Hanging Pentax DA 300 F4 on K1 Upside Down From Camera Sling by Tripod Collar. How Safe?
Started Oct 7, 2020 | Questions
Bobolink
Bobolink Regular Member • Posts: 150
Hi,
I just purchased the BlackRapid Sport Breathe Original Camera Sling and I want to use it with my Pentax DA 300 F4 on either my K1 II or my K3. The best balance point would be hanging it (upside down) from the tripod collar, but this makes me nervous because of the fact that the plate attaches to the ring with a screw that basically holds on by pinching it. I worry that over a period of time the screw could loosen and the whole rig could fall off (yikes!).
Does anyone have any experience or opinions on this?
I'm going on a long birding walk tomorrow and am hoping to use my new sling.
Thanks for any feedback on this!
-Bob
 Bobolink's gear list:Bobolink's gear list
Pentax K-01 Pentax K-5 II Pentax K-5 IIs Pentax K-3 Pentax K-1 II +1 more
Pentax K-1 Pentax K-1 II
MightyMike Forum Pro • Posts: 41,691
Re: Hanging Pentax DA 300 F4 on K1 Upside Down From Camera Sling by Tripod Collar. How Safe?
I've seem people do this sort of thing, I never liked the idea, a neck strap works for me even if it makes my neck sore after some hours
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/user/SpeEedy/profile/photos?sortBy=photoFavoriteCount
Michael Arbor Regular Member • Posts: 275
Mine is rigged this way...
Works great!
K-1 MkII+DA*300/4+HD1.4TC
With the carry lug adjusted to the 9 o'clock position, I sling the kit across my body so it hangs from my left side at my waist with the lens pointed to the rear. Note the use of two attachment straps. The lug strap carries the load, the other is for peace of mind though I've never needed the backup protection it offers. I can go all day with no problems.
While my sling/strap setup is made by OPTECH USA, I bet you can rig your BR sling to work in a similar way.
Cheers... M
Michael
No one cares how hard you worked.
Works in progress:
https://www.flickr.com/photos/michaelina2/
Bobolink
OP Bobolink Regular Member • Posts: 150
Re: Mine is rigged this way...
PortrayingLife wrote:
Works great!
Cheers... M
Great!  So I guess you've never had the screw between the plate and the collar loosen after a prolonged period.  That's good to know.  I still get a bit nervous but maybe it's OK.
Thanks for your encouraging reply!
hikerdoc Veteran Member • Posts: 3,513
Be sure to check that connection periodically even if you think it is very tight. I did have an early BR. With the constant swinging on the hip during hiking the screw lug could loosen. The locking collar on earlier BR carabiners also were not secure and I did have a camera fall. They began offering those accessory security straps as an add on. One other attachment option that does not involve screw on lug are the QD swivels from RRS or Magpul which attach securely to a port on my RRS lens feet or L brackets. I have not used a BR since my incident 8-10 years back, but they have apparently improved on the early design flaws. The frequent threads of several years back on cameras damaged by BR shortcomings have disappeared.
robgendreau Forum Pro • Posts: 10,926
I have a different sling but it attaches to the collar foot via a ¼ tripod screw as well. Very secure if you tighten it.
But mine doesn't have a snap link.
The collar is usually a good balance point but that's still a bunch of weight and bulk. My strap allows me to draw it in close, which helps prevent swinging around. And I always have a hand or two on such a big combo; I use the strap just to help with carrying it, and don't let it just dangle like I would with say the K-1 and a 50mm.
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
miles green
miles green Veteran Member • Posts: 7,827
You can use some Locktite, which is meant to secure metal screws.
I use the strong one for the screw that fixes the boat anchor to the chain... That one must NOT get loose. I use the light one to secure adjustment screws on my saxophone. They must stay adjustable but still move. I believe medium strength should be ideal for the tripod screw, but it helps if you check it on a regular basis.
Miles Green
Pentaxian since 1997!
Corfu, Greece
N.B. All my images are protected by Copyright
 miles green's gear list:miles green's gear list
Pentax K-1 Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +7 more
