Why does my bad K70 solenoid work OK on M?
petrock Regular Member • Posts: 145
No text.
Pentax K-70
flektogon
flektogon Veteran Member • Posts: 4,644
Re: Because...
Your K70 is very likely a typical "lemon". As I remember, you already had some intermittent problems with LCD.
Anyway, if the aperture solenoid is faulty, then it should not work properly regardless the exposure mode. Some users however found out that the aperture tends to work "more properly" in the LV mode.
Peter
ozdean
ozdean Forum Pro • Posts: 26,313
Re: Why does my bad K70 solenoid work OK on M?
You are using the aperture ring?
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-50 Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +13 more
OP petrock Regular Member • Posts: 145
Yes, I'm using the aperture ring, on both A and M lenses.
ozdean
There's your answer, you are stopping it down.
Then is the aperture operated more mechanically on M; but electrically via the solenoid on A ?
GossCTP Veteran Member • Posts: 5,444
The solenoid opens the aperture and then closes it for the shot. If it is not working then setting the lens to a value on the aperture ring will cause it to be at that stop, like a permanent DOF preview.
"Law and order" is anathema to liberty and justice.
 GossCTP's gear list:GossCTP's gear list
Panasonic Lumix DMC-LX5 Pentax K20D Pentax K-5 II Fujifilm X-H1 Pentax smc FA 50mm F1.4 +8 more
