P950 - How much cropping it allows
Started 7 months ago | Discussions
Avian2016 Senior Member • Posts: 6,066
5
Northern Wheatear female at 1800mm FL
Same image with cropping set
Cropped result
Thanks for watching.
Stay healthy!
jshen808
jshen808 Forum Pro • Posts: 16,067
Re: P950 - How much cropping it allows
Great testing & results!
Thanks for sharing.
Stay safe.
Cheers!
....................Cheers, John.....................
.....If I don't respond to your post,.....
...it means you're on my ignore list,..
...................words matter!...................
 jshen808's gear list:jshen808's gear list
Panasonic FZ80/FZ82 Panasonic Lumix DMC-FZ300
Augustin Man
Augustin Man Forum Pro • Posts: 10,883
I say an excellent result!
Thank you for sharing and happy shooting,
Augustin
 Augustin Man's gear list:Augustin Man's gear list
Nikon Coolpix P1000
Stevan G Contributing Member • Posts: 625
cropped to about 6000mm, I wonder if 6000mm digital directly from the camera would give the same result
although its always better to have a bigger resolution and then crop
OP Avian2016 Senior Member • Posts: 6,066
Thanks John.
I think a proper, rich light can make wonders. Here is such an example. And with a tiny, tiny sensor.
Stay healthy!
Thanks Augustin.
Stay safe!
I'm wondering too. I guess it wouldn't.
Stay healthy!
jshen808
Avian2016 wrote:
Thanks John.
Stay healthy!
Yes, having good light helps a lot!
You too stay safe!
Cheers!
ANAYV Forum Pro • Posts: 20,522
Looks good Avian.
Seems the sensor in this P950 is quite clean in good light.
I don't miss my FZ80. Good for what it was for, but this P950 is a step up (most areas).
Was this from RAW, SOOC jpeg or edited jpeg?
Stay healthy
ANAYV
Thanks ANAYV.
I found out that Raw setting (almost) always give me a (lil') bit more from the shot. So I have it permanently on.
Thomas166
Thomas166 Regular Member • Posts: 420
Nice. For me I like close up shots so I crop some shots. This one is really sharp.
 Thomas166's gear list:Thomas166's gear list
Nikon Coolpix P950 Nikon D5500 Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Tamron AF 18-270mm F/3.5-6.3 Di II VC LD Aspherical (IF) MACRO
Thanks Thomas166.
Looks like I got a good copy. Everything functions fine except the zoom barrel transport which grinds from 1400-2000m and backward.
Stephen McDonald
Stephen McDonald Forum Pro • Posts: 14,350
Avian2016 wrote:
Thanks Thomas166.
Your cropped bird has good detail in it. I've tried cropping some of my P950 photos and have been surprised at how well the smaller and expanded areas hold up. Here's one that I cropped heavily, to get rid of unwanted objects. You can see larger images and some EXIF info by going to my Flickr album, linked below and clicking on the down arrow below each photo on the lower, right side.
 Stephen McDonald's gear list:Stephen McDonald's gear list
Nikon Coolpix 950 Sony Cyber-shot DSC-HX400V +1 more
Agreed. If image has been captured in good quality light, even heavy cropping come out well. For such FL, results are very good.
sherman_levine
sherman_levine Forum Pro • Posts: 12,753
Avian2016 wrote:
Thanks ANAYV.
What do you mean by Raw setting? I assume you mean that you process the .NRW file.  Is that correct?
I find the largest difference between the NRW and the camera's JPG (even when NR is set to low) is the loss of low-contrast details (smearing). A program such as DXO will retain the details while even while removing noise.
 sherman_levine's gear list:sherman_levine's gear list
Panasonic FZ1000 Nikon Coolpix P900 Nikon Coolpix P950
It has meant that I have Image quality set to Raw.
With the Raw dialed-in, the smearing is much less present.
Dodge_Rock
Dodge_Rock Senior Member • Posts: 2,842
Lookin' good - I like your presentation!  I've been cropping to 3:2 or 16:9 depending on the shot.  Wish we could change the ratio in camera during trimming(cropping) during  playback.
 Dodge_Rock's gear list:Dodge_Rock's gear list
Nikon Coolpix P950
Good to read you liked my presentation. Thank you.
Stay healthy.
