Is there an adapter that allows a Canon EF lens to be mounted on Nikon F?
Astrophotographer 10 Forum Pro • Posts: 13,862
No text.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony a7R III Canon EOS Ra +1 more
kenw
kenw Veteran Member • Posts: 6,293
Re: Is there an adapter that allows a Canon EF lens to be mounted on Nikon F?
Nikon F has a shorter flange distance than Canon EF so any adapted lens would not focus to infinity.
There are Canon EF to Nikon Z if that’s what you meant to ask (you are posting in the Z forum).
Ken W
See profile for equipment list
 kenw's gear list:kenw's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Nikon Z7 Nikon Z 14-30mm F4 Nikon Z 24-200mm F4-6.3 VR +37 more
OP Astrophotographer 10 Forum Pro • Posts: 13,862
Thanks Ken.
Greg.
djd97 Regular Member • Posts: 265
kenw wrote:
Nikon F has a longer flange distance than Canon EF so any adapted lens would not focus to infinity.
Fixed your typo.
(@OP, the answer is still correct though)
 djd97's gear list:djd97's gear list
Nikon D7000 Nikon Z6 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Nikkor 24-85mm f/2.8-4D IF Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +3 more
cosmicnode Veteran Member • Posts: 5,623
Astrophotographer 10 wrote:
There are adaptors from canon EF to Nikon F, they have a element to correct for infinity focus which may affect image quality.
https://www.ebay.co.uk/itm/Canon-EF-EOS-Lens-to-Nikon-F-mount-adapter-D4-D4S-D610-D810-D3300-D7100/332565071010?hash=item4d6e6c44a2:g:zbIAAOSwnUlaj7uk
_ _
Mike.
"I say we take off and nuke the entire site from orbit, it's the only way to be sure."
 cosmicnode's gear list:cosmicnode's gear list
Nikon D1 Nikon D1X Nikon D1H Nikon D2H Nikon D2X +16 more
goldaccess Regular Member • Posts: 152
Wonder why you ask this (F Mount) question in the Z Mount forum.
 goldaccess's gear list:goldaccess's gear list
Nikon Z7 Nikon AF-S Nikkor 20mm f/1.8G ED Nikon 500mm F5.6E PF Nikon D4 Nikon D500 +17 more
kenw
Fixed your typo.
Doh!  Thanks for the correction to keep things less confusing.
And thanks to cosmicnode for finding the optical converter - I wondered if one existed as I knew there were some for other similar cases like Canon FD to Canon EF.
Ken W
