I don't know how to describe this lens issue
Started Oct 22, 2020 | Discussions
flysi3000
flysi3000 New Member • Posts: 4
I have a Canon 7D and a 70-200 f/4 IS L, and lately (well, at least since around the start of the pandemic) I've been noticing that I can't shoot anything sharp with it for the life of me. But it seems like more than just being out of focus. In fact, images look more like something from a Holga or one of those toy cameras with deliberate irregularities.
This image is a good example of the issue.
Anyone seen anything similar, and have an idea as to the cause?
Canon 7D / 1/3200s / f4 / ISO 800
 flysi3000's gear list:flysi3000's gear list
Canon EOS 7D Fujifilm X-T4 Canon EF 50mm F1.4 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-200mm F4L IS USM +2 more
Canon EF 70-200mm F4L IS USM Canon EOS 7D
LeicaEye Forum Pro • Posts: 10,560
Re: I don't know how to describe this lens issue
When I used the same lens on my 90D I had similar issues, I changed the Focus Point.. Set your camera/Lens up on a solid surface, use the timer and see how the image comes out.. If that's not in focus, check to see if Focus is an issue with other Canon Lenses, depending on the result it might mean a trip to the Canon Mother Ship ~ possibly both Camera & Lens..   L
Trying Harder Than Ever ..
pixseal
pixseal Veteran Member • Posts: 4,061
My 70-200 f/4 IS L suddenly developed a similar problem.  I could not get a sharp image even when focusing manually.  I sent it to Canon USA for repair and they fixed it for $200 (in 2013).
 pixseal's gear list:pixseal's gear list
Canon EOS R7 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 500mm f/4.0L IS II USM Canon EF 100-400mm F4.5-5.6L IS II +14 more
Kjeld Olesen
Kjeld Olesen Veteran Member • Posts: 4,594
Any chance ...
... problem is similar to this
https://www.dpreview.com/forums/post/64352630
 Kjeld Olesen's gear list:Kjeld Olesen's gear list
Canon EOS M Canon EOS 6D Canon EOS M5 Canon EOS R6
BlueRay2 Forum Pro • Posts: 14,816
hi Dave, did you ask canon what the issue was--and what was their answer?
if you look at God real close and for very long, you'll find defects!!!
it is definitely the focus! i would place the camera on a tripod in front of a brick wall and try to focus the the camera using different focal length and see what kind of result. if still not focused, i'd contact canon repair shot and consult with them about the issue.
pixseal
I was on a hike and using that lens and the problem started suddenly.  I don't recall impacting the lens.
ok, pixseal, that explains it...your lens had decentering issue--it can happen to any lens! i had this lens and loved it, it is one of the best canon makes. i lost mine in a park but replaced it with a new canon 100400 II at the time and never looked back. i am getting the itch for a 70-200 f4.0 IS again, and i am very close to get a copy. it is a great small tele lens for travel, producing some high quality photos! good luck.
