What aspect ratios do Pentax users like?
Started Oct 5, 2020 | Discussions
Barry Pearson
Barry Pearson Veteran Member • Posts: 9,625
This question was prompted by an article in "Black+White Photography":
Issue 243, page 72 onward.
The author, Eddie Ephraums, discusses the way some photographers concentrate mainly on a single aspect ratio, for example 1:1, 3:2, 2:1, 4:3, 16:9, 7:5, etc.
And may become well-known for it.
He made himself a simple adjustable hand-held viewer so that he could judge scenes without needing to look through a camera viewfinder.
(Using such a viewer is apparently commonplace in cine photography).
Some cameras can be adjusted so that different aspect ratios are seen in the viewfinder.
My K-1-series can be switched between aspect ratios, including 1:1.
My Ricoh GRIII can be set to 3:2 or 1:1.
And, of course, images can be cropped later in Lightroom or Photoshop.
Lightroom has several built in aspect ratios, as well as "Custom".
So back to the title of this thread:
"What aspect ratios do Pentax users like?"
Perhaps with a follow-up question:
"What assistance (if any) would be desirable in cameras?"
________
Some useful articles:
 Barry Pearson's gear list:Barry Pearson's gear list
Ricoh GR III Canon EOS R5 Canon EOS R7 Venus Laowa 12mm F2.8 Zero-D Canon RF 70-200mm F2.8L IS USM +28 more
Pentax K-1 Pentax K-1 II Ricoh GR III
ogl
ogl Senior Member • Posts: 2,004
Re: What aspect ratios do Pentax users like?
I like to see 4:3 и 5:4...
 ogl's gear list:ogl's gear list
Pentax K-5 IIs Pentax smc FA 43mm F1.9 Limited Pentax smc FA 31mm F1.8 AL Limited
JeremieB Senior Member • Posts: 2,041
I usually stick to the 3/2 without questioning it, but when I crop I prefer the square format.
I'm not fond of 16/9 or 16/10 (my phone does that) or wide panoramas. They are nice for saving more information about a place though.
Regarding tools, my camera being 6MP I avoid cropping anyway, and never more than 3/2 to 1/1.
 JeremieB's gear list:JeremieB's gear list
Pentax K-3 Mark III Pentax K-70 Venus Laowa 25mm F2.8 2.5-5X Macro Sigma 105mm F2.8 EX DG Macro Samyang 85mm F1.4 Aspherical IF +9 more
GossCTP Veteran Member • Posts: 6,207
I used to shoot a Panasonic LX5, which had a multi aspect sensor. I shot mostly with 4:3 and 3:2. If I were picking one to add to a camera it would be 7:5 as I find images from 5x7 cameras pleasing.
"Law and order" is anathema to liberty and justice.
 GossCTP's gear list:GossCTP's gear list
Panasonic Lumix DMC-LX5 Pentax K-5 II Pentax K20D Fujifilm X-H1 Pentax 16-85mm F3.5-5.6 WR +8 more
MightyMike Forum Pro • Posts: 41,691
35.9:24 seems to be a reasonable ratio... but I trim a little to get 3:2 in post processing
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/user/SpeEedy/profile/photos?sortBy=photoFavoriteCount
Lessiter Regular Member • Posts: 412
3:2 landscape
4:3 portrait
Adam007 Contributing Member • Posts: 805
For landscapes and even some environmental portraits, I like 16:9
 Adam007's gear list:Adam007's gear list
Fujifilm X100F Pentax K-1 Pentax K-3 Mark III Pentax smc FA 77mm 1.8 Limited Pentax smc FA 43mm F1.9 Limited +7 more
yardcoyote Forum Pro • Posts: 15,754
I like, in this order, 1:1, 4:3, 16:9 (both vertical and horizontal), other.  But (with one exception) I never change aspect ratios in camera.  I always shoot with the whole sensor to gather as much data as possible and crop later in post.
You certainly don't need fancy expensive software like Lightroom or Photoshop to crop a photograph!  Any basic image viewer, photo browser, editing suite for a phone OS, etc, has a cropping board.  I crop my images (and do other basic edits like sharpening, and tweaks to gamma, contrast, highlights and shadows, etc.) in FastStone, which is freeware, and in Pixlr on my phone.
The one exception is my small camera, the Little Monster, which is a Fuji X-M1 with the 27 mm pancake lens on board.  I sometimes set this camera to 1:1 just for fun, particularly when shooting with a fixed aperture toy lens.
Instagram: @yardcoyote
 yardcoyote's gear list:yardcoyote's gear list
Fujifilm X10 Fujifilm X100T Pentax K-5 IIs Fujifilm X-T10 Fujifilm X-M1 +20 more
(unknown member) Regular Member • Posts: 204
Interesting question ... I used exclusively 3:2 for over 10 years, but then got a Pentax 645Z with a 4:3 aspect ratio. Since then, I have a huge preference for 4:3 in portrait orientation and find 3:2 looks unnatural. For landscape orientation, both aspect ratios work fine, and what works best depends on the subject and composition.
