Remote control for M6ii
Started Oct 15, 2020 | Discussions
marx5002 Forum Member • Posts: 70
Are there any other possibilities to remotely press the shutter than the BR-E1(and smartphone) ? I know at least one called Aodelan, but the price is almost the same.
Is it compatible with the rc-6? Or does the M6ii even have IR?
Canon EOS M6
DC Guy Forum Member • Posts: 68
Re: Remote control for M6ii
There are couple from Vello
Vello FreeWave Plus and Vello Wireless Hutterboss (works with DSLRs also)
 DC Guy's gear list:DC Guy's gear list
Canon EOS M Canon EOS M6 Canon EOS M100 Canon EF 100mm F2.8L Macro IS USM Canon EF-S 55-250mm f/4-5.6 IS II +3 more
OP marx5002 Forum Member • Posts: 70
Thanks for the answer. But would prefer something that leaves the hotshoe free for flash triggers
R2D2 Forum Pro • Posts: 26,528
The M6ii uses Bluetooth for remote activation (it doesn't work with my RC-6). Just be sure to disable Bluetooth in the camera when you're not using it (so it doesn't use battery).
Some radio remotes plug into the "remote" port on the M6ii (leaving the hotshoe free). Otherwise the port works great with a wired remote also.
R2
beagle1 Forum Pro • Posts: 11,740
R2
yes, I just use a cheap ebay wired remote for my M5
www.flickr.com/photos/mmirrorless
R2
Thaks R2. I think I'm going with the bluetooth remote, a lot easier in the long run for 20 extra bucks.
rrc1967 Senior Member • Posts: 1,984
cable release works too - any of the remote wired releases that have the rebel connections work just fine.
Maxmolly7
Maxmolly7 Senior Member • Posts: 1,481
Just for the record, I also found out just now, that the M6II does not work with IR remotes. I didn't know before and was assuming I could still use my RC1 as on the M6I.
You have to use the timer or, the smartphone with App instead.
Otherwise you have to buy a new bluetooth remote and pair it with the camera and, oh well, a cable release.
May THE LIGHT be with you!
 Maxmolly7's gear list:Maxmolly7's gear list
Sony RX10 IV Sony RX100 VII Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +16 more
