Alexis wrote:
rrc1967 wrote:
Alexis wrote:
rrc1967 wrote:
I have no words for this release. Even my article on this announcement states that
Shelf stuffing at it's finest.
The only good thing about this camera? I won't be spending money on Canon cameras this Christmas, which it looks like I'm going to go to Colombia in November or December anyway, so there's that.
I got the M6 Mark II last december for a crazy deal ($750 for EVF, 15-45mm kit). I thought at the time I was only going to temporarily use it and didn't get it full-spectrum converted.
I take it you don't do any flash photography and/or video work with external microphones?
external microphones is never a problem - use a cage system (cold shoe plate,etc) and be done with it. External microphones do not necessarily have to go on the hotshoe, it's just a "convenience". If i'm using a microphone, odds are I don't need an EVF (and yes, I have one)
it's the flash that is of course a problem - what someone needs to do is make a E-TTL II extension cable with the data passthrough.
I have a E-TTL passthrough cable (for shooting using umbrellas etc) but I honestly don't think that the EVF will work on top of the hot-shoe passthrough ( I seem to recall someone explaining why this was not possible but I don't remember where I saw it).
the standard ETTLII does not have the EVF data connections. it would have to be a passthrough specifically made for the EOS-M's.
For those times I just simply don't use the EVF. Usually, when I'm shooting with flash it's indoors, so having an EVF is less of a problem. Or if I need both, I use the built in flash.
I also have a M5 as well, so if there are times I really need both I can use that camera, but in reality, it's not that much of a limitation for me.
I guess I could keep the M50 as my "flash" camera! I need to get my hands on a M6II with EVF to see how practical it is.
I came from the M5 - so I came from an EVF based camera. I don't mind it at all***. and having the choice of the two EVF's can be liberating.
There's just little things on the M6 II that are apparent after use, even after using Canon's M5 flagship - it's just more responsive, fast, AF, everything. Outside of the EVF, it's easist the best camera I've used sans 5D Mark IV and even then, if i consider it only cost less than $1000 and it weights 450g and easily travels. it's just a home run.
and yes, I mant a M5 Mark II
and a R5s ..
luckily I guess Canon is going to save me some money this year.
*** I have to add .. I don't mind it at all once i got used to it.
