Full spectrum converted Canon RP
Started Oct 22, 2020 | Discussions
robgendreau Forum Pro • Posts: 10,917
8
This camera works great converted to full spectrum.
I haven't been able to shoot in good conditions yet (clouds and such), but got a few as examples. Don't look if you have an aversion to freaky color.
Mine was converted by Kolari Vision.
28-135mm 1.8 760nm IR filter
35mm 1.8 720nm filter
50mm IRChrome filter
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
dmanthree
dmanthree Forum Pro • Posts: 10,302
Re: Full spectrum converted Canon RP
Have you tried it with a UV pass filter? I'm thinking about a conversion, and would like to do some UV shooting alongside the usual IR stuff.
---enjoys shooting with inferior gear, but tempted by better stuff---
OP robgendreau Forum Pro • Posts: 10,917
All the lenses I have are glass, and although perhaps an older adapted lens might work other than as a curiosity it hasn't been on my radar. And the filters aren't cheap. More than the lens I'd probably use by a factor of two.
But I've seen some very interesting macro work done, so perhaps.
Be nice if Kolari et al rented the UV filters. But I don't think so.
Pentax 645Z
dmanthree
Yeah, I get that. And I get that lenses with UV filtration included, well, won't work well. But it's something I'll look into when the time comes. By superzoom, it turns out, isn't the best choice for IR conversion. The lense produces a serious hot spot.
mikeyL
mikeyL Contributing Member • Posts: 977
That's a very nice set - I especially like the IRChrome filtered image with your selected post processing. I have a full spectrum converted Canon T2i that I originally used for astrophotography but now use for IR. It is fun to shoot with. I have a Korari Vision 590nm filter that is fun to sue, as well as a cheaper Polaroid brand 720 filter. I have found that a lot of the magic is in the post processing - you have some excellent results here. And then of course, even with IR you need a decent subject.
In any case, great set, thanks for posting.
ML
 mikeyL's gear list:mikeyL's gear list
Canon EOS 550D Canon EOS R5 Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 16-35mm F4L IS USM +3 more
Morvegil
Morvegil Senior Member • Posts: 1,024
Someone explain what converting to full spectrum means
Only pros shoot with Canon.
 Morvegil's gear list:Morvegil's gear list
Canon EF 70-300mm f/4-5.6L IS USM Sigma 50mm F1.4 DG HSM | A Sigma 24mm F1.4 DG HSM Art Canon EOS R5 Canon RF 24-70mm F2.8L IS USM +2 more
ML
Thanks. I keep looking at Kolari for one of those 590s. Gets more of that nice yellow in from what I've seen.
The cool thing about IRChrome is you can shoot and process pretty normally. No swapping, or WB issues at all. Fortunately it seems none of my Canon lenses have hotspots.
Pentax 645Z
dmanthree
It means that there is no filter of any kind in front of the sensor, so the effect you get depends on the filter you place on the lens.
And to elaborate further, most all modern digital cameras come with UV and IR filters on the front of the sensors (some manufacturers make specialized cameras for astronomers and such without the filters, like Canon does with the Ra). These block UV and IR from reaching the sensor. Remove them, and the sensor now can "see" those wavelengths.
A full spectrum just removes the filters, and in the case of most mirrorless doesn't replace it with anything. Other conversions might add certain filters in place of the original, like passing only 720nm and above. Or sometimes just glass since esp with DSLRs than can affect focus.
The nice thing about full spectrum is you can use lens filters (either in front of the lens or behind it) to filter light; I used three different ones in the examples above. Or you can add a UV/IR cut filter; it cuts the same wavelengths as the original in-body filter, essentially giving you the original camera back.
Pentax 645Z
Severinbass New Member • Posts: 1
Hi
I also have a modified Canon EOS RP, but i cant get the WB right for the IRChrome.
If i choose Daylight as WB the Picture looks like a picture with a unmodified Camera. If i take a custom WB it looks the same.
Do you know what the problem is?
I would love to get a reply.
Thx
Severin Bassin
Severinbass wrote:
Hi
Thx
Severin Bassin
Are you using WB in-camera? I just shoot raw and then use WB in Lr. What profile are you starting with?
Here's one I shot recently with the Kolari IRChrome filter. 35mm lens. Profile is Adobe Color. I set WB with a gray card; turned out to set to 19k in Lr, with a -3 hue. Then I just hit "auto" to adjust the rest with a tad of texture. Normally I'd turn down the orange, but just wanted to show the effect. With this foliage I usually get a tilt to the orange vs red.
The "Daylight" setting in Lr would have given 5.5k and +10 hue, and a more muted shot. It's the second one.
So not sure why yours aren't working out.
Custom WB
Daylight WB
Pentax 645Z
