest2
2) How to download these images. I downloaded few images but they are 2 images as ONE pic.
Appreciate if you please guide me.
Brian F Flint
This Youtube clip may give you the answer to how to process side by side images for the Quest 2.
https://www.youtube.com/watch?v=_c7GF6ziBwY
Thanks a lot for sharing very helpful video.
Can you please share a fresh link to some stereo images that I can view using the Android App VR 360 media Player.
Since you guys are truly hooked to 3D Media, I wonder if you have attended 3D New York Stereoscopy Association weekly show. They have a VR show on AltspaceVR platform which we view in Quest2 etc and we see high quality stereo images.
Love to see you guys coming again on that show-- They also connect on Zoom at the same time.
What software can we use to create stereo images. I once used Stereo Photo Maker few years back, but could not locate any fresh link.
Much appreciate your support
Kind regards
I can give you a link to download some 3D pairs in over-under (left over right) format, 4K resolution, different thematic, if you are interested.🙂
Android app VR Media Player - 360° Viewer can play them without problems, even with zoom-in and head tracking for a little more immersion.
Hi, 3D Gunner
Thanks. I'd love to explore various themes.
I tried creating an MPO file using  software STPHMKRE, hoping that it would open up in web based VR program but failed. I will also appreciate, if you could include some MPO format.
Thanks a lot
I assume you know that you need VR devices with high resolution screens (at least 1440x2560 pixels for both eyes) to be able to properly appreciate large 3D images.
I have prepared some images in different 3D formats for you to experiment with. You can download them here in the next 48 hours:
https://we.tl/t-cnGjX51hl0
Thanks a lot for all the support. These images are quite stunning and really project the power of Stereoscopic photography.
Any suggestions on the type of 3D camera to be used for amateur / hobby category. Currently, I just take 2 snaps and fuse them with software.
I hope you and Brian and other like minded pro will come on the NY Stereoscopic show in AltspaceVR.
Thanks a lot
Regards
Brian F Flint
I make some of my own 3d clips using two cameras side by side on a bar.
I can produce from the two video files a horizontally squashed side by side clip which is 16 by 9 ratio ( mp4 clip ). It think from some research I have done, that these clips may be accepted by Quest 2 unit if the clip have the metadata 'frame-packing=3' added. I have found a way of adding this metadata ( I use the free software ' handbrake' ). I up-loaded a couple of my clips with this metadata to youtube , and youtube has recognised the clip as suitable for 3d. It takes the side by side clip and plays it in red-cyan anaglyph format.
Here is a link to two of my clips with the metadata 'frame-packing=3' added.
https://youtu.be/wmJIspUjyAE
https://youtu.be/uH0ZCErLQUk
Is it possible to view these clips using the Quest 2 unit and what sort of results do you get.
If viewing from Youtube does not work I could send the clips as mp4 files by google drive or something.
Thanks for your appreciation! 🙂
I use two identical cameras (with identical lenses) to get good quality 3D images, plus a custom beam splitter and a custom dual-lens device for close-up/macro 3D photo/video.
Thanks for sharing the details.
Its quite a painstaking efforts to capture good quality 3D. I hope , it is OK to remain in touch and ask more guidance and assistance in this domain.
Hi Brian.
Thanks for your reply and sharing the details of DIY. Creating a video using 2 cameras must be laborious because for different scene depths, results could be different.
I have opened your Youtube videos and got following results.
1) On a Laptop, The Youtube opens an Anaglyph video.
2) Inside Quest2, I opened the Link in Youtube and got an Anaglyph video. I might experiment more to get a Stereo effect in Quest2
Finally some success
3) I downloaded your video in LowRes.
4) I have a wonderful App called BIGSCREEN. I copied the downloaded video and transferred it to my Quest2 folder. I launched BIGSCREEN App and opened this Video using the Video PLayer Option. The video opened as a 2D SBS, and after I changed the setting to 3D SBS, I got good Stereo effects.
BRAVO
Due to  average experience in the use of Quest2 and therefore I move slowly with the setting and FILE TRANSFER to HMD.
CAN YOU PLEASE SEND ME A HIGH RES SBS VERSION OF YOUR VIDEO, so that I can explore the Video in Quest2.
The capture in the attachment is from a 4K video clip, undistorted (full SBS, not half SBS for settings). You can test it on your Quest2 device.
Thanks, 3D Gunner. The quality of image is really great. Such images would really standout in Light Field Displays and Lumen Pad.
If your player supports viewing large images, 50MP or more without resizing, in 360* 3D VR, I can prepare one for you. 🙂
360* 3D images for VR needs to be very large and full of details to be impressive.
Brian F Flint
ShafqatMAX
Thanks for trying my clips on your Quest 2 device which I put on Youtube.
I'm not certain that you will require side by side movie clips which are squashed horizontally for viewing using the Quest 2 device. I am also not certain you need the metadata frame-packing=3 for the Quest 2.
Here is some links to some side by side parallel view movie clips ( not squashed ) which I have on my Flickr site. You should be able to down-load them in their original form. They don't have the metadata frame-packing=3.
I would be interested to know how you get on with these.
https://www.flickr.com/photos/26973646@N05/33835492664/in/dateposted-public/
https://www.flickr.com/photos/26973646@N05/34114528421/in/dateposted-public/
https://www.flickr.com/photos/26973646@N05/34544694411/in/dateposted-public/
https://www.flickr.com/photos/26973646@N05/14805780579/in/dateposted-public/
I can add the metadata if necessary but it will take me some time to do it
Brian
