EOS M50 Firmware Update, Version 1.1.0
Started Oct 20, 2020 | Discussions
P runar Regular Member • Posts: 361
Firmware Version 1.1.0 incorporates the following enhancement and fixes:
1. Enables NFC connection with smartphones running Android 10 operating system.
*For Android running v6.0 or later, use Camera Connect v2.7.10 or later.
*For Android running v5.0 or older, use a connection method other than NFC.
2. Fixes a phenomenon where, in rare cases, the camera may not autofocus at the edges of the image area.
3. Fixes a phenomenon in which, when using a Web service, if a camera is registered that is the same model as a camera that had already been previously registered, the registration data of the previously registered camera is overwritten.
4. Fixes a phenomenon in which, with [Display settings: Manual/Screen] set, when the camera's LCD screen is closed, after connecting to EOS Utility, the Remote Live View window is not displayed correctly in some cases.
This firmware update is for cameras equipped with firmware up to Version 1.0.3. If the camera's firmware is already Version 1.1.0, this update is unnecessary.When updating the firmware of your camera, please first review the instructions thoroughly.
I tested the NFC connection an it works on my Android 10 phone.  Great
when i tested the autofocus thing i didn't see anything different .
 P runar's gear list:P runar's gear list
Canon EF-M 32mm F1.4 Canon EOS M Canon EOS M50 Canon EOS M6 II Canon EF-M 18-55mm f/3.5-5.6 IS STM +4 more
Canon EOS M50 (EOS Kiss M)
Alan Sh Senior Member • Posts: 2,757
Re: EOS M50 Firmware Update, Version 1.1.0
15
I nearly got excited when I read the title - then opened the post.
 Alan Sh's gear list:Alan Sh's gear list
Canon EF-M 55-200mm f/4.5-6.3 IS STM Panasonic Lumix DMC-ZS40 (TZ60) Canon EOS M100 Canon EOS M50 Fujifilm X-T5 +13 more
OP P runar Regular Member • Posts: 361
The M100 have a new firmware update for this NFC - android 10 connection too:-)
jkcz Regular Member • Posts: 168
I wonder what else they changed, the version number jump usually means something more than just a little bug fix. Till now we got original firmware->1.02->1.03 and now suddenly 1.1.0. Anyone notice a difference in autofocus performance?
 jkcz's gear list:jkcz's gear list
Canon EOS M100 Canon EOS M6 II Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +2 more
YehudaKatz Senior Member • Posts: 2,512
Where did you download it from?
 YehudaKatz's gear list:YehudaKatz's gear list
Canon EOS 6D Canon EOS M50 Canon EF 24-105mm f/4L IS USM Canon EF-M 22mm f/2 STM
Thank you.
Re: Where did you download it from?
Thank you.
No text.
I failed to download Firmware Update, Version 1.1.0
No text.
Re: I failed to download Firmware Update, Version 1.1.0
yehudakgtbnet wrote:
I mean failed to install.
Were in the installation did it fail ?
The camera didn't recognize Version 1.1.0
Could you install it?
I tested it on both of my cameras.
Interesting that DPR has no mention in its News of the upgrade.
Flying Fijian Senior Member • Posts: 1,619
THERE IS NO M50 MK II - Just Firmware?
Maybe if enough people make noise about M50 Mark II, you might actually get a firmware update for the old M50...worth a shot!
 Flying Fijian's gear list:Flying Fijian's gear list
Ricoh GR III Fujifilm X-E3 Fujifilm X-T4 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R +13 more
Re: The camera didn't recognize Version 1.1.0
Yes after doing this,,,
If the firmware update files are saved in the subfolder of the SD card, they will not be recognized by the camera.
first copy the CCF19.DAT file to the root directory of the SD card, and then copy the CCF19xxx.FIR file.
Re: I tested it on both of my cameras.
it is only a small update of the firmware, like bug fixes
Re
yes, canon give us a mk2 firmware update
I followed this word-by-word.
No text.
Re: I followed this word-by-word.
Hmm..,you can try this ,,removing the lense and use P mode.
Finally managed to download the software
I thank you.
Yehuda
