X-T4 Aperture won't change with aperture ring in Movie Mode
Started Oct 14, 2020 | Questions
STKY New Member • Posts: 1
For some reason, when I'm in movie mode on my X-T4, the aperture ring won't adjust the aperture. Nothing at all changes when I turn the ring. It works in Stills mode and with multiple lenses but the only way I could adjust it in Movie mode was to add aperture to the command dial. I've looked around the settings and can't seem to pinpoint why this is happening.
Anyone else have this problem?
ne beginner Senior Member • Posts: 2,382
Re: X-T4 Aperture won't change with aperture ring in Movie Mode
I have an X T4, but have never used movie mode on it, or any camera for that matter, so no. Only have shot video on a few occasions using a camcorder or cell phone. But I'll see what you find as the solution, and keep it in mind, should ever do so.
 ne beginner's gear list:ne beginner's gear list
Sony a7R IVA Sony 35mm F1.4 G Sony 70-200mm F2.8 G SSM II Sony FE 16-35mm F2.8 Sony FE 20mm F1.8G +1 more
RogueOne Regular Member • Posts: 200
6
Page 262 of the manual specifies that if MOVIE OPTIMIZED CONTROL is enabled, you can't change the Aperture by the ring, only the command dial: Manual
 RogueOne's gear list:RogueOne's gear list
Fujifilm X-T2 Fujifilm X-E3 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +4 more
Emdeewee New Member • Posts: 1
I'm having the exact same issue.... Did you figure out a solution? Would love to know, I'm at a a loss here...
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,179
Just look into the thread! Question was already answered threenmonths ago. "Movie optimized control."
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
Duclos New Member • Posts: 1
This just started to happen  to my XT4. Did you figure out how to fix this problem?
RSB007 New Member • Posts: 1
Hi. Did you solve this problem as I have it now! Thanks.
Chandrahadi Junarto
Chandrahadi Junarto Contributing Member • Posts: 532
I rarely use video with my xt4, just because this thread I'm trying change my aperture from the lens aperture ring while shooting. There's no problem with mine.
I believe it's related to the answer from someone in this thread about movie optimize control switch off
 Chandrahadi Junarto's gear list:Chandrahadi Junarto's gear list
Leica M8.2 Nikon Df Fujifilm X-T4 Nikon AF Nikkor 180mm f/2.8D ED-IF Tokina AT-X 10-17mm f/3.5-4.5 DX Fish-eye +17 more
nonoriri New Member • Posts: 1
Hi! I had the same issue with xs10. I fixed it by going to the movie menu all the way down to "movie optimized control" and turn it off.
I hope it works for you too
holunfarn New Member • Posts: 1
I hope you already found your answer but just in case:
switch off the "movie optimized control" from menu>movie setting>movie optimized control.
when it's "ON" it disable the ISO/shutterspeed/aperture dials so it won't be affected by your still settings when you switch to movie, something like that..
JEANK1K New Member • Posts: 1
I had the same problem, you just need to go to Movie Settings and change Movie Optimized Control to OFF.
 JEANK1K's gear list:JEANK1K's gear list
Fujifilm X-T4
ConGanasMedia New Member • Posts: 1
I just had this happen today while shooting a video for work (so embarrassing I had to fiddle with the camera before just using the onscreen option). I'm home now and did some fiddling with the camera and under the Movie Settings there's a dumb dumb dumb option called Movie optimized control where it disables the ability to change aperture from the lens dial. Just turn that off and you're good. I have no idea how it got turned on.
Anyway TL:DR - Movie Optimized Control in Movie Settings. Make sure it's off.
Hope this helps someone frantically searching for answers in the future.
Olga Dekell
Olga Dekell New Member • Posts: 1
menu - movie settings - movie optimised control = off