Phil A Martin
Phil A Martin Veteran Member • Posts: 8,363
________
In like 6x7 primarily after my Mamiya RB67 but 4x3 approximates to that in digital, so my Panasonic LX100 is mainly left on that ratio or occasionally 1x1. My DSLR is obviously 3x2 and I find that too wide for my taste but as I'm composing in that ratio, I leave it like that and don't alter it later. What I would like but will never get, is a full frame 4x3 camera with the sensor the same width as FF but with a length conforming to 4x3 ratio. I know I could crop an FF EVF camera but I'd still be fretting about the lost pixels.
MrB1 Contributing Member • Posts: 605
When shooting I use the whole sensor 3:2 in landscape or portrait orientation, as appropriate for the subject.  In PP I crop to whatever looks right for the final image, which is often at or close to 16:9, 3:2, or 7:5, in either orientation.  The A series (close to 7:5) papers and printers are common, as are inexpensive frames with A4 pre-cut mat boards, so for me 7:5 is a convenient ratio for a home-made A4 framed print.
Philip
kenwklau
kenwklau Contributing Member • Posts: 600
Re: 3:2 for Landscape and 4:3 for Portrait
Ken
 kenwklau's gear list:kenwklau's gear list
Pentax K-5 IIs Pentax K-1 II Pentax smc DA 50mm F1.8 Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Pentax smc DA 55-300mm F4.0-5.8 ED +17 more
DougOB
DougOB Veteran Member • Posts: 3,176
Lessiter wrote:
3:2 landscape
4:3 portrait
I never really though about the question aside from a general sense of preferring 3:2 over 4:3 and not being a big fan of 16:9.
Having said that... I like this answer... it makes sense to me. I will have to play with it.
Doug
 DougOB's gear list:DougOB's gear list
Ricoh GR IIIx Pentax K-3 Pentax Q-S1 Pentax KP Pentax K-70 +36 more
Holger Bargen Veteran Member • Posts: 4,911
The aspect ratio is selected during the postprocessing for most of my photos.
After a long time looking at my photos on a monitor,exclusively, I ordered a couple of prints from my last holiday. I ordered them 13 cm - but I did not realized, that the 13 cm is the smaller side and the longer side depends on the aspect ratio I selected before. My photos with ratio 1:1 were 13 cm each side and looked just small all. I had a few photo with 16:9 ratio - and they came 23.1:13 - very nice panoramas.
My this is exactly what you can expect and there is nothing special about it. But to me it was a nice surprise to get that large prints if I select a wide aspect ratio (for the same price as the tiny 1:1 prints).
Now, I will think about process towards 16:9 more often ...
Best regards
Holger
________
 Holger Bargen's gear list:Holger Bargen's gear list
Pentax K-5 Pentax K-S1 Pentax K-1 Sigma 105mm F2.8 EX DG Macro Sigma 17-70mm F2.8-4 DC Macro OS HSM +7 more
LightBug Senior Member • Posts: 2,818
3:2 for landscapes, 3:4 for portraits
3:2 is too tall for vertical portraits, so I've been trimming 3:2 shots to 3:4 for portraits. I do think 3:2 is fine for wide landscapes though.
 LightBug's gear list:LightBug's gear list
Pentax Q-S1 Pentax 645Z Pentax KP Ricoh Theta V Pentax smc DA 15mm F4 ED AL Limited +19 more
Stephenhampshire
Stephenhampshire Contributing Member • Posts: 962
7x5
I standardise (mostly) on 7x7 or 5x7
Shoutout to 1x1 and then letterbox shapes of various ratios
 Stephenhampshire's gear list:Stephenhampshire's gear list
Samsung TL350 Fujifilm X20 Panasonic FZ1000 Pentax K-5 Pentax K-3 +28 more
Phil A Martin
________
Can I just add that I've never liked Eddie Ephraums. He always seemed to me to represent the triumph of technique over content. Attractive but empty images.
I much prefer the work of John Blakemore and Thomas Joshua Cooper, for pure black and white landscape photography with first class printing.
paulkienitz
paulkienitz Veteran Member • Posts: 5,459
Since I shoot birds a lot and am often cropping severely, I have no consistent pattern.  But there is a certain tendency to do bird cropping as a square.  With landscapes on the other hand, a cinerama aspect ratio sometimes makes sense, though of course then people might just think it's a stitched pano.
"A good photograph is knowing where to stand." -- Ansel
 paulkienitz's gear list:paulkienitz's gear list
Pentax K-3 Pentax Q Pentax smc DA 50mm F1.8 Pentax smc DA 55-300mm F4.0-5.8 ED Samyang 8mm F3.5 Aspherical IF MC Fisheye +4 more
Re: 3:2 for landscapes, 3:4 for portraits
Interesting, we share the same view. Have you always felt this way, or only after using the 645Z?
Interesting, I went from 4:3 for my first few digital cameras and then to 3:2, since 3:2 I've never looked back.
Mike from Canada
