Fujifilm S5 pro
Started Oct 16, 2020 | Questions
Hollyfg New Member • Posts: 6
Fujifilm S5 pro
Hi there, my ancient memory card will not format properly and shows zero frames available. I have followed instructions from the manual but it does not work. What can I do to resolve this problem. I put the photos on a computer with a cable. I deleted all photos then tried formatting. Still showing FULL! Would appreciate a solution. This a new camera for me and it is just one challenge after another
Fujifilm FinePix S5 Pro
Tom Schum
Tom Schum Forum Pro • Posts: 13,282
Re: Fujifilm S5 pro
Having owned and hassled with digital cameras for a while I have a few suggestions, but I haven't owned a S5.
My guess is you used the computer to delete the photos, rather than using the camera for this.  Earlier cameras get very confused by this stuff.  Deletion should happen only in the camera.
I assume you are trying to format the card using the camera.  It isn't a good idea to try to format using the computer, while the camera and computer are connected with a cable.
You could try to copy one of the photos to the card from the computer, then see if you can view that photo using the camera.  If so, it might format.  Do not use the computer to format the card.
I guess you have already tried the usual things:  1) Remove the card and check to be sure the file protect switch on the card is set to read/write (its normal position).  2) Put the SD card in a SD reader and put it in the computer and format the card in the computer, then try to format it in the camera and 3) for any action, battery in camera must be fully charged.
Good luck with all this!
Tom Schum
Copper: Mankind's favorite electrical conductor
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
Morris0
Morris0 Forum Pro • Posts: 32,181
Re: Fujifilm S5 pro
Hi Holly,
It took reading the other poster's post to realize the S5 Pro uses CF cards.   Use a flashlight to look into the CF slot.  Is a pin bent or missing?  You can also check the CF card for the pin from the camera stuck in the card.
I hope my hunch is wrong,
Good luck,
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Tom Schum
Re: Fujifilm S5 pro
I've owned cameras with CF cards.  Didn't think that the S5 would have them!
I always worried about pins bending in the camera!  Never happened to me though.  I guess I was just lucky.
Tom Schum
Morris0
Re: Fujifilm S5 pro
The S5 Pro is a Fuji modified Nikon D200.  I owned and loved my D200.  I never had a pin bend or break inside a camera though it did happen to one of my card readers.  The pin got stuck inside a Microdrive.  Had to extract the pin with a knife and then a tweezers.
Morris
OP Hollyfg New Member • Posts: 6
Re: Fujifilm S5 pro
Thanks for the advice my computer is out of town at the moment will try next week!
tokyowalker Regular Member • Posts: 152
Re: Fujifilm S5 pro
Some compact flash cards have a write protect switch on them. You should look for a little switch on the edge of the card. None of the cards have them but many do.
Morris0
Re: Fujifilm S5 pro
tokyowalker wrote:
Some compact flash cards have a write protect switch on them. You should for look for a little switch on the edge of the card. None of the cards have them but many do.
CF cards do not have this switch
Morris
Re: Fujifilm S5 pro
Morris
Some do. Actually I have several that do. Try Google.
DarnGoodPhotos Forum Pro • Posts: 11,881
Re: Fujifilm S5 pro
Get a new card, and it's better to format cards in the camera as opposed to with your computer.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
Morris0
Re: Fujifilm S5 pro
tokyowalker wrote:
Morris
I found none.  Please provide a link to one.
Thank you,
Morris
Re: Fujifilm S5 pro
Morris0 wrote:
tokyowalker wrote:
Morris
Thank you,
Morris
Here’s an example from DigiKey:
https://www.digikey.com/en/product-highlight/a/apacer/industrial-cf-6-compactflash
CF is used in hundreds of other products beside photographic cameras. Actually not many cameras use them these days. The CF cards have been around longer than digital cameras. The reason some of them have a write protect switch is to ensure that a device cannot corrupt or overwrite its boot device.
Again not all the cards have them, and if you have like newer Transcend or other types of cheaper consumer grade memory it might not have it. But actually the Kodak ones that came with my DCS Pro back had write protect switches.
Re: Fujifilm S5 pro
Morris0 wrote:
tokyowalker wrote:
Morris
Thank you,
Morris
Example .. Little green switch in lower right corner
Morris0
Re: Fujifilm S5 pro
tokyowalker wrote:
Morris0 wrote:
tokyowalker wrote:
Morris
Thank you,
Morris
Interesting.
Re: Fujifilm S5 pro
Mine doesn't it seems but thnks for the tip. Hope I can get this sorted as my daughter loves the camera!
jaberg
jaberg Senior Member • Posts: 1,037
Re: Fujifilm S5 pro
I just went down and opened the Pelican case containing my (now seldom-to-never used) FinePix Pro S2. ALL of the “period correct” CF cards — mostly SanDisk and Lexar — have the write protect tab and until you claimed otherwise I was under the impression, based on my past experience, that this was standard for the medium. Granted, the S2 is the last CF equipped camera I’ve owned, having made the switch to MFT instead of a “modern” DSLR and (with the purchase of an X100v) now moving towards a Fujifilm quiver.
As you say, “interesting.”
 jaberg's gear list:jaberg's gear list
Fujifilm X100V Fujifilm X-S10 Nikon AF Nikkor 85mm f/1.8D Fujifilm XF 16-80mm F4 Fujifilm XF 70-300 F4-5.6 R LM OIS WR +3 more
jaberg
Re: Fujifilm S5 pro
This is the “best practice” that I learned and follow — Format the card in the device you intend to write (record) with. It contradicts the suggestion made at the top of this thread. The exception is that I have used a computer to perform a low-level format on a “bad” card, but I then re-format the card in the camera before use.  However, the more hoops I have to jump through the more likely I am to just bin the card and replace it with one that isn’t giving me problems. Why ask for trouble?  (Fortunately, since switching to SD family cards I genuinely can’t recall having any issues — touch wood.)
Re: Fujifilm S5 pro
+1
Re: Fujifilm S5 pro
Yes I think you are right, I have the computer back and it doesn't even read the fuji. so I couldn't put the photos back on even if I tried. Is it possible to get these older cards then. I shall try to order online. Then i will be very careful next time
Thank you
Re: Fujifilm S5 pro
Thank you for trying to help me
