An "angled" minijack adapter for Ronin-S Control cable
Started Oct 10, 2020 | Questions
Michael Perfect
Michael Perfect Regular Member • Posts: 182
Bonjour !
The Ronin-S gimbal can control the Lumix GH4 using the bellow cable that plugs into it via a 2.5mm minijack with 3 rings :
Because of balancing needs of my rig, this minijack can't fit between the camera and the tilt arm of the gimbal, unless I find a "bent" adapter from the camera to the DJI cable. I'm thinking of an adapter in this style :
But as you can see, this is just a regular stereo adapter with 2 rings.
Here is the question :
Would the connection work if I find any 3 rings adapter in this style or is it a really specifically DJI/GH4 custom system which won't work even with a 3 ring adapter ?
Merci a lot
Michael
Current work : MIKRO, the Aliens from Earth (self produced)
https://www.youtube.com/channel/UCC71RypUFAfLnXEVIzw-llA
 Michael Perfect's gear list:Michael Perfect's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Canon EF 100mm F2.8L Macro IS USM Venus Laowa 7.5mm F2 MFT +4 more
Re: An "angled" minijack adapter for Ronin-S Control cable
You could buy a 2.5mm right angle connector and 2.5mm female connrlector and make your own cable, but I think it would be easier to buy 2.5mm to 3.5mm right angle 4-pole adapter (a bunch available everywhere) and then 3.5mm to 2.5mm 4 pole adapter (also available) as I could not find 2.5mm to 2.5mm right angle 4 pole adapter.
Michael Perfect
OP Michael Perfect Regular Member • Posts: 182
Michael Perfect
Ali to the rescue
Michael Perfect
lol I bought it I hope it's not a piece of cheet
Michael
